11-25-2021, 09:25 AM | #595 | |
14526
Rep 10,252
This is possibly your best troll yet! MB/Mercafia strikes again apparently! |
11-25-2021, 09:35 AM | #596 |
Rep 2,715
Drives: Built not Bought 04 Z4 VF. E70
Dickie has laser eyes. Eyes don't lie apparently. Wow, that statement is so out there it's hard to quantify.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
11-25-2021, 10:06 AM | #597 | ||
Rep 4,810
Drives: BMW
11-25-2021, 12:20 PM | #598 |
General
66632
Rep 21,538
RB did have a small problem with their drs activation arm being too stiff making the moveable wing flap at times to vibratate forcing the team to revert to an earlier wing for more stability. This has now been modified for the latest wing to work optimally.
///M Power-Belgium68557.50 |
11-25-2021, 02:19 PM | #599 |
General
66632
Rep 21,538
It's all very well for Masi to stand up for the marshall waving a yellow erroneously inside the barrier but Horner was spot on speaking up as Gasly continued to drive as not to impede other cars so the warning was unjustified. Max and BOT should never have received grid penalties, Masi simply overreacted unnecessarilly.
11-25-2021, 02:22 PM | #600 | |
Rep 7,920
So the Mercedes may not be the fastest on track but it certainly up there hence why you see it being able to close the gap on nearly every car on the field. Then nothing else on the field holds a candle to the w12 in terms of downforce generation (redbull excluded) so it can out brake and out corner the rest of the field hence why overtaking was so easy looking (if you're not Bottas). So that's the logical explanation based on given facts in formula 1. Next the figures are from the F1 taken radar traps, the same figures you see during the races in the bottom corner of the screen. So they've been taken via radar or lidar, which is much more accurate than what you see because you're insanely biased against Mercedes and so far you've only attributed everything to top speed and neglected every other factor. Again all you've provided was "I saw this", I "I saw that" etc etc but no data. You literally have nothing to stand on, except your unnatural hate towards Mercedes in this debate.
11-25-2021, 02:24 PM | #601 | |
Rep 7,920
deleted_397282_c43ae5ea84160.50 Steeler2442.00 |
11-25-2021, 03:11 PM | #602 | |
General
66632
Rep 21,538
11-25-2021, 03:17 PM | #603 |
Rep 7,920
Highlight the portions that is "gobbledegook" and explain why with science and facts. If you can't then you're full of yourself.
minn1914526.00 |
11-25-2021, 03:37 PM | #604 |
General
66632
Rep 21,538
11-25-2021, 03:42 PM | #605 | |
Rep 7,920
How do I hate RB? Because I am defending mercedes against baseless accusations? I would defend any team even RB if accusations are baseless, but you guys literally only bully mercedes so they are the only ones who need defending.
minn1914526.00 |
11-25-2021, 03:45 PM | #606 |
Rep 7,920
https://the-race.com/formula-1/mark-...d-bull-claims/
This one goes into a detailed analysis on the speed delta between mercedes and redbull, and it is nowhere near the "unraceable" 20kph+ difference that horner says it is.
minn1914526.00 |
11-25-2021, 03:49 PM | #607 | |
General
66632
Rep 21,538
11-25-2021, 03:59 PM | #608 | |
Rep 7,920
And debunked again, if you were in a real debate that would have been the end of it the moment you started changing the subject and unable to counter the data. Also note, I have not even made an attempt to pull redbull down, I am debunking your myths about mercedes and used relational comparisons to redbull.
11-25-2021, 04:14 PM | #609 | |
General
66632
Rep 21,538
11-25-2021, 04:24 PM | #610 |
Rep 7,920
Common technique to deflect attention away from yourself and change the subject. The data doesn't lie and I just dismantled your "jet mode" talking point, and there was not a single thing you could counter with.
Call me what you want I really do not care, it doesn't bother me, and it doesn't change the truth of your lies.
11-25-2021, 04:27 PM | #611 | |
General
66632
Rep 21,538
11-25-2021, 04:33 PM | #612 |
Rep 2,715
11-25-2021, 04:38 PM | #613 |
Rep 7,920
Yet I am the only one able to provide facts and data unlike you.
11-25-2021, 04:43 PM | #614 |
General
66632
Rep 21,538
11-25-2021, 04:57 PM | #615 |
Rep 7,920
I'm only defending Merc and debunking the lies about the supposed jet speed and how they have abnormally high speeds, and if it's a heap of s*it why can't you debunk it with facts?
Ah yes because the truth hurts. And where have I put RB down? It's not my fault the data shows that they're near the bottom of the pack in terms of top speed. Data doesn't lie. They usually have better cornering speeds vs. mercedes hence they gave similar race Pace, but in Brazil and Qatar Mercedes managed to match or exceed that cornering speed and that's why they came out on top as they now are faster and corner better. Btw look in the mirror you're projecting again, you guys are the only ones who have been putting out hate and degrading comments towards Mercedes and you don't seem to care.
Steeler2442.00 |
11-25-2021, 05:01 PM | #616 | |
General
66632
Rep 21,538
