08-21-2015, 10:49 PM | #903 | |
Rep 5,262
Comment = The OFF state is stored only within the follow-up time (15 minutes after terminal 15 off). |
08-23-2015, 07:41 AM | #904 |
Rep 6
Enable BMW Apps
Hello,
My new AUS - F22 just arrived and I've been driving it a week. Hoping to get codes to enable BMW Apps when driving...would the video in motion codes achieve this? |
08-23-2015, 10:22 AM | #905 |
Rep 5,262
which apps don't work while driving ?
ah looks like it must be a non-US thing... If you send me you HU_NBT cafd I can do a compare and see if I can find the difference Last edited by pikcachu; 08-23-2015 at 10:51 AM.. |
08-23-2015, 05:50 PM | #906 | |
Rep 6
I'm just ordering some equipment so I'll export the Hu_NBT cafd when it's in. |
09-01-2015, 03:36 PM | #907 |
Rep 167
There are a ridiculous amount of cables available on ebay it seems. Is there a vendor or brand that seems to be regarded as the gold standard around here? Or are they all pretty much the same? Thanks.
2004 Imola Red 330i ZHP 6MT RIP
2007 Jet Black 335i 6MT RIP |
09-01-2015, 04:21 PM | #908 | |
Rep 5,262
it's in the us |
09-03-2015, 01:35 PM | #910 | |
Rep 167
09-19-2015, 10:44 AM | #911 |
Lurker from behind
Rep 42
Hey pikcachu
Is there a way to change scale in sport display?
"Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer"
Walter Röhrl |
09-19-2015, 10:54 AM | #912 |
General
10543
Rep 41,207
Drives: 2018 Alpina B6 650ix GC
Not without Flashing DME with new firmware.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-19-2015, 11:05 AM | #913 |
Lurker from behind
Rep 42
Ok, thanks for the info and big thanks to your help with files.
Today I've coded: Speed to BC GPS sync Sport displays Temperature to BC Brighter halos temperature to tyres Radio/navi off when door opens corner lights complete text/email messages while driving Own ringtone
Walter Röhrl |
09-22-2015, 01:41 PM | #914 |
Lurker from behind
Rep 42
Question to shawnsheridan or pikcachu
Is it possible to activate speed limit info without having camera in rear view mirror? Ie. only using the information from navigation?
Walter Röhrl |
09-22-2015, 02:15 PM | #915 |
Rep 887
Drives: Enzo F23 228i
09-25-2015, 01:59 PM | #916 |
Rep 98
Drives: 12' 1 Series M Coupé
Garage List 2012 1M [10.00]
2014 Porsche 911 Ca ... [0.00] 2007 Porsche 911 Turbo [10.00] 1993 E36 M3 [10.00] 1999 E39 M5 [9.00] 2005 E46 M3 [0.00] 2011 BMW F10 535i [0.00] |
Hey Guys, I need some help because I did something very wrong
I Clicked on "Code" Button in any ECU, it overwrite the changes I had made, and this 2 errors showed up on iDrive: The car is running ok, cant feel any diference at all.. |
09-26-2015, 07:14 PM | #917 | |
Rep 1,503
FBO M235i r
F80 M3 |
09-26-2015, 07:25 PM | #918 | |
Rep 5,262
09-30-2015, 05:52 AM | #919 |
Rep 53
I'm about to take a shot at this. Two questions:
(1) If I screw everything up, is there a way to go back to factory for my car? Save original settings and restore? (2) I have the base/hifi sound system, no Nav (small display), no tech pkg. Is video in motion over USB possible? |
09-30-2015, 06:03 AM | #920 | |
General
10543
Rep 41,207
2) Not possible.
09-30-2015, 07:12 AM | #921 |
Rep 273
Hey fellas -- thoughts on being able to get bmw apps not to force read-aloud mode while driving? Specifically, you load BMW Online, News app... if moving they hide the text and you must use the read-aloud feature. Any coding that can disable that?
//M235ix Alpine White
09-30-2015, 08:27 AM | #922 |
Rep 449
Dealer re-coded car
So the dealer reprogrammed my car and all CAFD's are back to stock. Hard to get used to everything back to stock! I made backups of CAFD's after each item was coded back in 4/2014. It sounds like the recommended procedure is to re-code each item rather than restore the CAFD's?
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) |
09-30-2015, 08:31 AM | #923 | |
General
10543
Rep 41,207
09-30-2015, 09:26 AM | #924 |
Rep 449
Thanks, I was afraid of that. Can I still use the PSdZdata (V52.1+) software from back then?
'17 F80 (RET)
