01-18-2016, 03:00 PM | #1079 | |
Rep 554
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-18-2016, 05:41 PM | #1080 | |
Rep 5,262
I think you can hit the talk button and say POI to use the voice search I think the Dual phone will not show up but if you receive a call on the non connected phone it will come out their the speakers too but only 1 phone will be connected at a time |
01-18-2016, 07:30 PM | #1081 | |
Rep 48
As for the phone. I see one connected and that one receives and makes calls perfectly. The other one (paired) does not do anything with the car. I have also tried to split the activity. Phone 1 connected for phone calls and Phone 2 connected for streaming audio. Calling Phone 1 works, Phone 2 does not. The audio on Phone 2 drops the streaming volume while the phone rings, but you do not hear the ringing or see any indication on the car. If anyone has any suggestions I would love to hear them. |
01-18-2016, 07:46 PM | #1082 | |
Rep 444
Quickest Stock Turbo F8x In The World
01-19-2016, 04:28 PM | #1084 |
General
10936
Rep 42,989
Drives: 2018 Alpina B6 650ix GC
I replied to your same PM on Bimmerfest.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-19-2016, 08:08 PM | #1085 | |
Rep 48
I wanted to make sure that the USB port worked and did the video playback on the head unit, so I activated API_USB_VIDEO. That worked like a charm. I could see the additional menu item for movie and it played successfully. Now to figure out why movies via iPhone is not working. |
01-19-2016, 08:10 PM | #1086 |
Rep 48
01-19-2016, 09:11 PM | #1087 |
Rep 444
I would love to know how to remove them. The main reason I'm not getting new seats is because I don't want to stare at the seatbelt and airbag indicators on my dash all day...
01-20-2016, 06:30 AM | #1088 | |
Rep 48
Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF to nicht_aktiv Gurtzustandsanzeige_Fahrer_GWF_GZA_FA to nicht_aktiv |
01-20-2016, 08:20 PM | #1089 |
Rep 5,262
01-22-2016, 04:02 PM | #1090 | |
Rep 48
Under Settings, Connections, Bluetooth, in the menu if you scroll right while Bluetooth is highlighted you see the setting to configure bluetooth. Under there I found Telephone 2. All I had to do was check it and then go back to my secondary phone and select phone 2 as opposed to phone 1. Worked like a charm. Looks like VO coding 6NS still requires you to go make a few manual settings via iDrive. Maybe I missed this somewhere in all of the documentation, but I am glad that it worked!! |
01-22-2016, 08:59 PM | #1091 | |
Rep 5,262
VO coding just enables the features... will not change idrive stuff for you automatically |
01-23-2016, 09:04 AM | #1092 |
Rep 35
I have a 2015 F21 135i LCI with prof Nav and standard 6NH Bluetooth.
I have successfully coded some stuff (thanks to Shawnsheridans guides) but can't get the FA coding to work. I changed the 6NH to 6NS in the FA tree and then wrote it to the HU-NBT ECU but it doesn't seem to have worked? There was some text that appeared when coding about the VCM not being read. But that's beyond my understanding. Anybody have any ideas? |
01-25-2016, 05:18 PM | #1093 | |
Rep 70
I got same error than Cloud IX but could you explain why this file was missing even in latest Psdzdata lite ? Only from Full database ? |
01-25-2016, 05:31 PM | #1094 |
General
10936
Rep 42,989
Sometimes CAFD files are remove from PSdZData releases. This is the infinite wisdom of BMW AG. I have no explanation for it.
01-26-2016, 03:11 PM | #1096 |
Bright Sky
1165
Rep 923
Drives: BMW M235i (8AT)
Hey guys,
A quick update. I finally received my ODB cable today. With my notebook already prepared with all the software, bits and pieces I decided to do a "quick coding session" to see how it would go. Coded the ///M animation and set ASD to F06 (which seems to have eliminated it completely ) Tomorrow I'm going to take some more time and code some other stuff.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
01-27-2016, 08:52 AM | #1097 |
Rep 35
Ok
I've changed the FA to 6NS and VO coded the HU_NBT2. (No CMB MEDIA) The Idrive codes and resets.(previous FDL coding I've done remains ok though) Deleted phones and reconnect Bluetooth but no office function option in Bluetooth, or show notifications slider on iPhone Bluetooth page.So the phone isn't recognising the HU as an MAP device? (works ok on wife's X5) I guess it's just not coding the FA to the module. What else can I try? |
01-27-2016, 10:58 AM | #1098 | |
Rep 5,262
Look at the video again in the first post and make sure you pressing the correct button |
01-27-2016, 04:10 PM | #1100 | |
Rep 70
Change maximum radio volume upon vehicle start HU_NBT 3002 VOL_MAX_ON Defaut : werte=19 19 is the hex value for 25% 32 is the hex value for 50% 4B is the hex value for 75% 64 is the hex value for 100% Last edited by Grave; 01-27-2016 at 04:25 PM.. |
