bilstein b14 for m240i RWD, keeps sending me the same 2 L struts |
05-26-2020, 10:23 AM | #1 |
Rep 336
Has anyone installed the bilstein b14 coilover kit on an m240i rwd? I've received 2 kits so far with both containing identical left and right front struts. So the bracket protruding from the side is the same.
Not sure what is going on lol. Bilstein isn't giving me a straight answer either. I called them and they said they don't have individual part numbers for the 2 front dampers, just a single part number. |
05-26-2020, 10:47 AM | #2 |
N54 to N55
67
Rep 308
according to realoem there is a left & right piece for oem parts, not sure if somehow bilstein is different..
left: 37116865539 right: 37116865540 |
05-26-2020, 11:11 AM | #3 |
Rep 336
thats why we are are scratching our heads. ECS is telling us they should be identical. Even though they saw the pictures and sent us a new kit. i'm going in circles right now. lol
05-26-2020, 11:20 AM | #4 | |
Rep 3,643
Drives: 328d Wagon, M2 Comp, i4 eD35
You must have the adaptive suspension. RWD vehicles with passive dampers use two "left" struts in the front, so that's how Bilstein developed their kits.
You can use the two left Bilstein struts, but you'll need to get an additional left end link. After that, it'll fit/work. Here's a post I made explaining the same situation to another RWD user last year: Quote:
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-26-2020, 11:23 AM | #5 | |
Rep 336
Is this normal to do btw? Or should I be backing away from this and going with something more directly compatible? |
05-26-2020, 11:27 AM | #6 | |
Rep 3,643
The alternative is ask Bilstein to send you two xDrive front struts since those are L/R specific. They'll fit your vehicle, have the same spring rates and damping, and the only difference is the amount they protrude below the knuckle is a bit less (because they have to leave clearance for a front drive axle CV boot).
EVEda235i93.50 |
05-26-2020, 11:28 AM | #7 | ||
Rep 336
01-05-2021, 12:46 PM | #8 |
Rep 144
Thread revival.
Looked into the B14 kit since some sites like FCPEuro shows that they are compatible with the US-spec M240i, but on Bilstein's own site, only the B16 kit is listed. Contacted Bilstein and this is what they said: All the M240i’s that were sold in the US had electronic suspension and for this reason we only have the B16 DampTronic kit cataloged for your vehicle. This kit will plug into and interface with the factory EDC system. FCP Euro is purchasing some Euro spec B14 kits and selling them on their website. We will reach out to them about this. We would not recommend using the B14 kit on your US spec M240i. |
01-05-2021, 08:11 PM | #9 | |
Rep 336
01-06-2021, 10:55 AM | #10 | |
Rep 144
If the only difference between the two kits is retention of EDC then I'd be fine with the B14s. |
01-07-2021, 12:13 AM | #11 | ||
Rep 336
