06-02-2015, 07:05 PM | #45 | |
Rep 5,262
06-02-2015, 07:23 PM | #46 |
520
Rep 1,026
Drives: 2018 Shelby GT350
Precisely, one has the gauge the risk versus reward, you know simple things such as intakes and exhausts(catbacks or axlebacks) are minor things, but keep in mind on a grand scale that it's a combination of things that add up to what potentially happened to the OP. I believe adding different types of fuel has a lot to do with what happened as well(i.e. e85, race)...
Instagram: cboy1
06-02-2015, 07:34 PM | #47 |
520
Rep 1,026
Wouldn't you love to catch em all.
Instagram: cboy1
06-02-2015, 07:44 PM | #48 | |
Rep 757
06-02-2015, 07:45 PM | #49 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Seems like it could generate business for your shop. If you're an enthusiast and have knowledge to help the community decide which way to go, that's a plus. Having knowledge and not sharing it in this forum kind of detracts from your earlier statement of being a 'mod' friendly shop Charlie.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
06-02-2015, 07:47 PM | #50 | |
Rep 3,258
Yep..its a hatchback disguised as a 4-door sedan. Clever. Love my car..although today wife.com hijacked it to take it to work today lol. The visual clues between the 3 and the 4 are far enough apart that I really like the 4 . Now back to the topic at hand........
25% 3M Tint| |
06-02-2015, 07:52 PM | #51 |
520
Rep 1,026
Well keep in mind going back to the point where these engines were not designed to tolerate such high levels of octane.
Instagram: cboy1
06-02-2015, 07:58 PM | #52 | |
Rep 3,258
That being said...I don't think 100 octane is necessarily unless you are going the upgraded turbo etc route
25% 3M Tint| |
06-02-2015, 10:57 PM | #54 | |
Rep 757
I'm wondering however if you use the tune to take advantage of the 100 octane, and you get the extra power. Where is that extra power coming from? Increased boost? (potentially harmful) or Just better burn in the cylinders. (not harmful?) Or does it not matter and the extra power generated can be considered too much for the N20? |
06-02-2015, 11:38 PM | #56 | ||
384
Rep 548
06-02-2015, 11:47 PM | #57 |
Rep 757
what about 100 with jb stage 1?
06-03-2015, 03:40 AM | #58 |
Rep 1,503
You shouldn't be running 100 octane with the stage 1 because you won't see any gains. I don't think the tune can adjust for the fuel.
On the topic of the the stage 1, does it do the same thing as the stage 2 jb4 in tricking the ECU that it is running stock boost? |
06-03-2015, 08:47 AM | #59 | |
Rep 757
Wondering that myself. |
06-03-2015, 09:03 AM | #60 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Are people seriously thinking that if you put 100 octane into an otherwise stock car, you are going to blow your motor? LOL.
Higher octane just diminishes the chances of detonation with a higher compression motor, which is very beneficial when you are pushing more air and boost and consequently asking to generate more power. A stock ECU for a street driven car will be able to 'extract' more power correspondingly, to a point.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-03-2015, 09:13 AM | #61 | |
Rep 757
There's a few questions circulating but we are wondering if 100 octane is safe with stage 1 or jb4. |
06-03-2015, 09:39 AM | #62 | |
Rep 233
if using a stage 1, or jb4 map 1, pump vs 100 oct is the question. then the 100oct is safer than the pump fuel. what is dangerous is using map 6, or any higher boost maps. the danger here is not caused by the 100oct, its caused by the added clyinder pressures due to the high boost. |
06-03-2015, 09:47 AM | #63 |
Rep 349
Higher octane allows you to make more power.
It does not give you more power by itself. Assuming the tunes are static and the ECU does not produce more power given a higher octane, all the higher octane will do is increase your detonation threshold. Did the OP run e85? Or was it just mixed with regular fuel? If so, adding e85 without a proper tune will make you run lean. The characteristics of e85 are so forgiving when tuning on it and the car just keeps making power the more you push it, but results can be catastrophic once you switch back to regular gas using an e85 tune. |
06-03-2015, 10:41 AM | #64 | |
Rep 233
crude, yes. effective, maybe. never tried it. |
06-03-2015, 11:17 AM | #65 |
384
Rep 548
I rarely ran e85 as the car ran horribly at wide open throttle on any amount of e85. The electronic wastegate N20 engines are notorious for disliking e85 fuel mixtures plus it was a pain creating a 70/30 mixture of pump gas and e85 at the gas station.
06-03-2015, 01:23 PM | #66 |
Rep 114
How did the car feel when it happened? did it go into limp mode?
Also, did your car feel any different the few days before it happened? Best of luck on your next steps |
