02-07-2020, 02:12 PM | #1 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
MHD Stage 2 Dyno
Made some dyno pulls today at Stage Fab & Performance. Results are 347 WHP & 396 ft-lbs torque. Running MHD OTS Stage 2 - 93 OCT.
5" VRSF intercooler and custom pro-tune are next up on the list
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
02-11-2020, 08:23 AM | #2 |
Rep 2
no offense but those numbers are very low. It makes sense now why I am beating all my mhd tuned m235i friends.. I am running bm3 stage 2 e30 and i absolutely walk them. Most people pushing 400+whp and 450+ wheel torque with bm3
02-11-2020, 08:48 AM | #3 |
Rep 237
What do you think of MHD user interface and features? Seems like they have the same core features except mhd has support for XHP flashed transmissions and an officially sanctioned/branded wifi adapter. It's also not cloud reliant so have you figured out how to back up your tunes manually?
Cary Jordan also tunes on both so what ots maps are putting out doesn't really matter if your planning on doing a custom etune anyway |
02-11-2020, 09:03 AM | #4 | |
553
Rep 802
Definitely wasn't planning on just using OTS maps. I'll have Bob at Stage Fab custom tune it after I get the intercooler.
02-11-2020, 11:40 AM | #5 | |
Rep 4,133
02-11-2020, 01:43 PM | #6 |
553
Rep 802
Hell yea that's good to hear. What are you putting to the wheels?
02-11-2020, 03:33 PM | #7 | |
Rep 4,133
I’m about to freshen the car up and get a baseline and then do a new pump and reflash the tune. It pulled like maddd! |
02-11-2020, 07:37 PM | #8 | ||
553
Rep 802
02-11-2020, 08:41 PM | #9 |
Rep 4,133
02-12-2020, 08:31 AM | #10 | |
553
Rep 802
I'm at 84,000 now.
02-12-2020, 09:11 AM | #11 |
Rep 2,214
Get a Carey tune post IC, tell him to make it as good as possible without starving the fuel system. Usually 390-410whp before running into fuel issues on these engines. The IC will go a long way for making peak power, too.
02-12-2020, 10:03 AM | #12 | |
Rep 4,133
Bob even offered to set the targets lower (which would mean less fuel, and less power) I declined because the underlying reason needs to be corrected first. I can’t apeak for Carey, but I’ve seen Bob’s dyno tunes make 400whp on pump. |
02-12-2020, 03:30 PM | #13 | |
Rep 2,214
I'm not suggesting what you're saying isn't factual, but I am saying that if you can't break 400whp on the stock fuel pump, then you have a sole hardware issue that can be resolved by replacing/upgrading the pump.
lootman122111.50 |
02-13-2020, 10:02 AM | #14 | |
Rep 4,133
That was the part I disagreed with. Last edited by AmuroRay; 02-13-2020 at 09:34 PM.. Reason: grammar |
whoismorggan553.00 |
02-13-2020, 10:31 AM | #15 | |
Rep 2,214
02-13-2020, 12:16 PM | #16 | |
Rep 5,369
f20two - The numbers look solid and safe. You're M235 is making what a stock 2020 Supra is making. Those cars go mid to low 12s and weigh 100lbs less. Your M235 would be right on their tail.
03-02-2020, 03:51 PM | #17 |
553
Rep 802
Also note these numbers were in SAE not STD
03-03-2020, 07:07 AM | #18 | |
Rep 208
I guess I will have to get a custom tune done, something that doesn't win dyno contests but keeps the engine healthy.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
03-04-2020, 12:15 AM | #19 | |
Rep 373
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
