2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Focal Speaker Question
      04-13-2018, 09:15 PM   #1
VPB74
VPB74's Avatar
38
Drives: 2018 M240i
I'm replacing the HIFI amp with a Bimmertech amp. If I go with the Focal IFBMW-C speakers in the doors, what is a good speaker to use on the rear deck? Also, should l replace the stock sub with the IFBMW-subs? This set up will be a bit more than the Bavsound Stage 1 and Ghost subs, is it worth it?
      04-14-2018, 09:02 AM   #2
reward72
Drives: 2018 M240xi
Put a pair of ISC100. They are essentially the same as the IFBMW-C just a little thicker and much lower priced. They wouldn’t fit the doors, thus why you did need the IFBMW-C, but for the rear deck they are perfect.
I have them in my car. Sound great!
      04-16-2018, 12:18 PM   #3
robman23
Drives: M235
There is a ton of information on Focal speakers on this forum. I have the 100s in my doors. They do require a spacer ($10). I would recommend listening before deciding on which one is best for you. Also, the rear deck speakers are almost insignificant. You might replace the doors speakers, disconnect the center channel and replace the subs before replacing the rears.
Viffermike1753.00
      12-31-2018, 03:32 AM   #4
jagged
Drives: M2 Comp M/T
Hi, thanks for the feedback.
For a basic upgrade, do you recommend Focal IFBMW-S and replace 1 or both underseat subs with something like Focal IFBMW-SUBV2?
Then just keep rear speakers stock?
      01-10-2019, 12:12 PM   #5
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
I am curious to know how the Focal subs compare to the Bav sound subs as well!
