10-23-2015, 11:19 AM | #551 |
Rep 447
Each notch I believe is .3 boost, so going from b to d is a .6 boost increase. If on 93 octane should be ok but each car and gas quality is different. You won't blow up your engine, try it for a full tank and if getting erratic results or CEL then dial it back down. Computer will pull power when you've gone too far.
10-24-2015, 11:57 AM | #553 | |
Rep 447
Each notch is .3 lb of boost pressure increase not 1.3 bars. So, no I think you misunderstand if standard you are seeing 14.3 then setting D would perhaps get you 14.9 not 18. I think standard is about 3.5 psi of boost over stock so D would be 4.1. 18 psi would not work at all on 93 octane and stock downpipe.
10-26-2015, 10:09 PM | #555 |
IG @bmwF9xG80
3859
Rep 7,614
+1 kdog26372 is correct .3 boost each increase
My RC for my N20 came in C , I have tested each setting up to 4 but have not gone past that. Test each setting for at least 100 miles and hopefully you have a OBD2 Dongle to measure your psi.
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
01-13-2016, 07:17 AM | #556 | |
Rep 1,091
previous: 2003 E46 330i SMG
01-13-2016, 11:14 PM | #557 | |
IG @bmwF9xG80
3859
Rep 7,614
60-130 6.5s X4M
01-14-2016, 08:53 AM | #558 | ||
General
13506
Rep 19,005
While on the N20/N26, the harness have 3 sets of plugs which color labeled to connect to TMAP, MAP, and MAF sensors.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEAL!! | Akrapovic 10% Off SALE until Oct 15th 2024 MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-01-2016, 11:48 PM | #559 |
Rep 1,160
Really tempted to pull the trigger on the RC Ultimate but I drive to and from work in constant traffic (50 miles a day). Currently getting 19 MPG average... I was curious if anyone has any similar experiences and how the mpgs are fairing after the tune.
02-02-2016, 08:01 AM | #560 | |
Rep 809
02-02-2016, 09:17 PM | #561 |
Cone Killer
87
Rep 210
You're doing better than I am. Similar driving as you and I get 16.1. I've got the RC Ultimate but I was getting exactly the same before fitting it. The car feels a decent amount faster with it so I guess I should be thankful it's no worse
02-03-2016, 01:34 PM | #562 | |
Rep 1,160
There were a few posts in the past about discount codes. Think it was ROBNYC?My girlfriend's birthday is on the same week as Valentines so if my wallet survives that, would be great to have it ready. |
02-03-2016, 01:43 PM | #563 |
Rep 447
I am not sure why anyone would buy the RC Ultimate over the AA8 tune. They are the same price and one controls boost by RPM while the other does not. You get more for the same price with AA8. I've tried/had both and AA8 has been the better tune. The extra wire adds all of 5 minutes to the install time.
02-03-2016, 04:32 PM | #565 |
Cone Killer
87
Rep 210
02-03-2016, 05:39 PM | #566 | |
Rep 447
Next is the method of altering the map up or down. RC you have to disconnect the tune and take out 8 tiny screws and then turn a dial inside the box. AA8 has the dial easily accessible on the outside. Not that you change the tune a bunch, but simply a better design. Finally the AA8 mounts to an existing bolt under a cover by the passenger side. The RC really has no method of mounting other than zip tie to wherever you find a place for it, most likely in the hot engine bay. I can't say I'd recommend a swap if you've already paid for the RC, but for new buyers I see zero advantage and a few disadvantages actually of the RC vs. the AA8 for identical prices. No stage 1 tune is going to show any better dyno numbers than others really. They simply up the boost and you can adjust how much upping the box does (JB stage 1, RC Ultimate and AA8). The AA8 to me is better because rpm specific boost changes makes sense to smooth out the power delivery and with its ease of tune adjustment. If adding downpipe and/or E85 mixes none of these stage 1/1.5 tunes will give you the best results; really need stage 2 JB4 for that. Just my 2 cents.
02-04-2016, 01:24 AM | #567 | |
Rep 1,160
That being said, all of these would show up if they ran a diagnostic so I might not buy any of them out of paranoia. |
02-04-2016, 11:56 AM | #568 | |
Rep 447
02-05-2016, 10:22 AM | #569 | |
IG @bmwF9xG80
3859
Rep 7,614
60-130 6.5s X4M
02-05-2016, 11:56 PM | #570 | |
General
13506
Rep 19,005
I have them in stock ready to install in your car.
02-06-2016, 04:17 AM | #571 |
Rep 1,091
About using or not using the CAM sensor in addition to MAP/MAF: back when I had N20 in my now gone 528xi (for which I craved for every bit of additional performance), I tested another of these basically the same boxes - namely the Speedbuster, which also added CAM in its later model (I tested both - with and without CAM sensor). Frankly, using by butt dyno, no difference at all. Both were equally bad in lacking any linearity in the extra power delivery - they increased the initial lag, and then rocketed my F10 like crazy (which was sometimes even dangerous). So - while perhaps modulating the extra boost according to RPM might be better for the engine health - no spectacular addition of extra power (or smoothness) compared to MAP/MAF sensors only (at least with Speedbuster, but - like I said - they are all the same imho)...
02-06-2016, 04:52 AM | #572 |
Rep 1,091
Following the Speedbuster, I used the RC Ultimate on my N20 F10 quite a lot and found it programmed better - the boost started earlier, so less hesitation and a very distinctive pull even in Comfort mode and RPM just above 1,200 - all that improving power delivery linearity. Since I replaced the 528xi with my current M235i, I still had the RCU collecting dust - but finally some 2 months ago I sent it to the Manufacturer for reflashing for N55. They charged me for that and for the cables (the latter being strange, as they kept my N20 cables); anyway - including shipment - it cost me some Euro 100. On the day it came back, I visited their webpage seeking some installation instructions in the M235i - only to find out that they have dropped price, and include one free reflash as well as engine warranty (!!!). I was mad, but unfortunately my reflashed RCU is considered a "previous model" and all those goodies don't apply
Anyway, I'm going to test it on my M235i soon - any advise on the best placement of the RCU box? I'd be grateful for your solutions guys (perhaps even with some pics) -TIA. Piotr
