12-19-2020, 07:57 PM | #1 |
Rep 62
rear strut bar damage?
I noticed [link below] under my car today.
Wondering if something similar has ever happened to anyone else? it looks bent and really weird, not sure what caused it. How difficult is it to replace? Can it be done by 1 person? How critical is this part to the drivability and function of the car? is this the correct part? Please advise Thanks! View post on imgur.com |
12-19-2020, 09:09 PM | #4 |
3626
Rep 3,593
The jacking block has damage on the inside, almost as if the car slipped off a jack or lift, which then went through the underbody cladding. Alternatively driving over the end of a parking block or hitting road debris could also cause that sort of damage.
The tie bar doesn’t look very bent, if at all, but the cladding is definitely damaged. |
12-20-2020, 09:36 PM | #5 | |
Rep 62
Anyway, thanks! can anyone point to the part number to replace(or just check if it's what i have in the OP). Is it even worth replacing? and if so how easy? thx! |
01-02-2021, 11:51 AM | #6 |
Rep 62
Update: looks like it might be this part. Debating bothering to replace it
https://www.turnermotorsport.com/p-2...uine-bmw-part/ |
01-02-2021, 12:47 PM | #7 |
Rep 5,577
these diagrams and the site are excellent. I think someone on this forum posted this a while back
rear sub assembly: https://www.realoem.com/bmw/enUS/par...MW-M235i&mg=33 home page: https://www.realoem.com/bmw/enUS/par...-F22-BMW-M235i |
01-02-2021, 03:39 PM | #8 |
Rep 62
I concur!
I found the part i referenced here as it's the closest to what I think it is https://www.realoem.com/bmw/enUS/sho...diagId=51_8655 https://www.realoem.com/bmw/enUS/par...&q=51717367801 Last edited by oooseun; 01-02-2021 at 05:31 PM.. Reason: added actual part |
01-02-2021, 05:06 PM | #9 | |
Rep 5,577
If anything I'd put a new rubber lift block on to replace the torn one. |
01-02-2021, 05:32 PM | #10 |
Rep 62
01-02-2021, 07:11 PM | #11 |
Rep 5,577
You were getting rubbing ? Where at ?
I cannot tell much from the pictures. Is the part bent in a manner that a thin edge is aimed at the gas tank ? Because you need to make sure in an accident nothing pierces ! |
01-02-2021, 07:53 PM | #12 | |
Rep 62
This is why I'll attempt to use a wrench to bend it out of harms way |
