08-01-2015, 08:17 PM | #860 | |
Rep 5,262
KOMBI | 3000 Anzeige_Konfiguration | CC_RW_WARNUNG CC_RW_WARNUNG_2 controls the first reminder and should probably be greater than CC_RW_WARNUNG. The values for both these are the number of kilometers of fuel left before the warning. Also note the values in e-sys are in hex, so 90km would be stored as 5A. Windows calculator can do the conversion for you. |
08-01-2015, 08:46 PM | #861 | |
Rep 244
08-06-2015, 07:28 AM | #862 |
Rep 13
Drives: BMW 220i MSport Coupé
Hi pikcachu, thank you for this detailed and helpful topic.
I received my 2 the 16th of July () and enjoying it since then, but wanted to be able to do more Finally received my ENET cable and laptop is being upgraded to Windows 10. The only thing that is missing is ESYS and psdzdata. The vendor of the cable provided me with a link to download them (http://pan.baidu.com/s/1gdzc5ij) : ESYS 3.234 and psdzdata 513. Are they the latest versions ? Should I ask Shawn for a trusted link instead ? Since the car is this new, I'm not sure it works if I don't the latest version. Thank you and best regards. |
08-06-2015, 10:28 AM | #863 | |
Rep 5,262
08-06-2015, 10:31 AM | #864 | |
General
10925
Rep 42,952
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-06-2015, 10:58 AM | #865 |
Rep 13
PM received Thanks a lot
Time to code I will try to add/change : - enhanced bluetooth - N55 sound instead of N20 - 5 blink instead of 3 - reduced time to fold mirrors/windows Fortunately I already have the intelligent adaptive xenon and folding mirrors. I may be able to code DVD player since it's listed in my VIN summary, but I only have the small screen (without nav). I'll have a look. Thanks again guys, I'll come back with my changes done Last edited by G35TY13; 08-06-2015 at 11:05 AM.. |
08-06-2015, 11:34 AM | #866 | |
Rep 5,262
Also not sure the N55 will work... on the M235 you can't change ASD to the F80 anymore... but let us know if the N55 works on the N20 |
08-06-2015, 02:05 PM | #867 | |
Rep 13
easy to follow step-by-step instructions helped a lot Now coding ASD... well... there's no ASD xD Thought it was like in the 28i, but no... 20i dosn't have ASD (I'm supposed to search for an ECU called ASD right ?)... problem solved then xD Next... problem, everything is trimmed... since I have the latest version provided by Shawn, as well using E-Sys Launcher Premium 2.1.2, shouldn't this be solved ? EDIT : E-Sys Launcher Premium 2.1.2 didn't let me choose a Car Series (only choice is F999), could this be the issue for trimmed files ? Last edited by G35TY13; 08-06-2015 at 02:18 PM.. |
08-06-2015, 04:08 PM | #868 | |
Rep 5,262
there are some instructions on the files included so that you need to move the date of your PC 4 days in advance to be able to change it |
08-06-2015, 05:24 PM | #869 | |
Rep 5,262
* NOTE: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future." |
08-06-2015, 05:43 PM | #870 | |
Rep 180
Not interested in the F80 sounds or any ASD for that matter.. but why does the thought of not being able to, make me want it now.. lol |
08-06-2015, 05:57 PM | #871 | |
Rep 5,262
Also probably if you get your i-step updated you will lose it too... meaning the ability to change to F80... you don't loose ASD |
08-07-2015, 06:19 AM | #872 | |
Rep 13
Coded successfully : - digital speed - number of blink - closing mirrors and windows with FOB at 300ms I will try the DVD thing later, it's too hot outside (01:15 PM here in Switzerland with 33°C), and the car is outside Fun thing I discovered while coding : my head unit is HU_ENTRYNAV. Does that mean I can actually code the Navigation ? Should I need an activation code like in retrofit ? thanks again |
08-07-2015, 09:46 AM | #873 | |
Rep 5,262
08-07-2015, 08:04 PM | #874 |
Rep 886
Newbie coder here. Firstly thanks to Pikachu for this thread.
I have everything ready in place to start coding. I didn't get the NCD CAFD tool because the download link seems to be missing for the latest version, do I need it? (it seems to be used just to decompile and read?) I'm hoping to code Intelligent highbeams Folding mirrors on lock/unlock Seatbelt chime off Startup iDrive warning screen off Thanks
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793 |
08-07-2015, 08:30 PM | #875 | |
Rep 5,262
try the download link here http://www.bimmerfest.com/forums/sho...&postcount=140 Make sure you use the launcher and to set the right car series on the launcher (not F999) and F020 on e-sys "4) Launcher note: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future." |
08-08-2015, 08:13 PM | #876 |
Rep 404
I think these weren't asked before (unless I missed it) -- trying to code the following:
-Disable amber corners when low beams are on -Disable left/right fog lamps during turning -roll up windows when holding lock button on remote (I can roll them down with unlock, but not up) Does anyone know where to look? |
08-08-2015, 08:46 PM | #877 | |
Rep 5,262
Turn off front amber side markers FEM_BODY 3063 MAPPING_SIDEMARKER_R_OUTPUT fra_v_r (werte = 0E) off Turns right front sidemarker (amber light) off, blinker still works Not sure cause the M235 doesn't have fog lights but maybe disable this Cornering wizard FEM_BODY 3110 ASP_ABA_AKTIVIERUNG nicht_aktiv Activate cornering assistant You need this Close window/roof with FOB FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB aktiv Closes windows + moon roof through Key Fob Close window/roof with comfort access FEM_BODY 3053 KOMFORTSCHLIESSUNG_PA aktiv Closes windows + moon roof through comfort access Close mirror with FOB FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv Closing side mirror with Fob Open mirror with FOB FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv Opening side mirror with Fob It's all on the cheatsheet https://drive.google.com/file/d/0Bwv...hKSWdRTDg/edit |
08-11-2015, 09:06 PM | #879 |
Rep 63
Drives: M235i BSM
not sure if this has already been asked, but is it possible to open windows/moonroof when using comfort access? The same behavior when you hold the unlock button on the FOB?
08-11-2015, 10:50 PM | #880 |
Rep 5,262
