02-23-2015, 06:08 PM | #155 |
Rep 845
02-23-2015, 11:04 PM | #156 |
Rep 845
Here you go
02-23-2015, 11:13 PM | #157 |
Rep 86
Drives: '14 228i MSport
no spacers needed? tempting to pick a setup. and soo much space in those parking garages. I miss socal. parking here is like squeezing into a spot meant for a motorcycle.
02-23-2015, 11:20 PM | #158 |
Rep 845
No spacers, but you do need camber -- I have Ground Control plates in the front. My setup is F 2.25, R 1.65 (could use some more, maybe 1.8), and 1/16 toe in.
02-24-2015, 04:58 PM | #159 |
Rep 24
Thanks for posting more. Really looks
good. Might just need a little drop. Is there a reason u went with the square set up? I saw the staggered set has a real high offset on the rears. |
02-24-2015, 05:59 PM | #160 |
Rep 845
03-04-2015, 07:35 PM | #163 |
Rep 4,528
Drives: M2 CS
03-05-2015, 04:56 AM | #164 |
Rep 233
03-05-2015, 06:11 AM | #165 |
Rep 119
03-05-2015, 03:05 PM | #166 |
Rep 659
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
03-05-2015, 08:48 PM | #167 |
Rep 130
Pleased with my Enkei Raijin which were discussed earlier in the thread - low weight (20.0lbs) and pretty good price.
This is what the 18x8 look like in Hyper Silver. Wearing Michelin winter tires PA4 staggered - but with 245/40 in the back. |
03-06-2015, 03:40 AM | #168 |
Rep 4,599
Current '22 X3M LCI.. |
03-07-2015, 07:35 PM | #169 |
Rep 1,298
What about VMR VB3 CSL reps in the following sizes? Would they fit ok without rubbing? I'm not lowered.
F: 19x8.5 40mm offset 225/35/19 R: 19x9.5 45mm offset 255/30/19 |
03-13-2015, 08:46 AM | #170 | |
Rep 1,298
03-13-2015, 11:14 AM | #171 |
Rep 47
The rear might run into some problems with rubbing but I really can't say for sure. I know Apex wheels recommended a 58 offset with their 9.5" wheels for the back of the car. Fronts should work no problem.
03-13-2015, 01:06 PM | #172 | ||
Rep 2,494
03-13-2015, 06:33 PM | #173 |
Rep 4,528
Drives: M2 CS
03-13-2015, 07:11 PM | #174 |
Rep 1,298
Thanks all for the info, I appreciate it. I ran this setup up on my 135i and had pretty major rubbing in the rear so I had to roll the fenders. I don't really want to deal with all that again so maybe I should go with a 245 tire in the rear. It will be super stretched but then I shouldn't have any rubbing issues right?
03-13-2015, 07:12 PM | #175 | |
Rep 1,298
03-14-2015, 08:02 AM | #176 |
Rep 4,528
Drives: M2 CS
I'm running Yokohama S Drives but you could also use Hankook v12 in a 255 with out problems. From what I've read, only one person had rubbing running a 255 and he had Pilot Super Sports, which run really wide. But there's been others w/ Pilot Super Sports that didn't.
Before summer, I'm going to switch to the PSS since its a much better tire and worth the risk. BTW, my wheels came from my old 1 series. The front and rear rubbed slightly but no problems w/ the 2 series. Just switched out the TPMS |
