01-22-2015, 11:54 AM | #1 |
Rep 809
Anyone with ///M Performance Big Brake System?
The OEM brakes that came with my M235i are not bad, but I feel like they could be better. So I'm considering upgrading to the M Performance Brake System, part number 34112221445 (red calipers).
Anybody here that has moved to these brakes? Comments? Thanks!!! |
01-22-2015, 01:07 PM | #2 |
Rep 5,262
the OEM brakes are exactly the same just painted red... only difference is the rotors which are dimpled and slotted and i believe slightly bigger diametter...
That's why you don't see anybody getting them.. to me the M perf brakes are not worth it.... you get 90% sames parts with the OEM |
01-22-2015, 01:22 PM | #3 | |
Rep 809
01-22-2015, 04:01 PM | #4 |
Rep 5,262
01-22-2015, 04:08 PM | #5 |
Rep 809
LOL well that sound like a good idea, but, to save the part of the ///M emblem on the calipers, would require a very good paint job, which I don't think I can find in my country
01-22-2015, 05:20 PM | #8 |
Rep 5,262
you can just always just get the rotors and keep the blue brakes as is... there is no performance difference between the blue and the red
01-22-2015, 05:39 PM | #9 |
BD_e92
358
Rep 1,748
01-22-2015, 06:12 PM | #10 |
Rep 5,262
01-22-2015, 07:53 PM | #11 |
Rep 171
Yup the M235i comes standard with M brakes. Same kit you have on your car now.
Get a 6 piston brembo kit with 2 piece rotors. Just do the front, that should satisfy you |
01-23-2015, 06:38 AM | #12 | |
Rep 4,516
MPPK rotors are 370mm diameter so std blue calipers will not fit as they are to suit std rotor 340mm dia.
Current '22 X3M LCI.. |
01-23-2015, 08:32 AM | #13 |
Rep 809
01-23-2015, 11:30 AM | #14 |
Rep 199
Try different pads before buying an all new brake setup. You'll most likely be happier and so will your wallet. Only real reason to even consider a brake system overhaul is if you're finding them insufficient on a track or you have money to waste.
01-23-2015, 11:47 AM | #15 |
Rep 809
Very nice point man, thank you.
01-23-2015, 12:44 PM | #16 |
Rep 845
01-23-2015, 03:27 PM | #18 | |
Rep 5,262
http://www.rmeuropean.com/Part-Numbe..._E095124A.aspx http://www.ecstuning.com/Search/Braking/ES2568631/ http://www.2addicts.com/forums/attac...0&d=1396284603 M Performance Brake Disc - Front Dimpled and Slotted rotor, order 2 Comes w/ M Perf Brake Kit or can be installed on 2NH M Sport Brakes Last edited by pikcachu; 01-23-2015 at 03:38 PM.. |
01-23-2015, 04:42 PM | #19 |
Rep 199
Fluid change will only help if you're boiling your brake fluid under extreme braking conditions where the brakes do not have sufficient time to cool before being used heavily (ie track events). It will not make any difference in any any other scenario.
01-23-2015, 04:43 PM | #20 |
Rep 845
That is true. I sort of figured if he wanted a brake upgrade, it was for track use. My mistake.
01-23-2015, 05:14 PM | #21 | |
Rep 4,516
stock size [345mm x 24mm thk] but D&S rear disc part # 34206797598 Above part numbers are those quoted in the relevant yellow boxes maybe dimple and slotted rotors (same size as stock m235i rotors 340mm F and 345mm R) for lower powered f30 msport/MPPK upgrade. M235i MPPK use same size rear rotors but fronts are larger, 370mm rotors. Red/yellow/orange front calipers aren't the same as stock blue calipers ! |
