02-10-2024, 01:56 PM | #1 |
Rep 94
Weird Smell
I’ve noticed that everytime I wash my car and keep it in the garage it gets a weird smell. Like if you leave a wet towel in your trunk kind of smell. I don’t know if its the rotors or the fender guards.
Has anyone experience this as well? |
02-10-2024, 02:03 PM | #2 | |
Rep 84
Good luck, Ralph |
GTTC55.00 tracer bullet2419.00 |
02-10-2024, 03:35 PM | #3 |
Rep 42
Or in the front cowl where the air vent is by the windshield. Try running the A/C and spray Lysol into it.
02-10-2024, 03:43 PM | #4 |
Rep 94
02-10-2024, 03:44 PM | #5 |
Rep 94
02-11-2024, 01:19 PM | #7 |
Rep 94
02-11-2024, 02:47 PM | #8 |
Rep 1,096
If musty smell, you have water inside somewhere...if where you are in Texas (I assume) still get warms now..wash it and let it sit in the sun for a bit, see if water vapors start showing up around the glass. This happened to me in a previous vehicle I had...water was coming in, smelled a bit musty, left it in the sun for about 1 hr and then sat inside...it smelled a bit musty again and condensation was building inside the passenger side. The culprit? clogged drain tubes dripping slowly water along the A-Pillar making the carpet there humid, but not soaking wet.
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
GTTC55.00 |
02-11-2024, 08:46 PM | #9 | |
Rep 94
02-12-2024, 07:10 AM | #10 |
Rep 1,096
Trust your sense of smell. If no visual signs of water condensation, does it feels as if you are walking into a sauna? In other words, can you feel some sort of humidity in he air? hot cars are just that hot. In the experience I described above I could feel the inside was more than just hot, I could sense there was something else was going on, that let me to prod around the floor mats and the carpets using one of those blue shop paper towels to detect dampness. Sorry, I am trying to be as descriptive as I can to help out. At the ends of the day, water may not even be the issue.
GTTC55.00 |
02-12-2024, 02:43 PM | #12 | ||
Rep 94
Don't have sunroof. That's one thing I don't have to worry. |
02-12-2024, 04:46 PM | #13 |
Rep 1,096
Dont have a sunroof, now you peaked my interest even more.
02-12-2024, 08:06 PM | #14 |
Rep 84
Hey GTTC.
You could try to rinse/wash a few sections only to see if the odor appears. If water is getting in this could help isolate where it is getting in at. If the leak is minor, which it sounds like it is, you may not feel any dampness on the carpet. You'd have to pull it up to confirm the presence of water with a minor leak. Otherwise, the next best thing would be to check after a long rain shower. Maybe enough water collects to then feel it on the carpet. Does your windshield develop any moisture on the inside? I've never used them but they do make some moisture detection strips that you could try. Lastly, are you by chance running your ac or heater after washing the vehicle and/or parking it in the garage? Ralph Last edited by Ralph III; 02-12-2024 at 08:12 PM.. |
GTTC55.00 |
02-13-2024, 05:36 AM | #15 | |
Rep 94
Now. I do use a bit of decon spray on my wheels during wash to remove the break dust and it normally smells like crap so maybe somehow the smell finds its way in the car and all over the garage just long enough to be annoying. I have read some people having moisture collect in the doors by water coming down in between the window and the protective seal damaging the speakers. Everyone has given me great ideas so far the quick and easy signs have not turned up any problems. Will keep all in the loop on what I find. |
02-24-2024, 04:58 PM | #16 |
Rep 94
Well... I don't know if y'all noticed the door sills have rubber around it. I'm sure is to prevent what I found. It turned out my rear passenger side door sill "rubber seal" was bent just enough (probably my kids getting in and hitting it) to let small amount of water sip and collect in there, with time it created it's own world of microorganisms and it was what giving off the smell. It was just enough to be annoying and explains why it only happened when I washed the car. All cleaned out and good but probably have to get a new one at some point. At least the M5 logo still lights up 😂
Thank you all for your inputs |
tracer bullet2419.00 TVJ12003.00 |
