2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheel spacer testing - 5mm, 10mm, 12mm, 15mm
      08-02-2014, 01:44 PM   #45
HX_Guy
Drives: 2014 BMW M235i
The dust cap has to come off in order for a 10mm or 12mm spacers to fi ton the rear. Even the 15mm squeezes the dust cap, at least it did with the Ubercentric ones, H&R may have a different fit.
I don't mind removing the dust caps, really don't see the point of them honestly. I'm sure others will chime in and say if BMW engineers say they are needed, then they are needed and BMW wouldn't waste money on useless parts and maybe it's true...I just don't see why BMW's need it when no other car does.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      08-02-2014, 02:18 PM   #46
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
Got mine on... 12mm all around...
Appreciate 5
AlexM240i103.00
WillOs7.00
peediR1.50
KennyFSU1104.00
      08-02-2014, 02:23 PM   #47
pikcachu
pikcachu's Avatar
1406
had to put the dust cups on the spacers with some silicon glue
      08-02-2014, 10:02 PM   #48
HX_Guy
Nice, you did it! How are you liking the 12/12 setup?
BTW I tried that silicon stuff though, though mine was epoxy. The first time I went to mess with the spacers, the caps fell off..guess the epoxy didn't quite resist with the heat that those things probably heat up to.
2014 BMW M235i 6MT
      08-02-2014, 11:22 PM   #49
pikcachu
pikcachu's Avatar
1406
I really like it.... not too aggressive...not too tame...
The for wheels are still on
      08-03-2014, 05:34 AM   #50
horsepower_and_hounds
Drives: BMW
Originally Posted by HX_Guy View Post
Took all the spacers off earlier this morning to send them back, between improper fit and some vibration issues, I've decided I'm going to go with a trusted brand like H&R over these Ubercentric.
I decided against the 15mm front and 12mm rear...will do 12mm front and 10mm rear, but I am thinking maybe 13mm front would be a good compromise. Definitely 10mm rear though.
BTW the car looks terrible now without any spacers...just looks so weak, I don't know, looks so off. Spacers are definitely a must, or aftermarket wheels that are either wider and/or better offset than stock.
What was improper about the fit? Thickness, dust caps, if you can explain. Also what exactly can a spacer do to contribute to road vibration if it was not already there? Thickness variations causing small wheel run out frequency?
Just curious
      08-03-2014, 10:20 AM   #51
pikcachu
pikcachu's Avatar
1406
if the spacer is not balanced you will get wheel vibration....as well if you don't clean the hubs and the spacer doesn't sit flush against the hub
      08-03-2014, 11:22 AM   #52
HX_Guy
Just curious
On the 5mm spacers, the stud holes were not precise and one of the lug nuts would bind up when tightening it.
On the 12mm spacers, there would be vibration in the steering wheel between 40-50 MPH only and on the 15mm spacers, there would be vibration at 80 MPH only. Could be they weren't exactly in thickness or in balance, who knows.
2014 BMW M235i 6MT
      08-03-2014, 03:41 PM   #53
Drives: BMW
Cool...let us know how the next ones work out...I didn't see any of the spacer manufacturers claim they balanced their spacers. Also I think the closer to the spindle center an item is (small diameter) the less effect rotating weight has on balance. But not sure about run out
      08-03-2014, 09:35 PM   #54
pikcachu
pikcachu's Avatar
1406
well i mean the probably build them to be balanced... else it will create vibration when it spins
And some might be better balanced than others
      08-05-2014, 02:43 AM   #55
Roshi
Drives: 2015 M235 - MW, 6MT.
Pikcachu - what size lug nuts did you use?
      08-05-2014, 10:17 AM   #56
pikcachu
pikcachu's Avatar
1406
didn't check they came with the spacers... http://www.burgertuning.com/BMW_wheel_spacers.html
but there seem to be about 20-15 mm longer
      08-13-2014, 03:23 AM   #57
Roshi
HX_Guy - did you ever get new spacers? Or just looking to get new wheels first?
      08-13-2014, 04:58 PM   #58
HX_Guy
Looking at wheels now to where I wouldn't need spacers.
2014 BMW M235i 6MT
      08-16-2014, 06:47 AM   #59
Drives: BMW
What is being done with the spacers? I am still thinking of doing 12f 15r or close to that
      08-16-2014, 12:28 PM   #60
HX_Guy
I returned them back to Amazon.
2014 BMW M235i 6MT
      03-15-2015, 09:45 PM   #61
harkes
harkes's Avatar
China
1092
Drives: M135i, E39 M5, NSX and AE86
How about 15/15 - is that a no-go?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      03-15-2015, 09:54 PM   #62
pikcachu
pikcachu's Avatar
1406
It's just a matter of taste... those will stick out a little bit more...
      03-15-2015, 10:42 PM   #63
harkes
harkes's Avatar
China
1092
pikcachu looking at your pics it looks like the car can easily handle 15/15... just wondering if it will cause clearance issues..?
(A Dane in China)
      03-15-2015, 10:43 PM   #64
pikcachu
pikcachu's Avatar
1406
dont think it will cause any issues
      03-20-2015, 05:42 PM   #65
Ramathorn
Ramathorn's Avatar
Drives: 2015 m235i
First, thanks for all of the testing that has been done with the various sizes of wheel spacers.
Does anyone know how far can you space on the front and the rear before the tire would be at risk of coming up and impacting the fender/quarter panel?
I love the look, but the roads around me sometimes aren't the greatest, so I'm curious how far I can space out without causing problems going over larger bumps/potholes.
      03-27-2015, 05:34 AM   #66
tencazzo
Drives: BMW 220i M Sport
If someone interesting, there are new spacers from H&R from end of 2014 where you don't need to take off dust cups.
I have another question. I put 10 mm spacers on standard 461 wheels and got the feeling that handling became very sensitive for trace changing, like car goes to side where the trace not that flat. Is it a normal thing by using spacers and will it be gone without spacers, considering the fact that I rode 205/50 in winter and in summer now is 225/40 on the front and 245/35 on the rear witch is already much wider without spacers?
