07-25-2016, 06:47 PM | #1497 |
Rep 110
Anybody tried changing power class to turn down ASD?
http://f20.1addicts.com/forums/showthread.php?t=1222030 |
07-25-2016, 07:50 PM | #1498 | |
Rep 5,262
07-25-2016, 11:19 PM | #1499 | |
Rep 1,752
07-26-2016, 07:20 PM | #1501 |
Rep 74
Question,
Is anyone using windows 10 to do E-Sys coding?I like to get away from my old heavy HP laptop,and use my Surface 3 Pro which I clean installed windows 10 on.Just like to get some feedback from users who may have coded with E-Sys.Thanks for any replies. |
07-26-2016, 09:52 PM | #1504 |
Rep 74
07-26-2016, 10:27 PM | #1505 |
Rep 8,376
07-27-2016, 02:13 PM | #1506 |
Rep 775
I just got Esys installed and it went smoothly, however the only cable I have is a USB obd2- is it correct I need a LAN obd2 cable for the vin to register?
07-27-2016, 02:18 PM | #1507 |
Rep 8,376
07-27-2016, 05:53 PM | #1508 |
Rep 775
07-27-2016, 09:51 PM | #1510 | |
Rep 74
I did some coding last weekend (Unlock doors when engine is off)also my first visit to FEM_BODY.No problem with coding,all working fine.The reason I bring this up,so far when coding,like in ACSM or HU_NBT2,I never saw any cheat codes.But in FEM_BODY I actually saw some,and even some in (I don't make this up)in french.I made a test with the Activ and Nicht Activ values, but no joy. |
07-27-2016, 10:57 PM | #1511 | |
Rep 8,376
Re Cheat sheets and Coding: there are cheat sheets for most of the more commonly coded ECU's and remember coding is ECU, not chassis specific. A few new codes have come to light recently, but you will not see many until more people have G-series vehicles and newer ECU modules (eg., HU_NBT2). The other issue is mapping ECU's as the launcher uses legacy data. If you are referring to the build in E-sys cheat sheets, those have to do with launcher (C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\FDLCodes). They can be updated and edited. BMW's are driven all over the world and cheat sheets have been submitted from various individuals from these different countries, including those whose first language is French (Bortho) or Spanish (ruben_17non). You can use the filters for chassis and author. But, be aware that codes may appear that may not be relevant for your vehicle; therefore, you should select "Review" to verify before you select "Apply." |
Rommel428.00 |
07-28-2016, 09:02 AM | #1512 |
Rep 775
A question I'm having regarding coding 6NS- I have non tech non navi head unit. I have the walk through from Sean and am going through it repeatedly to understand what I'll do when I get the cable but the step where it says "add/ delete FA from bottom left window and click apply changes icon"
I'm not quite sure what I'm supposed to alter or add? |
07-28-2016, 09:30 AM | #1513 | |
Rep 1,752
07-28-2016, 09:45 AM | #1514 | |
Rep 775
07-28-2016, 10:37 AM | #1515 |
Rep 1,752
That's odd. I was able to stream from day 1 prior to any coding. Wait, i have a 2016. I think that may not have been standard at one point?
07-28-2016, 11:15 AM | #1516 | |
Rep 775
I need enhanced to even unlock streaming OR USB usage from what I see. |
07-28-2016, 01:47 PM | #1517 | |
Rep 8,376
07-28-2016, 04:30 PM | #1518 | |
Rep 74
About that 900mb file,just remember the last 3 digits KBxxxx285 I think it was some update for win10 1511 version.I even needed the latest firmware for my Surface Pro.Since I have not used it for a while,hence the big size for that KB update? Anyway the Surface Pro is up to date until Aug/2/16 right?A side note:Was reading on Betanews.com that after the BIG update,one can not disable many annoying parameters any longer.Windows 10 could use some CODING,if you know what I mean. |
