02-14-2019, 08:37 AM | #1 |
Rep 111
A puzzling stutter
So my 235 xi has about 80000 some odd miles and has always had its the regular maintenance performed.
if say i'm climbing from 40-70 in a higher gear without flooring it, the acceleration seems to have bumps in it as the engine climbs. I don't hear wheel slip, traction control doesn't come on, there's no noticeable change in rev sound, but there is a noticeable stutter in the acceleration. that is about as clear as I can describe it and I'm genuinely puzzled what this may be and if I need to take it in to have it checked. Has anyone else on here experience this before? Thanks! |
02-14-2019, 09:36 AM | #2 | |
Rep 6,031
02-14-2019, 10:45 AM | #3 | |
Rep 823
02-14-2019, 11:19 AM | #4 | |
Rep 6,031
02-14-2019, 11:53 AM | #5 |
Rep 111
thanks all. A bit more detail.
Its an automatic and its definitely not lugging as I've accidentally done that before in a parking lot. This can pretty much happen in any gear but more noticeable past 2nd and rpm's are typically already above 2.5k. no CELs, no warnings, nothing. Happens with all sorts of traction control settings and with the wheel straight, I believe I've even replicated with full off although being winter here and on snow tires (17 inchers), its been a while since I've done that. If there's any other type of information I can provide or things to try, I will be more than glad to. |
02-14-2019, 12:17 PM | #6 |
Rep 823
Initially I thought it could be fuel or air related but when you said it only happens in the 40-70 range, it threw a curve ball. You're up there in miles so your plugs and/or coils could possibly be a cause unless you've already changed them. If you've never changed your plugs, I'd personally start there to see if it makes a difference since you should be changing them soon anyway. Is your car tuned? Is it idling ok, no misfires or rough idle? Worse case scenario, take the car in as Sportstick had mentioned.
02-14-2019, 12:31 PM | #7 | |
Rep 6,031
One simple thing to try is when you feel that happening on the highway, immediately change the mode (not just TC on/off) from whatever it is to something else...Comfort to Sport...Sport to Comfort. Any of those. If the symptoms go away, it should start to help with a diagnosis, although I still think you are dealership-bound.
02-14-2019, 12:36 PM | #8 |
Rep 1,931
80mi, wastegate.... turbo next.
try changing your tmap sensors first...
www.nybmwcca.org
02-14-2019, 01:10 PM | #9 | ||
Rep 111
is this a simple change/cheap change? |
02-14-2019, 01:25 PM | #10 | |
Rep 823
02-14-2019, 02:14 PM | #11 | |
Rep 111
02-14-2019, 02:33 PM | #12 | ||
Rep 351
02-14-2019, 05:26 PM | #13 |
Rep 111
So after work, I decided to give it a spirited drive home for half and regular the other half and this is what i observed...
In DSC off, sport transmission, it is less noticable, and when i do it's usually as I'm building speed with the engine between 2 and 3ish thousand rpm. Passed that and all the way to red line, there's barely any if at all. In comfort, standard transmission mode, it's more noticeable as it spends more time in lower revs, that 2 to 4 window. ... Guess i have to drive around like my ass is on fire now |
02-15-2019, 11:30 AM | #14 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You might want to check if it's related to your transfer case. How's the wear on the front tires compared to the rear ones? I believe there's a fuse you can pull to disable/disengage the transfer case clutches (it will produce a CEL while unplugged).
See our thread about transfer case failures (and failure modes). |
02-15-2019, 01:59 PM | #15 | |
Rep 111
Tags |
acceleration, jutter, slip, stutter |
