03-10-2018, 09:40 AM | #1959 | |
Rep 8,364
03-20-2018, 07:33 PM | #1960 |
Rep 301
Turn off drive mode description?
Is there any way to turn off the descriptions that pop up every time I select a different drive mode (Sport, Sport Plus, Eco).
I HATE it! |
03-20-2018, 07:36 PM | #1961 |
Rep 5,262
ChrisFulton228.50 |
03-20-2018, 08:50 PM | #1963 |
N54 to N55
66
Rep 308
So wondering if anyone has any input on an issue, I have successfully coded my car btw (Thanks for all the info!) but I tried coding another fellow M235i, I was able to read svt/FA, activate FA, "read coding data" and then enter different ecu's. Once I went to "code FDL" I received some errors (forgot to screenshot) they were definitely cafd related though, I remember reading. Most of the coding I did didn't end up working, but a couple did (ex: AC off on startup). I did just realize I hadn't added all the cafd files that were in the "63.3+ CAFD" folder into the "psdzdata\swe\cafd" , so maybe I was missing those? His car is a 2014, mine is 2015 if that matters. I wasnt able to get his I-step version either. Any help/tips would be appreciated!
Nbturbos7.00 |
03-20-2018, 11:49 PM | #1964 | |
Rep 8,364
Post actual error. Then, community and I can further assist. |
03-21-2018, 06:43 AM | #1965 |
Rep 414
Hi Guys
I have NBT evo oem fitted in the car f87 3/2017 production, the car is quite full BUT without apple car play. I have check on etk possible retrofit and is possible to buy 6NR fsc code 9c. on the connected drive already work M laptimer, spotify and other app. Checking in comfrot mode the fsc is not present. Can anyone explain how bmw is managing these functions? is that provision that enable without FSC? thank you for help |
03-21-2018, 10:31 AM | #1966 | |
Rep 30
Thanks for posting! I did a little research and couldn't find a difference between 2014 and 2015 for coding, but I'm not too familiar with coding on these cars. Maybe we have to get together and try again, and if it still doesn't work we'll take that screen shot next time, lol.
03-21-2018, 09:24 PM | #1967 | |
Rep 8,364
03-22-2018, 08:23 PM | #1968 | |
N54 to N55
66
Rep 308
Line 30823: Result error: MCDError Severity: 2051, Error Code: 58640, Description: resource not available, Vendor Code: 2008, Vendor Description: T2 timeout occured Line 30841: description: T2 timeout on Service RDBI_FTP has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; LinkName: FEM_BODY_40_ETHERNET Line 33173: description: Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=53311][ErrorCodeDescription=Module offline][VendorCode=20039][VendorCodeDescription=link is no longer active]; LinkName: FEM_BODY_40_ETHERNET not sure if these mean anything or If it would be better to read the error in in e-sys in real time. Thanks! |
Nbturbos7.00 |
03-22-2018, 11:28 PM | #1969 | |
Rep 8,364
03-23-2018, 09:15 AM | #1971 |
Rep 67
Led headlamps
Hello again, I wrote a few weeks back, I'm having trouble on finding the code for leaving my halos full brightness on when turning the lights on. I tried all the options on the F22, F15 and F30 cheat sheets and couldn't get them to work. So I have come to the conclusion that it's because this car is 2018 and has the LEDs headlamps installed from factory.
The nearest I got is messing with FLE module - POL1_ and changing the third hex value to 0A, but that doesn't work as expected. Anyone has coded their LEDs headlamps halos to maintain full bright when you turn them on? Thanks in advance |
03-23-2018, 06:19 PM | #1972 | |
Rep 8,364
Then, I am not sure.
este66.00 |
03-24-2018, 05:24 PM | #1973 |
Rep 287
Coding Mirrors ?
Hi, can you guys tell me if I can code the mirrors to fold on my new 2017 M240i if it does not have the folding facility button installed already? Can they be coded to fold on locking and unfold on unlocking without the fold button being present on the door panel next to the adjustment buttons? It is not the only aspect I would like to code but I had this question first. Could not find the answer in search.
Thank you. |
03-25-2018, 01:33 AM | #1974 | |
Rep 8,364
03-25-2018, 10:06 PM | #1975 |
N54 to N55
66
Rep 308
Yeah weird, thanks anyways. maybe I’ll give it another go and see what happens and report back.
03-26-2018, 09:17 AM | #1976 | |
Rep 67
Thanks in advance |
03-29-2018, 07:38 PM | #1977 |
Rep 7
Hi all, did anyone try to code blinking rear led bars as indicators like that f30 on the video?
https://www.youtube.com/watch?time_c...&v=3MAxzkBKQFw |
04-17-2018, 11:53 AM | #1978 |
Rep 780
Quick resurrect for a question- my VO code for my exhaust apparently disappeared. My SA saw it and it’s the reason my exhaust valve hasn’t operated. He said to just get it coded back in but what’s the number for exhaust? I VO coded Bluetooth but don’t remember taking anything out
04-17-2018, 09:43 PM | #1979 | |
Rep 8,364
04-19-2018, 12:01 AM | #1980 |
Rep 780
Any way of doing this through the BimmerCode app or am I going to have to get esys again?
2014 AW M235i Sold
2013 BLK GT500 track pack/ perf pack/ recaros |
