2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Hi-Fi Speaker Upgrade
      12-11-2014, 05:53 PM   #67
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
The HK sail panels are $42.79 each and come with a tweeter. The tweeters are $52.98 and sold in pairs. I suppose I could sell the tweeters for $25, but I'm guessing there is no market for this. I wonder if the parts department will take them back as part number 65139226357 and credit me, but this doesn't seem likely without some cooperation from someone. Maybe my service advisor can help out.
Either that or just buy a pair of standard sail panel covers and route a hole out of them that fits the tweeter. Since the tweeter already has a mesh grill, it will be protected. Just don't know if it will end up angled appropriately.
      12-27-2014, 08:07 PM   #68
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
So I've upgraded the stock subs with the subs from the Jehnert Flatline kit. The sound is incredible. They are not yet broken in, but they play louder and dig much deeper, while maintaining sound fidelity across their range. No muddy mid bass, and the subs reproduce down to 50hz easily.
Time is limited, so I haven't had time to put the door speakers in. Plus I still have to figure out how I'm going to do the doors, since I don't have a proper tweeter mount yet.
The subs were quite a struggle to do the first side. The second side was much easier once I figured out what I needed, what to take apart, etc. I'll do a write up for those interested. There are definitely a few pitfalls you want to avoid with replacing the underseat subs.
Here is a pic of the two subs and the stock enclosure. The top left is the Jehnert and the bottom is the stock.
      12-27-2014, 10:27 PM   #69
akuan99
Drives: 2015 228i M-Sport Track 6MT
Jehnert woofers are known to be one of the best option for midbass response.
I'm getting fairly nice midbass boost from the four 100mm speaker replaced.
There is still improvement needed for the bass but it has not been my priority.
I may replace them later with a cheaper option than the Jehnert ones as they go over $500.
I would use existing sail pieces and drill holes for the tweeters as you can always buy sail piece later if you need to switch back to stock.
      12-27-2014, 11:17 PM   #70
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
I think the sails are filled with foam, so it should be easy to carve out a notch for the tweeters. I'll probably use a circular saw bit to cut a hole and then cover it with black grill cloth.
I'll also be replacing the rear speakers with a nice pair I have from days past and considering the Match pp82dsp for the future if I decide I want more volume.
      12-28-2014, 10:35 AM   #71
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Just replaced the stock (non HK) speakers in the doors and rear deck with 4" JBL GTO 429s. Like everyone else noticed, the increase in sound was immediately noticeable, especially on the high end. Also removed the center deck speaker to get more stereo clarity.
Will post pics later, but even the local installer did not think much of the stock speakers. No tweeters, only midrange 4s. The magnets were horribly small. Very disappointing but I guess they had to cut somewhere to put the rest of the car together.
I think next up is replacing the underseat woofers with Audison or Jehnert, maybe an extra amp to push it all properly.
      12-28-2014, 10:36 AM   #72
akuan99
I would get HK sail if you I didn't have tweeter grills.
My component kit came with two type of tweeter grills and mounts.
Didn't yours come with grills?
      12-28-2014, 10:45 AM   #73
hoppy6698
hoppy6698's Avatar
Anyone know where we can get the Jehnert subs separately in the US?
      12-28-2014, 11:28 AM   #74
akuan99
I believe Musicar in Portland can sell them separately http://musicarnw.com/bmw-upgrades/
I almost bought them for my previous 128i from them.
Keep in mind that the Jehnerts are not true subwoofers and may not be the best option if there is no separate sub installed.
The Focal ones are probably the best ones but they are pricey ($800 pair).
I've been looking for other options and this one looks very promising http://www.crutchfield.com/p_068RTW8...84.html?tp=111
It is well made and goes from 32 to 5KHz which is suitable for midbass and sub frequencies.
The best part is that they are only $200 a pair.
      12-28-2014, 01:19 PM   #75
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Yeah but they are integrated and would sit flat on the sail, aiming slightly downward. I will play with positioning them.
Don Amann at Unexpected Creations / eXquisite Marketing
mypearltpi@aol.com
      12-28-2014, 08:58 PM   #76
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
These are also sold by MusicarNW and you can buy a spacer made by earthquake. 120 each and are supposed to play better down low than the Jehnerts, but less so with midbass. If the mids extend down low enough, then these might work well.
http://www.amazon.com/Earthquake-SWS.../dp/B003R5NS9U
      12-30-2014, 03:33 AM   #77
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Posted a how-to on replacing the subs if anyone is interested in doing this.
http://www.2addicts.com/forums/showthread.php?t=1073803
      01-01-2015, 04:16 PM   #78
huma
huma's Avatar
94
Drives: U11 one day
You don't need line converter if you replace amp with one that accept balanced input like those from JL audio amps.
I recommend getting Technics' hardness so you can do a clean install without cutting any wires.
I will be using a 6 channel amp JL audio XD600 and skip center channel.
It actually sounds better without center channel speaker.
Here is my amp with wire hardness.
I only need to unplug 42-ping plug from the amp and plug the hardness adapter and connect +12V and ground wire.
I've not installed it yet as I'm being lazy and not in a hurry as having done speaker upgrade already has tremendously improved the sound.
Does the JL audio amp fit in the stock location? Considering changing the amp + speakers + subs when I get my vehicle.
Anyone have the link to the focal subs for our vehicle?
      01-01-2015, 04:24 PM   #79
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
JL amp should be small enough to fit.
The focal subs look like a direct replacement:
http://www.crutchfield.com/S-DVjIBr2...IFBMW-SUB.html
      01-01-2015, 05:17 PM   #80
hoppy6698
hoppy6698's Avatar
Anyone have the part numbers and a possible link to the HK sails? Installer is convinced that moving the tweeters up to the sails would definitely improve clarity.
      01-01-2015, 05:59 PM   #81
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Only sold with the hk tweeter.
51337269362
http://www.ecstuning.com/ES2744546/
      01-01-2015, 07:39 PM   #82
hoppy6698
hoppy6698's Avatar
51337269362
Thanks for the link, didn't know ECS had them.
      01-01-2015, 09:38 PM   #83
akuan99
JL Audio XD600/6 amp does fit in stock amp location.
I've confirmed this by removing trim piece and placing map on top of OEM amp but I haven't install it yet.
      01-01-2015, 11:36 PM   #84
hoppy6698
hoppy6698's Avatar
Okay, so finally got the speaker upgrade pics - JBL GTO 429s.
The stock speakers in the JBL foam (very small):
JBL 429s wired up:
Custom spacers:
Mounted:
Thanks to the team at Audio Northwest, Lacey, WA.
      01-02-2015, 09:24 AM   #85
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Nicely done.
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
      01-02-2015, 12:18 PM   #86
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Nice!
      01-02-2015, 03:16 PM   #87
haloeight
Drives: m235i xd perf. ed'n
Thanks a lot for this. Very helpful.
      01-02-2015, 08:04 PM   #88
huma
huma's Avatar
94
Drives: U11 one day
Thanks, $400 a sub is expensive. Do you know if Crutchfield offers coupons or something? lol. I tried searching online, but it seems like CF and one other company is the only ones that carry the Focal sub.
