10-13-2016, 10:04 PM | #1607 | |
Rep 194
Drives: 2024 BMW M4 Competition XDrive
10-13-2016, 10:45 PM | #1608 | |
Rep 8,364
10-13-2016, 10:53 PM | #1609 |
Rep 194
10-13-2016, 11:08 PM | #1610 |
Rep 8,364
10-14-2016, 10:41 AM | #1611 |
Rep 273
Emergency brake mode to blinking
hmm maybe I should do that... anybody ever found a way to tell the bmw online news reading app to let you read the whole article when vehicle in motion? (the voice transcript thing is... just too funny to listen to)
//M235ix Alpine White
10-14-2016, 12:58 PM | #1612 |
Rep 8,364
Only with hardware mod to fool GPS into thinking car is not moving.
10-17-2016, 10:53 AM | #1613 |
Rep 7
Hello guys. As a newbie to this coding this, i have two questions for you.
1) What should i code to use rear led taillights as indicating lights instead of regular yellow lights? I suppose that's how US cars' indicators work. 2) What to code for xenons for welcome lights? Thanks in advance. |
10-17-2016, 07:00 PM | #1614 |
Rep 74
10-17-2016, 07:05 PM | #1615 | |
Rep 8,364
<<< CAFD_00000909.caf.004_005_001 (ACSM_4C) >>> ACSM_4C > Ausstattungsflags 3000 > Initialwarnung_GWF_IW = aktiv |
Rommel428.00 |
10-18-2016, 11:57 AM | #1616 |
Rep 1,753
my friend has a 2017 F30. Will the same settings in the cheatsheet work on that car as well?
10-18-2016, 12:10 PM | #1617 |
Rep 5,262
10-18-2016, 08:21 PM | #1618 | |
Rep 74
Thanks again,Almaretto. _Rommel42 |
10-18-2016, 09:44 PM | #1619 |
Rep 8,364
10-21-2016, 12:57 PM | #1620 |
Rep 2,924
Anyone can send me the latest software and cheat sheet (in PDF or Excel)? I will start coding tonight my F87.
Thanks in advance for your help!
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
10-21-2016, 05:59 PM | #1621 | |
Rep 8,364
10-26-2016, 11:57 AM | #1622 |
Rep 100
I couldn't find this mentioned anywhere, but if you change the below werte values to 00, camera and PDC will stay on indefinitely until manually disabled.
This is as opposed to using FF as the werte value, which will automatically turn off camera and PDC once max distance of 255 meters is driven. REM----> 3203 D_SCHWELLE_2 REM----> 3203 D_SCHWELLE_1 In addition to the above, you still have to code the speed parameters to werte FF to get this to work. |
MerlinPurple690.00 |
10-26-2016, 12:14 PM | #1623 | |
Rep 100
This will allow the car to roll with the door open regardless of seatbelt. |
10-26-2016, 08:23 PM | #1624 |
Rep 551
The North American cars have different hardware in the tail lights. The turn signal lights are simply red in North America, instead of yellow like the rest of the world.
10-26-2016, 11:31 PM | #1625 | |
Rep 74
_Rommel42 |
10-27-2016, 11:31 AM | #1626 |
Rep 3,844
I have a US spec car which has red color turn signal plastic. I was able to change the color emitted to yellow by installing a bright yellow LED even though the plastic is red. I suppose you could do the opposite by changing your bulbs to bright red LED. I ended up installing red LEDs for my rear turn signals, that is the way BMWs are sold in the US.
10-27-2016, 04:49 PM | #1627 | |
Rep 551
The answer is that it must be done through hardware changes, not coding. |
10-28-2016, 11:42 AM | #1628 | |
Rep 3,844
The quote was this ^. He apparently wants to have red turn signals with a car that has yellow turn signal lenses, I interpreted it as he thought he could code the car to change which lights were used as turn signals, but the lights used as turn signals can't be changed. It is possible change the bulb in the turn signal light to a bright red LED which would achieve his ultimate goal. The red LED would override the yellow color of the turn signal lens. I was just trying to help him achieve his ultimate goal. |
