2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Didn't backup SVT
      03-25-2017, 01:28 AM   #1
icycoldd
Drives: AW M240i
Didn't backup SVT
1st attempt at coding today and I forgot to backup SVT If I re-code everything back to stock and back up the SVT would that be equal to backing up an un modified SVT?
      03-26-2017, 11:16 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
SVT = Software Variant Table (ie listing of ECU's and their firmware)
It does not actually contain any FDL coding parameters.
You could code a hundred different parameters in 30 different ECU's and the SVT will be unchanged.
The only time it changes is after software/firmware is updated through flash programming.
RoundelM31836.50
      03-28-2017, 12:29 AM   #3
icycoldd
Drives: AW M240i
I see. Well, I went ahead and coded back to stock as I didn't have a backup of my .ncd files. Now I feel safe being coded.
      03-28-2017, 12:32 AM   #4
Almaretto
Almaretto's Avatar
2374
You are welcome to do that, but you also can always just VO code back to factory. I use ncd iterations with TM's NCD / CAFD tool to compare, but never use to reset ECU.
      03-28-2017, 11:12 PM   #5
icycoldd
Drives: AW M240i
I read up on TM's NCD tool and its features. If I want factory settings in the future (same as resetting ECU?) I can VO code like you said?
      03-28-2017, 11:30 PM   #6
Almaretto
Almaretto's Avatar
2374
Yes, though, I am confused by what you previously did when you "coded back to stock."
      03-28-2017, 11:46 PM   #7
icycoldd
Drives: AW M240i
I just un-did the coding I previously did without backing up the .ncd files.
      03-28-2017, 11:47 PM   #8
Almaretto
Almaretto's Avatar
2374
so you manually FDL-coded your vehicle back to stock?
      03-28-2017, 11:54 PM   #9
icycoldd
Drives: AW M240i
Here's what I did:
1. Coded 2 or 3 features. On this first round, only backed up FA.
2. Went back in and FDL coded those 2 or 3 features to stock.
3. Made sure the car was back to stock and backed up FA/SVT/.ncd files. I assumed those were the files as they came from factory.
4. With everything backed up, I re-coded the car with the desired changes.
      03-29-2017, 02:55 PM   #10
Almaretto
Almaretto's Avatar
2374
Here's what I did:
FA is like SVT. Unless changes written to VCM, they remain factory.
      03-29-2017, 08:39 PM   #11
icycoldd
Drives: AW M240i
Ah ok. I was under the impression FA and SVT were necessary to backup for FDL coding - as per TM's F30 FDL coding demonstration.
      03-29-2017, 10:53 PM   #12
Almaretto
Almaretto's Avatar
2374
SVT is good to backup unless you have CAFD_ID's memorized like me. That way, you know which NCD to load offline in FDL-Editor.
The FA, if unmodified, will match what is found in Decoded VIN. And, can always be pulled from VCM. I sometimes save them & load modified copies(eg, -6NH, +6NS) to do VO coding.
