08-27-2016, 05:17 PM | #23 | |
Rep 4,518
Drop is about 10mm all round and Spring rates up abt 20% front and 10% rear
Current '22 X3M LCI.. |
08-28-2016, 01:33 PM | #24 |
Rep 566
08-28-2016, 11:56 PM | #25 |
Rep 4,518
Not sure 3rd hand info so not gospel - best check direct with bmw to confirm
08-29-2016, 02:32 PM | #26 |
Rep 765
Is this the kit for the 228? I thought the M235 comes stock with the 10mm drop over the 228i models due to the springs / bump stops.
08-29-2016, 06:21 PM | #27 |
Rep 4,518
No Bmw do an MP upgrade for m235i adaptive
09-01-2016, 07:50 PM | #29 |
Rep 4,518
http://www.bmw.de/de/topics/service-...lekatalog.html
Open up the link U/name bmwetk1 P/word Eu111111 Find Spring part numbers for your cars configuration
09-06-2016, 09:41 AM | #30 | |
Rep 85
So as near as I can tell there is no upgrade on springs. You simply configure to options on the car. Sunroof etc. |
09-06-2016, 10:05 AM | #31 |
Rep 4,518
You should see MP springs as option to be ticked so a spring numbers suit yr cars options.
09-06-2016, 11:13 AM | #32 | |
Rep 85
Front 31 33 6 680 630 Rear 31 53 6 860 619 These come up as 435i springs. I wasn't able to generate any further data. I can see the 4 series springs having a firmer rate. I kinda doubt any drop. |
12-13-2017, 07:43 PM | #33 | |
Dustin335i
50
Rep 80
Drives: Mineral Grey M235i M/T
Thanks for your reply- |
12-13-2017, 11:28 PM | #34 |
Rep 1,161
yes very useful info.
I've just ordered the blistein b12 pro kit for my m235 red non adaptive. this is the B8 dampers/shocks with the eibach springs. so think it's worth getting the BMW OEM bump stops??
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
12-18-2017, 10:04 PM | #35 | |
Rep 566
The "dinan" ones you can source from BMW or some other place for a fraction of their dinan price, the part numbers are: 31331138814 front 33536762722 rear The ones I'd prefer for the front are 31332225377. I've never experienced any problems with the rear ones but some people use p/n 33531138109 (don't know if they're any different or better than the "dinan" ones). Last edited by x233; 12-19-2017 at 08:25 AM.. |
12-18-2017, 10:19 PM | #36 | |
Rep 566
The B12 kit is fine. It really is a combo of B8 shocks and Eibach springs, perhaps they even provide bumpstops for the rear shocks. I generally like B12 on other vehicles and used them several times in the past on other cars. They are fine in the summer but may be a problem in winter. I had them for about 2 days on my m235 xdrive but didn't like them compared to the stock adaptive shocks and the same Eibach springs. Reason: I installed them in winter when there was a lot of snow, ice and bumps on the roads. B8 shocks have a rather stiff rebound setting from factory and a short travel (up to 5 cm shorter if I remember correctly). As a result the car felt quite jumpy and skipping a lot in those wintery conditions. You'd need perfect roads for them. Changed them back real quick for the adaptive shocks but kept the Eibach springs and like that combo a lot. Still use it. I think Bilstein B6 shocks would work better in those conditions because they are essentially the same inverted monotube design and rebound settings as B8 but they are taller (this wouldn't effect the lowering because that is effected by the springs) and have significantly more shock travel (this would probably help in the conditions described above). But I didn't have a chance to try B6 shocks on my m235. Last edited by x233; 12-19-2017 at 08:26 AM.. |
Hasser446.50 |
12-19-2017, 02:02 AM | #37 | ||
Rep 1,161
I'll wait and see what arrives in the kit before ordering the bump stops.
2014 M5
12-19-2017, 08:30 PM | #38 |
Rep 5,372
FYI - The "bump stops" are actually an integral part of the spring setup and specifically designed to work with the spring, in a sense creating a progressive spring rate as the spring reaches it's full compression stroke. They are not stops.
Hasser446.50 |
