06-04-2017, 10:30 PM | #1805 |
Rep 8,376
What do you mean it was not an option?
06-04-2017, 10:48 PM | #1806 |
Rep 671
Didn't know it was part of wireless charging.. I was really thinking about ordering it, but because of price and losing storage space, I didn't take it..
So I'm SOL, since I didn't get wireless charging eh? On edit.. it seems EBT can be coded active if one has a combo box. Where is this combo box located? Can I tell by looking at my build sheet on BMWVIN or BIMMER.WORK? If I have a combo box, what do I need to code to activate EBT? Thanks!
'20 240ix convertible
06-04-2017, 11:28 PM | #1807 | |
Rep 8,376
You have a Combox; it is built into HU_NBT(2). You only have to worry about separate unit if you have head unit like HU_CIC and then must look for CMB_Media in SVT tree. 6NW is the new 6NS for ID5/ID6 systems Using modified FA (-6NH, +6NW), VO code HU_NBT2 "Read Coding Data" for HU_NBT2, Edit (MICROPHONE_NUMBER = wert_1) FDL Code HU_NBT2 |
06-04-2017, 11:36 PM | #1808 | |
Rep 671
This coding has my head spinning....
06-05-2017, 01:13 AM | #1809 | |
Rep 8,376
The process uses both types of coding: VO and FDL. You first VO so that E-sys takes care of making all the changes to add a factory option. Then, you follow up with FDL coding so you do not have a system error about missing hardware (ie second microphone). |
06-05-2017, 05:24 AM | #1810 |
Rep 860
Almaretto, is it correct that I can't add Apple Car Play to my MY16 '235 given that it was not an offered option at that time?
Thanks again for your help. |
06-05-2017, 06:42 AM | #1811 | |
Rep 8,376
If I recall correctly, your F22 would have ID4, which is not compatible with 6CP. |
06-05-2017, 11:03 AM | #1812 | |
Rep 671
If VO coding resets to factory, it seems one should VO code 1st before doing anything else...
06-05-2017, 12:23 PM | #1813 | |
Rep 8,376
Yes, that is the rule-always VO code first. |
06-05-2017, 12:44 PM | #1814 | |
Rep 671
Live and learn...
06-10-2017, 11:04 AM | #1817 |
Rep 26
Do you know how to code Miracast? Would love to give it a try, although I am not sure about the value. You'd still have to have your phone on to see Waze. I keep my phone on a magnetic wireless charger set to auto-start Waze whenever it is connecting to power and BT.
06-10-2017, 11:17 AM | #1818 |
Rep 8,376
Use Cheat Codes.
06-10-2017, 08:52 PM | #1819 | |
Rep 671
My question now is how do I know if I have enhanced bluetooth? I don't see Office in any menu. Is there something I can do to see if Enhanced bluetooth is active?
06-10-2017, 10:54 PM | #1820 | |
Rep 8,376
You should not do the former or dealership will have errors when attempting to program. You should also make sure to change mic number. When you read Coding data, is office Fdl active? |
06-10-2017, 10:57 PM | #1821 | |
Rep 671
http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf
06-11-2017, 11:42 AM | #1822 | |
Rep 8,376
Fxx, Ixx, & Gxx Series Coding: Getting Started Guides, Tips, & Cheat Sheets You can skip steps 8-10 and simply load modified FA (vs reading from VCM) in Expert Mode > Coding. This way, when dealership reads vehicle, it looks factory. |
06-11-2017, 08:18 PM | #1823 |
Rep 671
mirror folding
I'm trying to get my mirrors to fold in/out based on whether I lock or unlock the car... I tried the below and it doesn't seem to work.
FEM_BODY: ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN : Changed from nicht_aktiv -> aktiv ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN : Changed from nicht_aktiv -> aktiv Do I need to code something else or is it not possible to do on the 2 Series? Thanks!
06-11-2017, 08:20 PM | #1824 | |
General
10931
Rep 42,975
Drives: 2018 Alpina B6 650ix GC
KOMFORTSCHLIESSUNG_FB = aktiv KOMFORTSCHLIESSUNG_PA = aktiv
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-11-2017, 08:21 PM | #1825 | |
Rep 671
BTW, on the F30 cheat sheet, it says those two are for the keyfob. I only coded the original 2 because it said it was for fob or comfort access. Thanks!
06-11-2017, 08:28 PM | #1826 | |
General
10931
Rep 42,975
PA = Comfort Access You should also code this unless you don't minding pressing and holding Fob button for 20 seconds: KOMFORT_SCHLIESSEN = Werte 00
