03-20-2016, 07:51 PM | #1189 | |
Rep 5,262
which version do you have? |
03-21-2016, 09:43 AM | #1190 | |
Rep 107
Looks like I'm running: Version 3.27.1 PSdZ Version 5.01.02-2015-08-12T 12:04:59Z I got my esys files and pdszdata from here: http://*****************/esys/ Is there a more current link I should be using? Thanks in advance! |
03-21-2016, 09:46 AM | #1191 | |
Rep 5,262
03-21-2016, 04:06 PM | #1192 | |
Rep 107
http://www.bimmerfest.com/forums/sho...postcount=6507 Worked without issue this go-round and I was able to successfully code the mirrors to fold/unfold with comfort access. Thanks again to everyone on this thread. |
03-21-2016, 04:15 PM | #1193 |
Rep 282
My use case is that I like to be able to mount the phone on a magnetic mount on the dash, use Google Maps for navigation while streaming my music through Bluetooth (like Pandora or iHeartradio). The navigation will automatically lower the music volume when giving guidance, and you can also use the car's controls to skip tracks, etc.
03-21-2016, 04:18 PM | #1194 |
Rep 282
03-21-2016, 05:04 PM | #1195 | |
Rep 1,753
03-21-2016, 06:06 PM | #1196 | |
Rep 107
I will say however that I went out earlier to try it again and noticed that it doesn't actually work with the fob. The 2016's have comfort access standard so I never use my fob it just lives in my pocket. The mirrors do fold/unfold when I grab the door handle though, which is what I wanted so I'm unsure if that's any help to you. |
03-21-2016, 06:27 PM | #1197 |
Rep 5,262
03-22-2016, 12:21 PM | #1198 | |
Anticipator
14
Rep 49
Do you know what is the maximum angle the mirror is capable of turning? Many thanks for your great work.
03-22-2016, 12:45 PM | #1199 |
Rep 5,262
03-23-2016, 08:38 PM | #1200 |
Rep 88
cable ordered and still waiting.. finally got around to loading windows 10 on parallels for mac...
just been watching some vids and can see i need the e-sys software.. still not up 100% on tokens and all that jazz i see there is a cheatsheet already that can be preloaded looking to do pretty much what cth6 did and change some of the active sounds thanks to all for the great thread
16 228i xdrive with JB Stage 1 tune, 35% tint, debadged more to come
03-24-2016, 03:37 AM | #1201 |
Rep 116
I messed up coding, ended up re-coding my FA with the backup I had. I received a chassis/fuel system error. I followed another thread about reloading a corrupted CAFD. I did that and I am now receiving a check engine light, U1187 (Network.) I have an appointment with the dealer but its not for a week. Any ideas?
03-24-2016, 10:35 AM | #1202 | |
Rep 5,262
03-26-2016, 09:51 AM | #1203 |
Rep 116
I was modifying the Rem portion for led brake lights. Started to receive rear light malfunction errors so I tried to code my backups I make when I first got the car in Dec(I've actually got the backup stored on multiple thumb drives due to paranoia of messing up.) The engine and everything shut off mid-coding and I found this thread.
http://www.2addicts.com/forums/showthread.php?t=1050928 I was getting the same errors as the OP then followed your instructions in that thread to recode dme2. The CEL disappeared yesterday after the car sat turned off for a few hours. Is there anything I should check to make sure it's all good? I'm going to feel even more like a moron if I go into the dealer and they say it's all good. |
03-26-2016, 11:31 AM | #1204 | |
Rep 5,262
Next time just make sure you don't code the whole car cause you can't code the DME with the engine running without a charger. ONLY CODE INDIVIDUAL ECUS!!! Also you don't really need backups.... if you mess anything up just select the specific ECU you want to restore like REM and hit "Code" instead of "Code FDL" that will revert all your coding to factory values |
03-26-2016, 05:30 PM | #1205 |
Rep 244
1) Is it possible to decrease rain sensor sensitivity (even the less sensitive setting is most of the time too fast for me)?
2) Is it any way to disable the cold weather warning? the coding below does not work for me FDL Coding Kombi => CC_TEMPERATUR WARNUNG = nicht aktiv 3) Is there a way to have the heated seat settings remembered for longer than 15 min? Thanks |
03-27-2016, 10:08 AM | #1206 |
Rep 25
Is there a way to have the windows fold upon locking? I don't use the key fob that much so would be great to just have them close when I press the door handle. Thanks for all the amazing information here .
03-27-2016, 10:34 AM | #1207 | |
Rep 5,262
If you mean to close the windows you just keep pressing the close button on the handle until they are closed if you coded it |
03-27-2016, 02:19 PM | #1208 | ||
Rep 25
03-27-2016, 02:44 PM | #1209 | |||
Rep 5,262
You can even set how much time delay, you can set to 0 and it will fold all time |
03-27-2016, 05:17 PM | #1210 | ||||
Rep 25
