| 08-31-2014, 04:44 PM | #67 |
![]() ![]() 1473
Rep 5,262
Well on the f20 when I turn dsc off the steering gets heavier than in comfort mode. Still need to see if there is any difference from sport to dsc off etc
| 09-01-2014, 07:41 AM | #68 |
![]() 21
Rep 179
| 09-01-2014, 07:48 AM | #69 |
Rep 1,091
OK, so in F22 at least steering remains heavy; since steering and suspension (provided you have adaptive suspension) always go together when changing modes, can you confirm your dampers remain stiff, too?
previous: 2003 E46 330i SMG
| 09-22-2014, 01:02 PM | #70 |
![]() ![]() ![]() ![]() 64
Rep 736
UPDATE: It seems now that on 2015 models, when in Sport or Sport plus and you turn off DSC you no longer go to comfort mode. You now stay in Sport. I verified this yesterday at the dealers M235
2011 335 E90 MSport PPK - retired
2008 M3 - retired 2007 335 E92 - Buy back 2007 X3 MSport - retired 1995 M3 - retired |
| 09-22-2014, 01:44 PM | #71 |
Rep 863
Drives: '19 M2 '21 X5
| 09-22-2014, 02:19 PM | #74 |
TIM YOYO
1548
Rep 3,295
Drives: 2013 M3
Any chance you could post your iDrive software version so the other guys here can compare?
Current: 2026 X3 M50 - B58 Arctic Race Blue / Amber / Atlas Grey /
Past:: 2013 X3 xDrive28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
| 09-22-2014, 02:19 PM | #75 |
![]() 121
Rep 1,259
Nice keep us posted. I would like this update. Takes to many steps to turn off all the helpers.
| 09-24-2014, 12:15 PM | #76 | |
Rep 555
Driving Modes in an MY 2015 (from experience): Eco PRO -- who gives a shit. Comfort -- slow throttle, slow shifts, soft suspension, low effort steering, low RPM upshift threshold, DTC off*, eDiff on Sport (with default config) -- fast throttle**, fast shifts, stiff suspension, high effort steering, high RPM upshift threshold, DTC off, eDiff on Sport+ -- fast throttle, fast shifts, stiff suspension, high effort steering, high RPM upshift threshold, DTC on, eDiff on Traction*** (short press of DSC off button) -- slow throttle, slow shifts, soft suspension, low effort steering, low RPM upshift threshold, DTC on, eDiff on DSC OFF -- (long press of DSC off button) -- slow throttle, stiff suspension, high effort steering, LOW upshift RPM threshold, fast shifts only in manual mode, DTC on, eDiff off *DTC OFF = FULL electronic stability control; DTC ON = REDUCED electronic stability control **It is possible that the faster throttle is simply a byproduct of the higher cruising RPM and upshift threshold. I will see if this is the case the next time I drive. ***I have only used Traction mode a couple of times so I will need to confirm this. What I would like: Custom mode that is enabled by default when using my FOB. Fantasy custom mode -- fast throttle, stiff suspension, low effort steering, low upshift RPM threshold in automatic mode but still with fast shifts, fast shifting manual mode, DTC off, eDiff on If someone ever releases a device that enables you to more specifically configure the cars suspension and drivetrain I will buy it. Immediately Last edited by Celestion; 09-24-2014 at 12:46 PM.. |
| 09-24-2014, 12:36 PM | #77 | |
![]() ![]() 1473
Rep 5,262
at Eco PROthorttle mapping is not a byproduct of the higher cruising rpm... try this... configure "sport" to "only chassis"... now in comfort at constant throttle, switch to "sport"... and you will see the car accelerates by itself a little bit cause of the different mapping... |
| 09-24-2014, 12:39 PM | #78 | |
Rep 1,091
| 09-24-2014, 12:43 PM | #79 |
![]() ![]() 1473
Rep 5,262
| 09-24-2014, 12:43 PM | #80 |
Rep 863
| 09-24-2014, 01:03 PM | #81 | |
Rep 555
I will triple check this just to be sure though. |
| 09-24-2014, 01:13 PM | #82 | |
What goes here?
476
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
| 09-24-2014, 01:18 PM | #83 | |
![]() ![]() ![]() ![]() 27
Rep 841
CHASSIS = dampers, steering DRIVETRAIN = throttle, exhaust, transmission |
| 09-24-2014, 01:41 PM | #84 | |
![]() ![]() 1473
Rep 5,262
in comfort mode put the shifter into "sport" DS mode.... now configure "sport" to either "both" or "only drivetrain" now go from "comfort" to "sport" at constant throttle and you will see the car accelerates by itself.... |
| 09-24-2014, 02:02 PM | #85 |
Rep 863
So can anyone confirm that the 2015's have Sport w/ DSC Off?
We now have one say yes and one say no. |
| 09-24-2014, 02:49 PM | #86 |
![]() ![]() 1473
Rep 5,262
| 09-24-2014, 03:00 PM | #87 | ||
Rep 863
| 09-24-2014, 05:41 PM | #88 | |
Rep 555
I didn't read your corrected instructions before my next drive. However, I can confirm that there are indeed genuine throttle changes (independent of the changed RPM shifting thresholds) in Sport and Sport+ modes. I can also confirm that these throttle changes do NOT carry over into DSC Off mode. That said, DSC Off mode still has the fast gear changes. Fortunately the Sport+ throttle response can be be mimicked by pressing down the gas pedal faster/further. About the DSC Off suspension configuration: To me it feels different from both the Comfort AND the Sport+ configuration. |
| Bookmarks |
