| 08-28-2020, 11:24 AM | #89 |
Rep 205,939
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
kianf2276.50 |
| 08-28-2020, 11:33 AM | #90 | |
![]() 12
Rep 56
Thanks for the details. Appreciate the time to take the clip as well. I ordered one yesterday morning, hoping to install myself. Here in my area, all the euro "specialists" want to do 3 hours job putting it on. Can definitely be done in an hour. |
kianf2276.50 |
| 08-28-2020, 04:17 PM | #91 | ||
Rep 348
WolfGTI752.00 |
| 08-28-2020, 04:33 PM | #92 |
Rep 939
Yeah 1-2 hour max, I drove to the shop 1/2 hour before they opened so just parked and read until they opened - then rolled in.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, VAC monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
| 08-31-2020, 08:32 PM | #93 | |
Rep 348
| 09-01-2020, 11:06 AM | #95 |
Rep 205,939
Unfortunately, I'm not an expert on PA emission laws
| 09-02-2020, 10:58 AM | #97 | |
Rep 205,939
| 09-04-2020, 11:17 AM | #98 |
Rep 75
Anyone running this downpipe with the active autowerke axleback only? Curious to see how those two paired will sound. Looking into going with the autowerke axleback
Instagram: @ninthvision
https://www.instagram.com/ninthvision/ if you're local hit me up for pictures or video |
| 09-04-2020, 06:42 PM | #99 |
![]() 12
Rep 56
I just got the car back from the install. Definitely no turbo lag now but a very different power curve. Pulls a bit harder up top but I feel like I might need a custom map. Mhd stage 1 cut about 2/10ths of a second and this dp cut another half but I'm still getting used to the feeling, very different. What is everyone else running software wise with this downpipe?
kianf2276.50 |
| 09-08-2020, 11:51 PM | #100 |
Rep 348
Car has started to sound better and smell sliiiightly more as I've put more miles on the cat. Hope this is just part of the break-in process.
| 09-14-2020, 02:27 AM | #101 |
Rep 348
Even more smell now. The worst smell is during cold start and for a while till it's warmed up. even then it still smells a little. Hope this is not sign of the cat failing.. It smells significantly more than day 1. Not sure if that's normal across the board...?
| 09-15-2020, 08:36 AM | #102 |
Rep 205,939
It sounds like you need to check your installation for leaks or a bad gasket
kianf2276.50 |
| 09-15-2020, 12:24 PM | #103 | |
Rep 348
| 09-15-2020, 12:32 PM | #104 |
Rep 348
Also.. I've been very careful and paranoid of "warming up the cat" before putting the car in sport as I'm afraid even the stock burbles could damage the cold cat. Is this a baseless anxiety I have or should I continue "warming up" in comfort and getting some heat into the cat before any burbles?
| 09-16-2020, 09:49 AM | #105 |
Rep 205,939
it depends on how sensitive you are to the smell, most do not even notice any smell with the catted downpipe
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() Last edited by mike@x-ph.com; 09-16-2020 at 01:59 PM.. |
| 09-17-2020, 05:48 PM | #107 |
Rep 348
Performance has not been an issue. On cold start if you walk out back the car smells like it's pretty much straight piped. Very similar to a friend of mines catless m235i. If you allow it to warm up a bit the smell goes down but it's still there. I'm not overly sensitive to smell either.. it definietly was not like this day 1 and week 1. I guess it's fine if it's part of the "breaking in" process, I just hope it's not a sign of the cat failing.
| 09-17-2020, 05:49 PM | #108 |
Rep 348
| 09-29-2020, 10:11 PM | #109 |
![]() 12
Rep 56
| 10-01-2020, 10:13 PM | #110 |
![]() ![]() ![]() 129
Rep 448
| Bookmarks |
