03-21-2016, 06:52 PM | #1 |
Rep 225
Removing front bumper to install Charge pipes
Does anyone have an installation guide or write some tips for installing charge pipes? I got mine second hand, so no instructions on how to take off the front bumper, and whatever else is needed. Thanks in advance!
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
03-21-2016, 08:50 PM | #2 |
Rep 444
http://f30.bimmerpost.com/forums/sho....php?t=1151005
You can say thanks to Mike@N54 tuning. The guide says its for a 335i but it will be basically the same thing.
Quickest Stock Turbo F8x In The World
03-21-2016, 09:01 PM | #3 |
Rep 179
Remove the under panel to gain access to the lower charge pipe retaining clip. Disconnect from charge air cooler. Upper part of motor, I've found it easier to remove the plastic trim that covers your electrical connectors towards the drivers bulk head covers (1 t20 screw) and remove the throttle body...of course after disconnecting the charge pipe from it. After than its just a matter of maneuvering it out. It's a little tough cause of all the crap in the way but that's how it's done.
03-21-2016, 09:28 PM | #4 |
Rep 225
Thanks guys! That pdf is a godsend!
