11-09-2016, 11:17 PM | #1 |
Rep 14
Parking sensors going off in the rain
The parking sensors on my M235i go off every time there is water or rain drops on them.
Makes them useless whenever I park in the rain, or after washing the car. The display shows red and there is just a continuous beep. Has anyone else experienced the same, or is it just my car for some reason? |
11-10-2016, 04:19 AM | #2 |
Rep 1,219
Drives: 2015 M235ix
It's just you. My 2015 M235 has never had a problem. However, my wife's X3 did show this problem in heavy rain once. She took it in to the dealer and they replaced the faulty sensor in question. You should do the same.
11-10-2016, 03:37 PM | #6 |
Rep 518
That has never happened to me, but then again SoCal never gets any rain worth mentioning about.
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
11-17-2016, 07:24 AM | #7 | |
Rep 14
When the sensors are switched on (in reverse gear or after the switch is pressed), they beep continuously whenever they are wet. They function normally when they are dry |
11-17-2016, 08:02 AM | #8 | |
Rep 5,577
Cause I think mine may beep in the wet in a manner that they don't in the dry, but the warning increments still function as they near an object. Never occurred to me to consider it a original problem, just that the rain reflects the light back to the sensor. |
11-22-2016, 03:58 AM | #9 |
Rep 891
Drives: None atm
I have this issue currently on my X1 its a MY2016 and right now there is a lot of shifting in the temperature in Sweden so if it rains during the morning hours then in the afternoon if drops below 0 it freezes and ice begins to form on the sensors causing them to go off like crazy,So right now i have to check so there is no ice on the sensors every time i go out to the car.
11-07-2018, 07:57 AM | #10 |
Rep 869
It just happened to my car... 3.5 years old 50,000km on it... it was pouring outside, as soon as I reversed... first the rear was beeping nonstop, and i got out thinking there's a pole behind me... nope... drove around the block, when to park and then the front sensors started beeping nonstop.
11-09-2018, 07:46 AM | #11 |
Rep 71
This happens on my 17 M240. I have a US mills work offset plate that I spent about 2 hours trying to mount so it didn’t trip sensor. But as soon as it rains it goes off. Would be very interested to hear how to fix this if others have a solution
Edit: oh and by “go off” I mean it’s the constant beeeeeeepppp as if you’re as close as you can get to something without hitting it. Full blast no escalation of beeps Last edited by EM240; 11-09-2018 at 08:14 AM.. |
11-09-2018, 08:26 AM | #12 |
Rep 5,577
This happens to me in the rain - I was thinking that water on the sensor defracts the beam and something like the tow hook mounted license plate is near enough to catch the sensor beam.
I wonder if you were to remove wax from the face of the sensor, that the wax beading wouldn’t be so high and refract the beam as much. |
11-09-2018, 09:47 AM | #13 | |
Rep 52
