2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Window sealant/cleaner/lubricant
      09-08-2014, 08:50 PM   #1
williewonkerz
williewonkerz's Avatar
2014 M235i  [0.00]
What do you use to lube the rubber around the door where the window meets it?
It's making a sort of sticky rubber noise.
      09-08-2014, 09:43 PM   #2
Macphisto
Macphisto's Avatar
1110
Drives: 2016 ///M2
Gummi Pflege
      09-09-2014, 01:17 AM   #3
one1er
one1er's Avatar
19
Drives: M235i (Yet to come)
I normally just wash the rubber with warm water and dish detergent...not sure if it's the best option, but it works for me! Cleans and degreases the rubber and doesn't seem to harm it at all
      09-09-2014, 06:40 AM   #4
overcoil
Drives: M235i 6spd
Glycerin (available at RiteAid) - I won't start applying till the weather gets to freezing wet conditions.
Or Zymol Seal
When it comes to UV protection I use a car cover
      09-09-2014, 08:40 AM   #5
williewonkerz
2014 M235i  [0.00]
Thanks a bunch guys. I expect I'll wash the rubber with soap, then apply glycerin.
I assumed that was the general care, but I was worried about getting anything gummy or drying out the rubber.
Never heard of Gummi Pflege, I'll have to look that up
Thanks!
      09-09-2014, 09:12 AM   #6
Jerich0
Love to Drive
197
Drives: X4 & M4
Use 3M rubber lubricant it comes in spray... Open the door and apply it... Leave door open for about 30 mins till it dries so that you dont stain a bit your window glass
      09-09-2014, 10:15 AM   #7
dwvcfii
Drives: 1998 328is, 2006 330ci ZHP
Gummi Pflege is the stuff to use. BMW used to stock it years ago but now you have to find it elsewhere. I got mine through Amazon.
Advice: You have absolutely no idea how freakin' expensive those door seals are (think many hundreds of $$$) so it's worth making seal care part of your regular regimen.
      09-10-2014, 11:40 AM   #8
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
Gummi Pflege, by all means. It's available thru Bavauto.com, & is probably best product. Comes in an applicator like liquid shoe polish years ago...when people tried to polish shoes the easy way.
It dries quickly, no mess and keeps seals soft. I have a Z4 also and that car has more rubber seals than the US Navy. GP is not expensive at all. Have had one bottle for years with 2-3 Bimmers around here. It does not take much.
      10-05-2014, 01:25 PM   #9
roteGeliebte
Drives: 2014 228i M Sport
Streaks on windows
Will Gummi Pflege help keep the seals from accumulating junk (or atleast make them easier to clean)? The inch or so of window drop down upon opening the door seems to make the window seal a magnet for collecting everything from pollen to tree sap which then streaks all over the window.
      10-06-2014, 02:49 PM   #10
zkeeper
zkeeper's Avatar
Haven't found over these years that GummF is any more prone to collect debris or whatever. It IS a topical, and soaks in to a degree. I don't use it to excess---but anything applied to rubber, could I guess allow "dusties" to sit and need cleaning. The GF wipes clean nicely...and I just apply it in fall and spring...not much more needed than that. But it cleans nicely...just have not seen the issue you mentioned though.
      10-22-2014, 08:34 AM   #11
williewonkerz
2014 M235i  [0.00]
bought some! thanks guys
Search this Thread:
