02-28-2016, 06:26 AM | #136 |
Rep 887
Drives: Enzo F23 228i
It looks like your rear is poking out 3mm or so...is it just camera angle?
And this is 235/30 Square? |
02-28-2016, 06:33 AM | #137 |
Rep 1,091
This more like 10mm, not 3 - and it takes M2 to accommodate those nice wheels
previous: 2003 E46 330i SMG
02-28-2016, 07:03 AM | #138 |
Rep 645
02-28-2016, 01:17 PM | #139 |
Rep 178
02-28-2016, 04:18 PM | #140 | |
Rep 3,318
I dont understand? "Takes a m2 to accommodate those nice wheels" maybe its a language barrier, these are recast 437m spec 19x8.5 et35 19x9.5 et40 oem 437m are 19x9 et29 19x10 et40 I plan on getting an OEM set of fonts when they come up cheap and machining the backpad to a more usable offset since they have a nice concave profile 19x9 et34-36 square would work with some suspension adjustments wheel fitment has more todo with tire size then wheel size/offset at this point, Even 19x9.5 et35 fits on a f22 if you are willing to do a 225 or 235 tire to fit in wheel well which most people into stance would do. I am running 255 Michelin Pilot SuperSports which makes the side wall a bit more square making it looked Poked but if I was using a soft sideway narrow 245/30 and a touch more camber with same wheels it would be tucked The wheel itself maybe be 2mm poked I don't see being an issue if the wheel doesn't rub and the thread of the tire is in the wheel well , looks aggressive and fills the wheel gap I will say if your worried about wheels fitting or are not interested in trying to make something work then stick to narrow high offset wheels |
02-28-2016, 04:39 PM | #141 | |
Rep 3,318
when rolling the wheels seem to tuck in and car is lower , its like 1-2mm poked as the tire on full suspension flex will touch but I did drive 4500 miles so far on this setup and is 100% drivable never had any trouble, a narrower tire would not even be close to touching |
02-28-2016, 04:57 PM | #142 | |
Rep 645
02-29-2016, 06:39 AM | #143 | |
Rep 1,183
Do or die day drpoomanchoo. Right now I am leaning towards 18x9et44 or 18x9.5Et44. reasoning for et44 would be less poke and people seem to think it'll fit. Also if it doesn't a 3 mm spacer brings you to et41. If you had to space out a 42 I thing you end up with slightly more poke than cloud unless you get custom 2mm or 1mm spacers if those exist. |
02-29-2016, 07:06 AM | #144 |
Rep 1,183
http://www.wheel-size.com/calc/?whee...=30mm&scl=51mm
http://www.willtheyfit.com/index.php...et2=44#content 9" vs 9.5" Looks like 9.5" would not affect clearance3 because the tire is the limiting factor...correct? |
02-29-2016, 10:54 AM | #145 | |
Rep 645
02-29-2016, 07:25 PM | #147 | |
Rep 895
2019 SG M5C
02-29-2016, 07:59 PM | #148 |
BMW Lover
128
Rep 251
02-29-2016, 08:56 PM | #149 |
Rep 1,183
02-29-2016, 09:23 PM | #150 |
Rep 645
Congrats Fellas, I ordered mine as well in 19's . debating on whether to try 265's or 255's. couldnt beat the price for such a sweet wheel. ill keep updated on fitment and if i shoot for 265's on dinan drop
02-29-2016, 09:31 PM | #151 |
Rep 5,262
03-01-2016, 10:04 AM | #153 |
Rep 1,183
03-01-2016, 10:10 AM | #154 |
Rep 1,183
What I learned so far....
Cloud is running 19x8.5et35 - 235/35 and 19x9.5et40 - 265/30 mpss Another member 18x8.5et35 - 235/40 and 18x9.5et47 - 265/35 Both did not rub without modification on stock suspension |
