06-02-2016, 08:41 PM | #1365 |
Rep 5,552
Can you code Automatic Highbeams feature without the actual option? And if Yes, how would you turn it on or off, in idrive?
I am also wondering if something like manual rev matching can be coded? I assume most likely not.... |
06-02-2016, 08:43 PM | #1366 | |
Rep 5,262
Also you need the cameras in the mirror Most definitely not worth it. I don't think you can code rev matching |
06-02-2016, 10:02 PM | #1367 | |
Rep 5,552
PS. Getting the cable on Saturday, will be watching those YouTubes in OP, hopefully won't screw up anything |
06-02-2016, 10:09 PM | #1368 | ||
Rep 5,262
06-03-2016, 08:04 PM | #1369 |
Rep 74
Hi to all,I was looking for a "POST" button,found this instead.Yes,I"m a Newbie.My first post.
I just got my M235i 2016 build date april coupe with the Technology Pack.Had no idea one could do all this coding stuff until I hit this site.After reading a lot of coding related messages,I know I have to do this. May I ask Shawn very humble to guide me to the latest apps,files and docs I would need to get started coding this amazing car!? My ENET cable is on order already.I thank you already in advance. |
06-03-2016, 08:52 PM | #1370 |
General
10939
Rep 42,996
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-05-2016, 02:10 PM | #1372 |
Rep 5,552
So I got the cable, watched the YouTube 101, will try tomorrow...
One question so far, do you press Code FDL for each change done or can you code all changes at once? Do I understand this right: connect, read all data from car, disconnect, make all necessary changes, connect to car and code them in by pressing Code FDL, right? Thanks again! |
06-05-2016, 02:22 PM | #1373 | |
Rep 5,262
Yes, that's correct.... you don't really need to disconnect, but if you are going to make a lot of changes is better so you don't have to have the car running for no reason |
06-05-2016, 02:59 PM | #1374 | |
Rep 5,552
06-05-2016, 04:42 PM | #1375 |
Rep 74
I just installed the latest E-Sys files on my laptop.Went all smooth.Thanks Shawn!
Have a couple of questions...when choosing the chassis,I did not expect F22,F23 etc.to show up under chassis option.Until my install,and reading plenty of messages on this truly great board,I thought when the time comes,I would choose F20.Anyway I picked F22,since my M235i 2016 is an F22,Right?One more question for now,(there might be many more to come)what does FDL stand for?Still waiting for my cable. Thanks for any replies in advance. |
06-05-2016, 05:17 PM | #1376 | |
Rep 5,262
06-05-2016, 08:02 PM | #1377 |
Rep 74
Thanks for the info,Pikcachu.Once I try to start coding,what should one NEVER EVER click on?Just would like to get as much info as possible.
Could you give me also for example a step by step instructions for my first coding?Like activate Dvd in Motion,and USB video? |
06-05-2016, 09:50 PM | #1378 | |
Rep 5,262
Watch the video on the first post there you have a step by step |
06-06-2016, 04:47 PM | #1379 |
Rep 5,552
And done..... everything went smoothly. Thanks.
You can add the drivers seat easy access feature to coding sheet as well, tested and works FDL Coding: SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C" 1st line enables the feature other 2 might not be needed since they customize how far seat moves etc |
06-06-2016, 09:41 PM | #1380 | |
Rep 607
Drives: 2019 BMW M2 Competition
06-06-2016, 09:50 PM | #1382 |
Rep 607
06-06-2016, 09:53 PM | #1383 |
Rep 5,552
yeah just moves the seat when you open and close the door. only 1st line needed, unless your seat is already far back, then might need the other 2 lines.
06-07-2016, 10:18 AM | #1384 |
Rep 5,552
As far as VLD...
This line: LUT_FLC_FORWARDLIGHTING_Y also asks you if car is equiped with AFS or not and default is without AFS. Should this be changed ? |
06-07-2016, 10:25 AM | #1385 | |
Rep 5,262
I know somebody posted the individual changes to on some previous post I would just follow that |
06-07-2016, 11:24 AM | #1386 | |
Rep 5,552
I did notice that when you select F20 w/ AFS, LUT_FLC_FORWARDLIGHTING_Y values change accordingly to whats in cheat sheet. So I assume you dont really need to change the values but activate AFS instead Got info from here by the way: http://f80.bimmerpost.com/forums/sho...&postcount=231 |
