09-29-2020, 06:13 PM | #1 |
Rep 611
Brembo ceramic pads cheap
Long story short: installed M Performance brakes, had gray sliders, dust amount increased 1000%, was going to use the M Performance pads for at least a year but I can't stand it so I started looking for low dust alternative.
Found several posts mentioning the Brembo Ceramics, went to Brembo site to see vendors, they have a Brembo online store. Located the ones to fit and was looking at them for a few minutes and got a pop up code for 10% off (CHECKOUT10). I got a full set of front and rear Brembo ceramic pads for $136.33 shipped. Bought them Sunday and received them today. These are the same pads that fit the blue M Sport brakes. Just thought I should pass the info on. |
09-30-2020, 07:45 AM | #3 |
Rep 558
I got mine from Rock Auto for $132 delivered.
I haven't installed them yet because I haven't decided what I want to do about the rotors, which look fine: Use as is? The new pads may not 'bed' properly, resulting in reduced effectiveness and/or noise. Resurface (cut) them? I've heard varying opinions on this. Replace them? Expensive and maybe unnecessary. Rollo` , what did you do with your 'used' rotors and how were the results?
09-30-2020, 12:13 PM | #4 |
3621
Rep 3,591
The compound rotors used on the M240 & M235 (aluminium hat / cast iron rotor) should not be recut due to the lateral flex between the riveted hat and rotor not likely to give a precise enough location when cutting to stay within 0.01mm run-out tolerances. This is indicated in the BMW TIS: https://www.newtis.info/tisv2/a/en/f...rakes/Gg0mEIUE. Other single piece rotors on the 228 and 230 can be machined without a problem, as per the instructions in the TIS.
09-30-2020, 12:41 PM | #5 | |
Rep 558
In the past, I would never put new pads on a 'used' (shiny) rotor, because I was concerned about the pads not bedding properly. But, maybe I was just being over cautious. What's your thoughts/experiences on putting the new pads on 'used' rotors, assuming of course that they are above minimum spec and do not have any big grooves/ridges?
09-30-2020, 02:40 PM | #6 | |
3621
Rep 3,591
I've had as little as one set of pads per rotor on a couple of BMWs and as many as 3 sets of pads on one BMW and 2 BMWs with 2 sets per rotor, all with no issues when I've just measured the rotor thickness before changing the pads and kept to the spec. |
PeterWT252.50 |
09-30-2020, 02:42 PM | #7 | ||
Rep 504
E46 -> E90 -> F30 -> F23
PeterWT252.50 |
09-30-2020, 03:18 PM | #8 | |
Rep 558
09-30-2020, 05:16 PM | #9 | |
Rep 3,496
https://www.newtis.info/tisv2/a/en/f...kes/1VnXuTBEfk? The reason I ask is I'm reading that our "M vehicles" (Brembo brakes) are to have their rotors replaced at 1.6mm of wear, while non-M vehicles (base brakes) will tolerate 2.4mm of wear. Perhaps you can explain this, too: in the case of non-M vehicles, why does BMW require a wear reserve of 0.8+mm before replacing pads? Thanks.
09-30-2020, 07:43 PM | #10 |
Rep 611
I thought I was on the brembo official web site but was instead on brembostoreusa.com according to my invoice. Sorry about the misinformation. (turns out that was the official site, see post below)
I just received them and have had my rotors and current pads on for less than a month so I will be just replacing the pads. Last edited by Rollo`; 09-30-2020 at 08:31 PM.. Reason: update |
09-30-2020, 08:31 PM | #11 | |
Rep 611
https://www.bremboparts.com/america/...es-live-116789 |
09-30-2020, 09:03 PM | #12 | |
3621
Rep 3,591
In the case of some ///M rotors (such as the ones I had on my Z4M), they likely don’t allow more wear due to the risk of cracking of the cross drilled holes. They may just assume ///M rotors are used more aggressively, so the risk of cracking is higher with the standard additional wear limit. Last edited by aerobod; 09-30-2020 at 09:09 PM.. |
10-01-2020, 12:52 PM | #13 | |
Rep 3,496
10-01-2020, 07:36 PM | #14 | |
Rep 611
dradernh4392.50 |
10-01-2020, 08:09 PM | #15 | ||
Rep 504
10-01-2020, 08:52 PM | #16 | |
Rep 3,496
No, it goes with the M Performance Brake Kit, which has a front rotor size of 370X30, while the M Sport brake system (the blue caliper brake system) on M235s and M240s has a front rotor size of 340X30. I swear, someday a bright college student will earn an advanced degree after being the first person to fully explain, in plain English, what is possible with each BMW model in terms of OEM braking components. Pending that, we have this: https://www.bimmerworld.com/About-Us...-Sport-Brakes/, including this caveat "This page is evolving as we continue to find exceptions and changes made in the middle of production." Kudos to Bimmerworld for making the effort to keep all of this straight for us. They are more than worthy of our business. No affiliation, simply a very satisfied customer.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 10-01-2020 at 09:01 PM.. |
10-02-2020, 08:18 AM | #17 |
Rep 558
Does anyone know the correct process to bed these Brembo ceramic pads properly on the used rotors? Gentle & slow or hard & fast?
Thanks!
10-04-2020, 09:40 PM | #18 |
Rep 611
I installed the Brembo ceramic pads today and they are great so far. Initial bite is actually better and since I don't track the car I will probably not know what I am missing regarding the M performance pads likely better fade resistance.
I bedded them gentle and fast, I did some medium pressure high speed braking from 80 down to 30 and avoided any hard full stops while driving around today and they seem to be fine. |
PeterWT252.50 |
10-05-2020, 12:46 PM | #19 | |
Rep 558
Thanks for sharing your approach to bedding them. I've never replaced the pads on this car. Any tips I should be aware of before I do it? Or is it pretty straight forward, just: remove springs, remove pins, remove sensors, grease contact points on new pads and then reverse procedure for install?
Rollo`124.00 |
10-05-2020, 07:25 PM | #20 | |
Rep 611
I didn't even change out the sensors since these had been installed for less than a month so that made it even quicker for me. Super easy process. |
PeterWT252.50 |
