BMW 3-Series (E90 E92) Forum
Rain sensor wiper - manual adjustment ??
11-16-2005, 10:53 AM | #46 | |
Rep 39
11-16-2005, 11:04 AM | #47 |
Rep 5,732
Just to add to the general confusion:
I am really not sure if I have this problem - on the one hand, when I adjust the intensity, it does seem to wipe faster WHEN THERE IS RAIN (most noticeable between setting 1 and 3 of 4). However, as the rain recedes or stops, it slows down or stops. Until now I thought this is what it it supposed to do. The as the rain picks up it will start wiping again but not as intensily as the setting I had previously set, so I have to "re-set it" by putting it again on the lower setting, then as the rain gets harder, move up the scale. Again, I thought this is what it was designed to do |
11-16-2005, 03:13 PM | #48 |
Rep 513
Let me add an extra perspective to this debate. According to my dealer, the sensor not only controls the wipers but also the auto headlights.
When my car went in for the CIP 19 upgrade, I asked for the wiper sensitivity to be increased and for the auto headlight sensitivity to be decreased, as I've ended up driving along in the morning with the sun shining and my headlights on! He said that increasing the sensitivity of the wipers increases that of the auto headlights and that the 2 cannot be adjusted separately. His recommendation was to make the wipers more sensitive as this is a safety issue and to control the headlights manually! In the end, I asked him to leave them as they are. |
11-16-2005, 03:34 PM | #49 | |
Rep 39
I don't even think the two systems use the same sensors. I believe there are two light sensors that detect ambient light to control the auto headlights. These are always functioning. It's my understanding that the auto-wipers rely on an IR beam that projects out from the back of the rear-view mirror and onto the windshield. This IR beam then reflects off of the windshield and unto an IR sensor. The characteristics of the reflected beam vary with the amount of water on the windshield, thereby supposedly allowing for the auto-adjustment. Further, unlike the normal light sensors, this IR system is not on all the time. You have to manually activate it by the button on the stalk. Furthermore, I can control the sensitivity of the auto-lights via iDrive. In contrast, the sensitivity adjustment for the wipers is done right at the stalk. I highly doubt the two adjustment systems are connected. It also doesn't make sense logically. Can anyone with more substantial knowledge confirm or deny any of the above? |
11-16-2005, 03:47 PM | #50 | |
Rep 152
2023 330i Xdrive, phytonic blue/ tacora
11-16-2005, 03:58 PM | #51 |
Rep 44
I have a new E90 325i SE (UK spec) and I alos can't get the sensitivity sdjuster (on the stalk) to make any difference at all. Sometime the wiper frequency on 'auto' is ok, other times too fast, others too slow. If only it would allow me to adjust, I reckon it'd be ok. Manual says you can adjust.
11-18-2005, 02:37 PM | #52 |
Rep 78
Wac77:
You are right, I check again and there are distinct settings on the stalk. But there are only 3 settings total (including the top and bottom settings) instead of 4 that most mentioned ?? But it still does not do anything to change the frequency at all. |
01-28-2006, 12:57 PM | #54 |
Rep 49
same problems
Im having the same problems as many of you have had. The sensitivity adjustment does nothing to the speed of my wipers no matter what the intensity if the rain is. I put my BMW in to have it checked, and the technician said that I probably will not see any VISABLE change in speeds of the wipers. But after reading some who post that the changing the sensistivity does change the speeds of their wipers, I feel like I was just told a bunch of crap. Maybe if we all complain to BMW enough.. they will look into this matter and figure out what is wrong.
01-28-2006, 01:33 PM | #55 |
Rep 90
Very timely thread for me!
I have a December production 330xi. I've so far been pleasantly surprised that the rain sensor has got the amount of wiping just about right (I live in Vancouver and have yet to drive the car when it is not raining!). However, last night driving on the Upper Levels highway the wipers did not seem to be wiping often enough. This is interesting as most people say their wipers are hyperactive. Mine are just about right except for last night. So I played with the adjustment. I think it speeded them up a little. But the effect was so subtle that I think it could have been the placebo effect! The bottom line is that if the frequency adjustment does anything it is too subtle a change to be really useful. For me the best fix would be for BMW to allow the sensitivity adjustment to have a greater effect on the rain sensor sensitivity. The fact that I live in a temperate rainforest together with my being fairly happy with my rain sensor performance most likely indicates that I have a defective unit. I'd better avoid software updates until spring arrives! ;-) |
01-30-2006, 09:14 AM | #56 | |
Rep 2,168
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
