07-07-2017, 10:33 AM | #177 | |
Rep 58
Will the lca and ts give you enough camber for your desired driving? |
07-07-2017, 11:30 AM | #178 | |
Rep 85
07-07-2017, 02:10 PM | #179 |
Rep 58
I'm not sure. From what I've read it should give you about Neg 1 degree. And different tyres with stiffer sidewalls will be a big help.
11-22-2017, 04:23 PM | #180 |
Rep 159
Hey all,
New to 2addicts here. Just picked up a 2015 m235i and looking to dial in some camber for track use. Anybody have updated impressions on this new version? Have read all the camber plate threads pretty extensively. Looking for something that uses the OEM spring isolator. |
01-31-2018, 02:42 PM | #181 |
Rep 68
I just read through this entire thread (Along with the K-Mac and other threads linked in here) in search of a streetable camber plate. I find it hard to believe that no one can come up with a camber plate that works on the street without excuses from manufacturers.
Has anyone tried the revised Vorshlag plates with spring isolator installed? |
dsramme25.50 |
02-15-2018, 01:14 AM | #182 |
im a car
739
Rep 1,117
Drives: 220i M Sport | 520i M Sport
Do the Vorshlag plates also allow for caster adjustment?
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
02-15-2018, 05:42 AM | #183 |
Rep 986
Nope, there is limited area to work with. If you need caster adjustment Powerflex makes a an adjustable bushing for the front upper control arm (RWD only).
All the camber plates work on the street. But NVH is part of the game. You will hear more noises. If you really need the camber on the street then you'll accept the noises |
02-15-2018, 12:08 PM | #184 | |
im a car
739
Rep 1,117
02-15-2018, 01:43 PM | #185 |
Rep 986
Go back to original LCA's, and get camber plates This shit is all trial and error, just because they fit doesn't mean you should fit them
You could always try the M235 Racing LCA's http://www.realoem.com/bmw/enUS/show...diagId=31_0942 Part #6 and #10. I bet no one has tried that yet. |
02-17-2018, 07:23 AM | #186 | |
im a car
739
Rep 1,117
02-17-2018, 12:41 PM | #187 |
Rep 986
Camber plates don't destroy cars, idiots destroy cars. There's no need for a daily driver to add 3 degrees of camber for a road car. If you are not tracking the car, then it's really no point. If you need that type of front-end grip on the street then you are obviously driving dangerously. But do what you want
Camber plates increase NVH nothing less. And it's minimal, you hear a little more suspension and road noise for the first few days, and then it goes away... You get accustomed to it. The F22/F30 camber plate designs had a few hurdles and bumps in the beginning, bad designs, poor bearings, variety of design methodologies. Each has it's own strength and weakness. TC Kline, GC, Vorshlag, Dinan, etc.. I've found out through tracking with camber plates like anything else things wear out and need replacements and inspection. Just another thing to consider. The right options. IMO: 1. Coilovers w/ their plates 2. OEM w/ aftermarket plates (GC or Vorshlag) Sorry for the rants, but I hope it helps a little. |
02-18-2018, 08:56 PM | #188 | |
Rep 2,601
No bangs, clunks or twangs though. |
Anthony235715.00 |
02-20-2018, 11:01 AM | #189 | |
Rep 1,541
Camber plates should not be wearing out like they seem to do with the solutions listed in this thread. They should also not have the NVH that is so prevalent. Track car or daily driver. Other cars seem to have the same issue when adding camber plates to OEM suspension. It's just not a good solution. Better off with control arms or camber arms that allow camber adjustment. I've never used just camber plates. Just seems like a waste of time and money considering all the headaches and continued maintenance of them. If it's a matter of budget then just put your camber plate money towards some BC Coilovers and be done with the headache. Good budget coilover.
03-01-2018, 10:19 AM | #190 |
Rep 57
Low Speed Rattle?
My M235i xDrive is used mostly as a daily driver, but I also like to attend an occasional AutoX. Also hoping to make it to a couple track days this year. Needed to dial in some negative camber to help save the outer shoulders of my tires, so I just installed Vorshlag camber plates (also added Dinan springs while I was at it).
The Vorshlag camber plates I received accommodated the stock isolator/dust boot nicely and I haven't heard any odd noises that are obviously coming from the springs. I know that camber plates come with a NVH penalty, but I am not sure what noises are 'normal' versus noises that are a sign of trouble. I think I am hearing what folks describe as a 'low speed rattle' (although it can also be heard at higher speeds if the conditions are right). It happens when travelling over uneven pavement and the suspension has to work. I have pulled the setup apart and checked for signs of wear or loose hardware, everything looked ok. I gave the top nuts a good shot with my impact wrench to make sure they are tight. These plates are built like a tank, hard to imagine anything is rattling with the hardware tight. Guess I am a bit paranoid about ruining the spherical bearings. I have tried to capture the sound in a couple videos, but it's not the same as being in the car. Anyone recognize these suspension noises? https://youtu.be/ZVe6TAvB_Qg https://www.youtube.com/watch?v=SO0vm1VChG0 |
DaFish157.50 |
03-01-2018, 10:25 AM | #191 |
Rep 1,084
That noise is typical of any spherical bearing camber plate on these cars. "Normal".
The only plate I tried that didn't have that noise was the K-MAC, which has an elastomer-suspended washer instead of a spherical bearing. Unfortunately, the K-MACs had other issues.
03-01-2018, 10:37 AM | #192 | |
Rep 57
I think the Vorshlag plates are beautifully made, but I wish we had other good camber plate options for cars that are primarily daily drivers. Folks get into my car and frequently comment on the noise (basically asking if its broken). But gotta have more negative camber! |
03-01-2018, 11:19 AM | #193 | ||
Rep 1,084
03-01-2018, 11:29 AM | #194 | |
Rep 57
FWIW, I am currently running a square setup: - 18x8.0 ET42 - 235/40/18 Michelin Pilot Super Sport I went with the camber plates hoping for easy camber adjustments up to -2.5 degrees (and keeping the front wheels located to avoid any possibility of rubbing). |
03-01-2018, 12:14 PM | #195 | |
Rep 6
Upon my initial installation of the plates, I had the very same clunk at low speeds that is in your videos. Vorshlag guys suggested that the top nut was not tight enough. The things had been installed professionally and torqued properly with an impact wrench to begin with but nonetheless I checked and rechecked it. I did two track days with that setup but in the following weeks the noise drove me nuts on the streets, so I took them off and sent them to Vorshlag for an inspection that they offered. Vorshlag folks found -- verbatim quote -- "brinelling of the radial bearing in the perch" -- so they replaced the radial bearings and rebuilt the plates. I have yet to put them back on to see if things are any different. Did you show the videos to Vorshlag? Curious what they'd say. I was never able to capture the sound properly to show them but they maintained in our conversations that there should not be any clunking of any kind. |
03-01-2018, 01:12 PM | #196 |
Rep 57
I did send the videos (and a few of pictures I took after disassembling the drivers side to inspect it) to Vorshlag yesterday, haven't heard back from them yet.
I also chatted with Vorshlag before I took the videos and they said that improperly tightened top nuts are a very common source of noise troubles. They even made a video on the proper way to tighten the top nut: https://www.youtube.com/watch?v=2bab6x47CSs |
03-01-2018, 06:13 PM | #197 |
Rep 57
Mystery Unsolved
Had a chance to talk to the Vorshlag folks today about my videos and pictures; they spent a good bit of time talking to me and it seemed like they were really trying to help.
Bottom line is the audio recording isn't anything like being in the car, so it didn't really help to pinpoint a specific cause. The sound is something beyond increased road noise, and as such isn't expected. The usual suspects are loose top nuts or sway bar endlinks, both of which I think are tight. Now the question is: are the camber plates causing the noise, or simply transmitting the noise. In the transmitted case, I suppose it could be something normal or something busted. I could send the plates back and have them inspected. But I think a real solution would involve getting the entire car down to Texas so they could dig into it ... they offered to bring it into the shop and try to figure it out. Much too far away for that unfortunately. Anyone with similar issues close to Vorshlag? Last edited by SpudGT; 03-01-2018 at 06:26 PM.. |
03-07-2018, 10:13 PM | #198 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
