03-23-2016, 09:49 AM | #111 | |
Rep 1,422
There is fiberglass in the 2nd chamber but it has a straight core. The fiberglass removal will let you hear more sound, as with replacing the perf cores with solid tubing. The reason I have no drone is likely because I have still have the backbox and some of the stock structure. But outside, it sounds quite loud. Very aggressive. The cabin is very well insulated. If you rub pure straight pipes, I'm very certain it will drone. I chat with a couple guys running straight pipes, including the Castro setup. Both drone. The fact that Fabspeeds doesn't drone, I don't know. If you listen to their video you can hear the mic vibrate and resonate at certain RPMs...to me, if there's drone, you'll feel it inside the cabin. |
03-23-2016, 03:55 PM | #112 |
Rep 112
Ok I get it. So just weld everything in chamber 1 and 3. And delete the fibergass in 1 and 3! Thanks!
I'm also running ER catless. So I think i place my midsilencer back... 1 series is very sensitive for drone when delete midsilencer But i love the snap and crackles! I hope the muffler mod in combination with downpipe will make it loud and backfire a lot when midsilencer is replaced. |
03-23-2016, 04:39 PM | #113 | |
Rep 1,422
Good luck man! |
03-24-2016, 02:08 AM | #114 |
Rep 112
Thanks mate! Midsilencer delete really brings the snaps and crackles. But in a 1series the drone is way too much. But i'm pretty sure there will be a nice sound even with midsilencer!
08-31-2016, 11:36 PM | #118 |
TeQuiero
90
Rep 424
I just got my muffler delete and wanted to share my thoughts on this.
I have the VRSF downpipe + muffler delete but kept the resonator in tact. It is very loud on cold-start. If you park in the garage, it's almost 2x as loud as stock exhaust with downpipe. Inside the cabin, it is very loud. You can hear the bass of the exhaust. There's also drones upon acceleration at around 1.5K that goes away at 2K, then another drone at about 3K-3.6K. If you are going up a steep hill, be ready for some loud drones. Sound From the outside, it sounds good. From the inside, it sounds "decent." I say decent because the sound is not "consistent," if that makes any sense... At certain rpms, the cabin would sound good, but at other rpms, the tone of the exhaust makes it sound like a diesel truck. This is subjective though. Formula for getting gunshots every time: Get muffler delete + downpipe + 6mt. When you're coming to a stop, downshift from 3rd to 2nd and make sure you're rpm is at about 2.5K-3K, then very, very gently step on the throttle for a split second. Now onto power.... I feel there's a loss in low-end torque, though some people have said that muffler deletes do not cause any power loss. The outlet of the Y pipe that replaced the stock muffler is 2.25", making it 5" total for exhaust gases to exit. Inlet I believe is the same size as the midpipe. When I launch, prior to muffler delete, I am pushed back to the seats after the turbo spools up around 2K-2.5K rpm. Now I don't feel that jolt anymore, but a rather linear increase in torque. Cliff notes: - If you don't mind the cabin loud at certain rpms and drones, this is for you - If you want an aggressive sounding exhaust, this is for you - If you want gunshot overruns, this is for you. - If you don't care about the feeling of being pushed back in low rpms, this is for you. - If your gf/wife isn't into cars, a muffler delete+dp is going to annoy them. ** To those with same setup, have you noticed low end torque loss? |
09-01-2016, 05:12 AM | #119 | ||
Dejan
1760
Rep 4,194
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Looks oem looks classy sound level goes up a tad and you'd be happy. Plenty here have done it on the 28i cars.
FBO-PS1 and stuff
09-03-2016, 07:17 AM | #120 | |
Rep 247
05-17-2018, 08:05 AM | #121 | |
Rep 36
07-22-2019, 01:30 PM | #122 |
Rep 6
thanks everyone for sharing the views. I just started my research to get sporty sounds out of my M235i but i am not open with voiding my cars factory warranty. Can someone suggest if muffler delete or after market exhaust will void BMW Factory warranty ?
07-22-2019, 01:41 PM | #123 | |
Rep 197
https://x-ph.com/active-autowerke-bm...-back-exhaust/ Now if you are daring, just get a chargepipe, downpipe, and resonator delete with a JB4. You get a huge exhaust note when you punch it plus loud pops when you please, yet quiet when you need it. Also +70hp or so.... In the rarest of cases where you will actually use the BMW warranty for engine related issues, just take the mods off. no traceability really |
