11-07-2018, 09:45 AM | #1 |
Rep 11
Storing car for 3 months
Work is unfortunately sending me to the Philippines for 3 months after the holidays. I asked the service advisor at my local BMW dealership what I should do to the car to prep it for the 3 months of sitting in the garage and he said just plug in a Battery Tender and don't worry about it.
Anything else you guys would recommend? I bought some fuel stabilizer I plan to also put in the tank before I leave. |
11-07-2018, 11:40 AM | #3 |
Rep 148
inflate tires to max as indicated on sidewall. Reduce to proper psi before you drive it.
2016 M235i convertible
2016 Mercedes AMG GTS 1966 Corvette roadster |
11-07-2018, 04:25 PM | #4 |
Just Copacetic!
177
Rep 616
I use the CTEK 8-step automatic charger to keep our 2001 X5 battery topped up as we only use the car occasionally to transport larger, heavier things. The last battery lasted over 12 years before needing to be replaced by using this automatic charger.
'01 X5 3.0 AlpWhite
11-07-2018, 04:57 PM | #5 |
Rep 6,028
+1 for CTEK battery tender. Also, check Amazon for a set of 4 tire saver cradles...you just drive up onto them and the tire rests on the curved surface. Add Stabil to a half tank, fill the rest of the way and drive at least 5 minutes before final shut down. Tires to max cold pressure (when you check them cold!), per sidewall information.
Unicorn123186.50 N757AF5.00 |
11-07-2018, 09:23 PM | #6 |
Rep 160
If it was me I would just top up the tank - 3 months isn't really THAT long, and maybe hook the battery up to a tender. When I put my motorcycle to bed for the winter I would fill up the tank, add fuel stabilizer, do an oil change and put the battery on a tender every month or two. Served me while for 10 years...started every spring on the first try.
11-08-2018, 03:26 AM | #7 |
388
Rep 889
+1 on filling tank and maxing tires. Beyond that and the battery tender, it should be OK. Try to store it where the ceiling won't fall on it, that turns out to be bad ...
11-08-2018, 10:29 AM | #8 |
Rep 11
I will definitely inflate the tires and look into the tire cradles - good suggestion. As for the CTEK battery tender, I already have an old Battery Tender (probably 10 years old). Is that fine to use, or should I really get the CTEK? Thanks
11-08-2018, 10:32 AM | #9 | |
Rep 6,028
EDIT: Just found this: https://www.bmwblog.com/2016/01/28/b...ttery-charger/ Probably better price on Amazon under CTEK brand name.
11-08-2018, 10:47 AM | #10 | |
Rep 5,577
11-08-2018, 11:42 AM | #12 | |
Rep 3,496
I've used it once to bring my battery up from 12.26V to 12.95V. That wasn't a challenging job for the CTEK, of course, but it did the job just fine.
11-08-2018, 01:23 PM | #13 |
Rep 375
My sister leaves her car parked for weeks at a shot. She parks it on some 1x6 lumber. The softness of the wood makes a world of difference with flat spots.
The other thing I'd say is don't have anyone start it. Just let it be. |
11-08-2018, 01:44 PM | #14 |
Rep 6,028
Sure....wood, carpet, anything soft will be a bit better than concrete, but the effect of something such as these relatively inexpensive Bunkerwall tire savers on Amazon is quite clear.
BEM-S44515.50 |
11-08-2018, 02:15 PM | #15 |
Rep 8,942
Do you have any experience with those or something similar? I'd much prefer that versus jack stands for the winter. You still need to inflate to max or not?
11-08-2018, 02:28 PM | #16 |
Rep 6,028
I bought a few sets of exactly those, as they were the best deal on Amazon. Some others were oddly and ridiculously expensive. I've used them for a couple of years with perfect results with the cars left behind when we "snowbird". It is helpful to put some kind of a mat below them to stop skidding during the drive-on, if you have a smooth concrete floor, but not much of a hassle. I still do inflate to the cold max shown on the sidewall, but I'm probably a bit more cautious/protective than most or perhaps necessary.
BEM-S44515.50 |
11-08-2018, 03:10 PM | #17 | |
Rep 8,942
Think I may get the Race Ramps Flat Stoppers they're quite a bit wider than the yellow ones and I've had good experience with their products in the past. They are also sticky so no need to worry about skidding on the floor. $200 vs $50 so there's that, but for something that will last forever not horrible. EDIT: After rebate the RR ones are only $180 on Auto Anything.
11-11-2018, 11:31 PM | #18 |
Rep 2,527
Drives: 2011 328i Wagon
Now that I have become a snowbird, my cars in Maine, including my BMW sit for months and months at a time. I fill the tanks, and put them on battery tenders, and that is it. I've actually been parking my Spitfire for the winter that way for 23 years, never a problem. The tires do flatspot, but it goes away in 10 minutes of driving.
11-13-2018, 07:12 AM | #19 |
Rep 26
Don't forget the mice !!
I also spray mice deterrent around the ports of entry. I once found a dead mouse stuck between the lower door jam and rocker.
'14 M235i EB Coupe
'11 135i Convert DCT (traded) '03 and '97 540iA Sport (retired) '97 Vette Coupe 6 sp (sold) '74 Jensen Healey (MIA) " No law about how long it takes to go the speed limit " |
11-13-2018, 07:48 AM | #20 |
Rep 3,496
They will also build nests in your intakes. We got cats to deal with the problem.
12-18-2018, 06:44 AM | #21 | |
Rep 914
12-18-2018, 07:26 AM | #22 |
Rep 8,942
I am very interested to see how the Flatstoppers work this is my first winter with them. I also tried the BMW cover but it was crap, got the fleeced satin indoor one from Car Cover World and it is 100x better (and less money even).
