06-04-2017, 12:12 PM | #1784 |
Rep 671
What am I doing wrong? I've tried uninstalling and reinstalling and none of the instructions I find online shows the below screen shot. They all say to update the Path to install the software token, but there's no option to to it..
Anyone know what to do? I did find that it will generate a token, but it's in a hidden folder.. I can copy and past where it's needed, but I'd rather do it as the instructions say.. Can anyone assist? Thanks! BTW I used this installer: ESysLauncherPremiumSetup_2.7.1_Build_135.msi
'20 240ix convertible
06-04-2017, 12:17 PM | #1785 | |
General
10543
Rep 41,215
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-04-2017, 12:35 PM | #1786 | |
Rep 8,364
06-04-2017, 12:36 PM | #1787 | |
Rep 671
The token lands in: C:\ProgramData\TokenMaster\E-Sys Launcher Premium\freetoken.est Then the below comes up.. I have it set on F23, since I have a 230xi convertible.. launch it E-Sys is automatically launched.. I go to Options then settings, but there's now this problem.. There's no Program tab. I'm guessing <DialogOptions.1> is the old Program tab? Can anyone confirm? Also, should I copy the freetoken to the C:\data folder or leave it where it is?
06-04-2017, 12:41 PM | #1788 | |
Rep 671
06-04-2017, 12:43 PM | #1789 | |
Rep 8,364
The pictured tab is the "Program" tab, but you should not be changing anything there. Not sure why yours is displaying differently. Just got to "Options" and "ODX." You can leave token there or move. If you move, make sure to change EST Tab location. |
06-04-2017, 03:10 PM | #1791 |
Rep 671
Thanks all... I've got it figured out, but I have another question...
I switched the iDrive display from id5_plus_plus => id6_light.. Here's what I got.. What I'm trying to get is this (thanks for post this tom @ eas): Can someone tell me what other code I might need to change to get the smaller icons? If I can't get the smaller icons, as I've seen pictures of.. I think I'm going to just switch back.. Thanks again all!
06-04-2017, 03:21 PM | #1792 |
Rep 8,364
Do not code ID6_Lite if you want ID5 interface. ID6_lite has larger, flat icons. ID5 has curved smaller icons.
06-04-2017, 03:25 PM | #1793 | |
Rep 671
http://f80.bimmerpost.com/forums/sho...3&postcount=22 Did he get lucky or is there more to getting the smaller id6 lite icons?
06-04-2017, 03:52 PM | #1794 | |
Rep 8,364
They are both ID5. It is just an ID5 or ID6 skin/ GUI. |
06-04-2017, 03:56 PM | #1795 | |
Rep 671
When I switched to id6_light, I get the gigantic tiles, where you can only see 3 at a time versus 6, like he's showing.
06-04-2017, 04:13 PM | #1796 |
Rep 671
So changing it to aktiv will allow one to keep the fogs on, even what HBA is active and or high beams are in use?
06-04-2017, 04:17 PM | #1798 |
Rep 8,364
06-04-2017, 04:44 PM | #1799 | |
Rep 671
06-04-2017, 04:47 PM | #1800 |
Rep 8,364
Yeah. I forgot what option was, but remember it had nothing to do with coding and just navigating system. But, great thing is that you can easily switch back and forth between GUI's (with coding) as you decide which you prefer.
06-04-2017, 08:20 PM | #1802 |
Rep 671
Any guidance/tutorial would be greatly appreciated. I searched, but couldn't find anything.. I tried activating all the codes listed in the cheat sheet and it made no difference. I'd love to have idrive read me my texts..
Thanks!
06-04-2017, 08:25 PM | #1803 |
Rep 8,364
Enhanced Bluetooth is a factory option. You do not FDL code it, so it is not always found on Cheat Sheets. Did you try 6NW? Make sure to FDL code back any conflicts (eg number of mics).
06-04-2017, 09:06 PM | #1804 |
Rep 671
I have no idea what you mean by 6NW. As for enhanced bluetooth, I don't think it was an option when I ordered my '17 230i. And I don't see it on the cheat sheet... Maybe I should try using the F30 cheat sheet?
