02-21-2019, 06:44 PM | #23 | ||
Rep 95
02-21-2019, 06:48 PM | #24 |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
Easiest solution, buy a Cayman.
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
02-21-2019, 07:51 PM | #25 |
Rep 3,539
Drives: 328d Wagon, M2 Comp, i4 eD35
K-Mac has bushings for the LCA/wishbone and tension strut arms that allow you to adjust camber/caster on xDrive cars. I have both installed on my vehicle right now (just installed the caster bushings this past weekend). Here's the thread I started on the camber bushing (also can be used in RWD models).
The camber bushing doesn't significantly improve steering feel, but the caster bushing significantly adds to the feel and responsiveness. You can feel the road more through the wheel and it also feels like you're more connected with the car. The latency between turning the wheel and the car responding also feels reduced. The downside is that NVH is also increased due to the more solid bushing vs the rubber and fluid-filled OE bushing. The noise increase is mostly low frequency, no clunking or ticking noises. Increasing the negative camber on xDrive cars also increases the caster. When I maxed out my camber with the K-Mac bushings, my caster went to 8.55deg and 7.95deg. at 8.55deg I was just about rubbing at full steering lock. After I installed the tension strut caster bushings I set both sides to 8deg. |
02-22-2019, 12:33 AM | #26 | |
3626
Rep 3,592
The scrub radius actually has a complex effect on steering feel, as the tyre loading changes the effective centre of the contact patch moves, so the dynamic scrub radius changes too. With a modern car the static scrub radius is often about 20mm negative (SAI hits the ground outside the contact patch centre) to give good stability with variable friction under each front tyre. Zero static scrub radius should be avoided, as the dynamic scrub radius tends to switch between positive and negative, contributing to vague steering feel. When wheel offset is changed there is a risk that scrub radius can be changed in an unexpected way. Last edited by aerobod; 02-22-2019 at 10:55 AM.. Reason: update info |
02-22-2019, 08:01 AM | #27 |
Rep 6,029
My son had one and both he and I found it a real PITA to shoehorn in and climb out of that bodystyle. Once in, yes, it's excellent in so many ways, but we're tall and ingress/egress was more of a problem than he thought it would be when he first got it. It left after about a year and when he would offer to let me drive it, after the first few times, the thrill wasn't worth the contortions. 2 Series wins this one hands-down!
02-22-2019, 09:18 AM | #28 | |
Rep 48
I will have BMW look at it as I am due for the recall fix on the car and hopefully that is the issue. I know people say electric steering is vague in general and good enough. The rack on my Mercedes is also electric and it is 10000000x better than what the 2 provides. I also never hear anyone complain about the M2 setup so that is also why I asked what can be done to become more like the M2 without buying one. Thanks again all! |
02-22-2019, 09:21 AM | #29 |
Rep 48
I already had and tracked a Cayman. I have a little girl that likes cars and she is not quite ready to sit in the front seat. I traded that in for a 911, which was my dream car. In one year I put 25k miles on it and 22 track days. Sadly, I had a ton of home repairs due and the smart financial decision was to dump the car.
Now of course 911s are even more expensive than ever and I just cannot justify spending that much money on a car right now. My race car already sucks up some serious money... |
RotorOver295.50 |
02-22-2019, 06:11 PM | #30 | |
Rep 95
how much NVH would you say you get, ballpark relative to camber plates 20%? 50%? How's the durability so far? Where did you purchase the bushings? |
02-23-2019, 12:40 AM | #31 | |
Rep 3,539
I've only had them on a week so I can't say too much about their durability, but the bushings have a pretty solid looking design. I'm not worried about their longevity. I'll be taking them on some dirt/gravel BLM roads this weekend. I purchased these direct from Kevin at K-Mac as I've been beta testing/giving feedback on the design and this is the 3rd iteration. I'd wait a bit to see if he iterates on my latest feedback. As they stand now they're great for a track car, but might be a bit too rigid for a street car. |
01-10-2021, 08:20 AM | #32 |
Rep 24
Reviving a dead thread but wanted to comment on all the great wisdom here. I just picked up a used M235i that suffers from some on-center steering deadness which seems to be a common problem with these cars. I've read through countless threads related to the issue and seems like a combination of 2 problems (at least for my specific car):
1. The on-center vagueness is a problem from the factory due to the mushy tension strut bushings and lack of camber from the factory. Sounds like upgrading to the Turner motorsports monoball fixes that along with the M2/M4 LCA's for a bit more negative camber without having to install camber plates. 2. This problem only gets worse with age as bushings wear but might also be from the steering rack's "thrust" thing (I guess it's like a preloader for the rack) that can be upgraded with: https://www.turnermotorsport.com/p-5...ust-piece-afs/ |
01-10-2021, 08:59 AM | #33 | |
Rep 3,496
01-10-2021, 09:25 AM | #34 | |
Rep 24
01-10-2021, 04:28 PM | #35 |
Rep 615
Interesting thread. Thanks for reviving it as it predates my ownership. My biggest complaint about our 2016 228i is the horrible steering feel. It is horribly over-boosted and vague. Like a 1975 Cadillac. So if I understand all I've read here, the real issue is that it has an electric steering rack. Going back to the OP... when I switched from summer rubber to winter, it is so over-boosted I could hardly feel the difference in normal driving.
01-10-2021, 04:46 PM | #36 |
Rep 19
I had the same problem with my 230i, and was really helped by this thread. I installed the https://www.turnermotorsport.com/p-5...m-upgrade-kit/, but went with original M2 parts. These really helped. But the real game changer was when I swapped the original EDC dampening for a Bilstein B16/PSS10 kit (without EDC). This really changed the car into a beast, the steering is now fantastic and responsive, and the centering is great. I have the Variable Sport Steering rack on mine, by the way, I think the problem is bigger with this rack. (I also have a 118i with the normal steering rack, and the steering is much better than my 230i was originally)
01-28-2021, 08:36 PM | #38 | |
Rep 6
Curious about the B16/PSS10 setup and ride quality. How does it compare to the three EDC modes, Comfort-Normal-Sport? Knowing that the Bilstein kit is adjustable, what did you find were the best settings front and rear? |
01-30-2021, 09:38 AM | #39 | |
Rep 24
I finally got my order of the M3/M4 LCAs and the Turner monoball TAs along with the thrust repair kit. I’m hoping this trio is enough to liven up the front end without needing to go coilovers. |
