02-18-2018, 10:18 PM | #45 | |
Rep 245
Basically, I'll sacrifice it for the looks and having the square setup I want. If I'm alone in the car my music is on and pretty loud 100% of the time. If I'm not alone it's only with my gf and I already told her to get ready for the noises which doesn't bother her since she dives a '04 civic so still an upgraded ride. Good luck on the search and let us know what you find.. If I can get an alternative down the road I might if the plates end up being annoying. I'm used to driving 2G Eclipse's so you can't get much more noises and rattles than that! |
Raymondo123467.50 |
03-12-2018, 05:15 AM | #46 |
Rep 176
I should be receiving the product very soon.
SteveInfante604.00 |
06-29-2018, 02:07 PM | #47 |
Rep 2,700
06-29-2018, 07:43 PM | #48 |
Rep 986
I have the same model, i use GC camber plates, and Dinan springs.. Very nice combo IMO. I would bite the bullet and do either GC or Vorshlag camber plates while your doing the springs You'll notice an increase in noise the first week or two, and then you'll forget about it.
07-08-2018, 07:39 AM | #49 |
Rep 566
In case anyone is wondering if RWD bushings fit xDrive front lower control arms - yes, they do.
They appear to be the same size, no additional hardware required. I test fitted camber-adjustable both SuperPro and PowerFlex bushings, they fit, but am currently running PowerFlex p/n PFF5-1902G which is significantly stiffer than the stock. The SuperPro ones appear to be softer than the stock so I didn't actually use them. The ride is somewhat harsher/stiffer, the steering is noticeably more responsive and there is certainly less understeer. I was only only able to get -1.15 camber symmetrically (I could get -1.15 one side and -1.45 the other so I made it equal at -1.15). Last edited by x233; 07-08-2018 at 11:22 AM.. |
07-08-2018, 09:26 AM | #50 |
Rep 1,931
would also point out that using a stiffer sidewall tire will help a little with the un even wear from the positive camber.
i had run a nt01 on stock suspension with spacers and had even wear across all tires. So don't always jump to needing a full suspension because MPSS street tires get destroyed on the track.
www.nybmwcca.org
07-09-2018, 11:06 AM | #51 | |
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
Note that although the camber/control arm bushings fit xDrive, when I tried to fit the Superpro tension strut/caster bushing (SPF-4306k) it was too long to fit into the subframe mount on the car. The bushing pressed into the arm fine, but couldn't be mounted to the car. This is weird, because Superpro's European site said it should fit. With the Superpro bushing I noticed no increase in NVH, and a very slight steering feel increase (not really noticeable unless thinking about it). I'm trying to get a hold of KMac's +/-2deg camber bushing, and have given them measurements of my caster bushing to see if I can get an adjustable one there too. Interestingly, KMac said that Raymundo received both the camber and existing KMac caster bushing for his xDrive car, and didn't report any fit problems with either. |
x233284.00 |
07-11-2018, 08:29 PM | #52 | |
Rep 566
OK, now I am not even trying those caster-adjustable SuperPro ones though I, too, have them. Also, I wonder what's wrong with SuperPro. Polyurethane is supposed to be stiffer than the stock rubber and they don't look that. Your input only confirms my initial impression. |
07-18-2018, 10:25 PM | #53 |
Rep 2,700
I want to report that I baught and installed Kmac Camber bushing kit on my m235i Xdrive and we managed to get -2 degrés of camber ! Here are my final specs:
Front -1.98 camber 0.12 degrés total or 1/16 of toe per side Rear -1.8 camber 0.12 degrés total or 1/16 of toe per side This totally transformed the way the car handles ! And no ill effects or sounds or anything. Your results on camber may vary, I had one side at the end of the adjsutment and the other side with .25-.35 left in it.. Now I can't wait to go trough my 235/45-17 RE71r to install new 245/40-17's |
07-19-2018, 11:28 AM | #54 | |
Rep 3,548
I'm still trying to get my hands on a thrust arm bushing to measure so they can make an xDrive caster bushing. My dealer didn't have any in stock that I could measure the other day. |
07-26-2018, 10:06 AM | #55 | |
Rep 260
07-26-2018, 10:07 AM | #56 | ||
Rep 2,700
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
09-04-2018, 07:56 AM | #57 |
Rep 4,529
09-05-2018, 03:16 PM | #58 |
Rep 566
In theory, yes. Still, damage or premature wear of any part as a result of it has yet to be reported. It's a rather common modification for various cars but I don't think I've ever heard of anything failing due to that. Maybe the difference is too small to cause anything to fail. I'd call this a safe one, at least with the usual adjustment range of about 1 degree.
PS: bmw makes oem camber correction steering knuckles, min 30 min, plus 30 min, basically the same idea, and those are apparently well within the safety margin. Last edited by x233; 09-05-2018 at 03:31 PM.. |
09-05-2018, 05:50 PM | #59 | |
Rep 4,529
-30min to -2 deg is still a sizeable change in geo
Current '22 X3M LCI.. |
09-05-2018, 07:00 PM | #60 |
Rep 2,700
I don't have the car anymore so we will never know...
09-05-2018, 08:24 PM | #61 | ||
Rep 2,700
09-05-2018, 08:40 PM | #62 |
Rep 566
03-31-2019, 09:00 AM | #64 | |
Rep 96
With longer arms it's easy to see how the entire wheel would move outward. But if the bushing goes in the ball joint, doesn't that only tilt the bottom of wheel out? And the top of the wheel closer to the strut. Last edited by funseries; 03-31-2019 at 09:06 AM.. |
