2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Dinan Stage 1 Discussion Only
      08-26-2014, 05:00 PM   #155
s2ktan
Drives: 2015 M235 - Delivery - 9/2014
Originally Posted by chaddy74 View Post
Lets leave this poor (Kid) alone !! Clearly he's struggling on multiple levels as his now posting AFR data and previous data from other tunes when the thread he created is Dinan only!! Very Silly this whole situation !!
+1 - we should all just be patient and stop speculating.....Whatever the truth is, it will come out. Just a thought.
      08-26-2014, 05:07 PM   #156
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Op is ok to just tell the truth, we do joke around but its nothing personal u know
We're all car guys
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-26-2014, 05:58 PM   #157
pikcachu
pikcachu's Avatar
1412
Drives: M235i (F22 Red angel)
btw wth is that big drop in the AFR for the dinan tune at the beginning of the graph?
      08-26-2014, 05:59 PM   #158
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Originally Posted by Maniac0908 View Post
I hope this doesnt turn out to be something like his numbers being 2 off of what was advertised.
What do they advertise their Stage2 tune at?
Mike
      08-26-2014, 06:02 PM   #159
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Spoon feeding only the information I can at this time. A review is ongoing at this time with an answer shortly. Not trying to mysterious here, but just can't release information until I have it ready to go. Patience please!
I thought the AFR numbers were very interesting. Look at the changes between the tunes and factory settings. Does anyone here know about fuel tuning see a problem here? I do!!
      08-26-2014, 06:04 PM   #160
Delnari
Delnari's Avatar
Bingo! We have a winner!!
      08-26-2014, 06:09 PM   #161
HX_Guy
Drives: 2014 BMW M235i
Delnari, are they reviewing the output numbers or other aspects of the dyno, like the AFR, or both?
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      08-26-2014, 06:09 PM   #162
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Tell him what he's won, Bob!
      08-26-2014, 06:32 PM   #163
pikcachu
pikcachu's Avatar
1412
where is my prize ?
hope it's not a free Dinan "tune"
      08-26-2014, 06:40 PM   #164
jmkr
Boost Patrol
jmkr's Avatar
Drives: 2014 M235i
sooooooo its running a little rich - what comes next?
      08-26-2014, 06:55 PM   #165
HX_Guy
It looks like it's running a little bit leaner than stock past 5700 RPM whereas the BMS is quite a bit leaner from 5300+.
2014 BMW M235i 6MT
      08-26-2014, 07:44 PM   #166
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Mike
Stage 2 isnt out. Stage 1 is 364hp 409 tq
      08-26-2014, 07:50 PM   #167
Researcher
Drives: MG M235i / C7 3LT Z51
OP is getting a lot of PR here for free. Not even Starbucks can compete! Steve would have posted if there was real issues to address. Stop giving free PR.
      08-26-2014, 08:04 PM   #168
Researcher
When OP is ready he will post story.
      08-26-2014, 09:14 PM   #169
basiluf
Drives: 2019 S450 2018 S90
Didn't the OP install the tune himself? I thought in order for the warranty to be effective, an authorized dealer must do the install. Maybe car went kaboom on dyno?
'14 M235i(current)ED
'11 E93 M3(past)ED
'08 E90 328i(past)Local
      08-26-2014, 10:07 PM   #170
alz0rz
What goes here?
alz0rz's Avatar
456
Drives: 2019 G30 M550i
Is that all it is.. a little AFR hiccup (in a non-critical area...) that threw off the results a bit????
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      08-27-2014, 08:52 AM   #171
Ritz42
Drives: F22 & R56
The AFR graph would be more informative if it was measured over RPM.
      08-27-2014, 10:44 AM   #172
Mike@N54Tuning.com
Time is actually interesting. Since load is fixed on a dynojet the shorter the time the more power you made. If each run started and ended at around the same RPM then the longest run would have the least amount of HP and the shortest run the most.
Just for comparisons sake the N55 Stage1 tune requests 3psi more than stock across the board. I would hope the Dinan with its extra control is pushing a lot more than that? The JB4 can run as much as 10psi over stock with the aggressive maps. The JB4 also has F30 EWG AFR control in testing now.
Mike
      08-27-2014, 10:49 AM   #173
HX_Guy
Seems to correlate, unless it's just a coincidence? The 0 second mark is ~2,000 RPM and every second after goes up 500 RPMS.
2014 BMW M235i 6MT
      08-27-2014, 02:29 PM   #174
Delnari
Delnari's Avatar
Okay, finally able to talk the my Dyno adventure from last week. First off, let me say I have respect for everyone who works at making a living in the auto aftermarket industry including tuners. It's a tough life that doesn't pay nearly as much as it deserves!
The tuner I use for my first dyno is the same one I used for my dyno with Dinan. Figure we would get apples to apples measurements. As mention already, the car was ran in the incorrect gear on the first past (6th instead of 5th). Second, the cabling connected to the car was not secured enough to measure true torque reading as it had intermitted signals. Add that to fact the Dynojet used (4-wheel drive version) was getting wheel slip during every pull; including my first baseline pulls which I didn't learn about until after this second go round. Bottom line, the Dyno numbers on the final 4th pull came back underrated!
The wait was for Dinan to get the entire unit back and run diagnostics to verify everything was working as it should be. Some finger pointer was going on from the shop and needed to get both parties a good say before posting any real numbers.
So, my numbers are:
314 HP and 343 TQ (First post updated with Chart)
Not very good considering stonger numbers from the BMS N55 Stage 1 unit. Just finished speaking with Dan in Dinan Engineering and he said the real Dynojet number should have been 315 HP and 370 TQ for the Stage 1 kit. He did go on to say that the Stage 2 will be a bump to about 335 HP and nearly 400 TQ once it gets released. They are waiting on the Dinan Intake to go live for production before it is released. Would like to see another M235i with Dyno run on a Dynojet come back and report their numbers to see if they match up to what is expected.
I waited for both my tuner and Dinan to respond before I posted any numbers so it didn't appear I was taking sides against the other. Again, nothing but respect for those who work in this industry. I have been issued a full refund from Dinan and deciding my next move for a tune. Leaning towards a 200 cell catted downpipe to put on now while I ponder the JB4 setup.
      08-27-2014, 02:51 PM   #175
Fletch F. Fletch
Drives: Black M235i MT
I've been quietly following this since I am brand-new to any of this. From what I've read the average drivetrain loss is 15% give or take. That puts the motor numbers at 361 and 395 or thereabouts. Would that be correct?
      08-27-2014, 02:59 PM   #176
Delnari
Delnari's Avatar
I think the M235i is more around 9% realistic powertrain loss. Dinan confirmed that their stock M235i is 296-297 rear-wheel HP with me earlier today.
