05-19-2015, 03:05 PM | #441 | |
Rep 447
05-19-2015, 05:28 PM | #442 | ||
Rep 312
05-20-2015, 02:10 AM | #443 |
Rep 447
Hard to say, but if level d is best for me on 93, don't see how 91 on level d would be a good idea. You aren't gonna blow up the engine, the ecu will simply adjust and make things feel lumpy and then you know you've turned the dial to much. On 91 I'd stick with base setting of b, but I didn't design the thing, but I also believe that was direct recommendation from RaceChip too.
05-20-2015, 02:08 PM | #444 |
IG @bmwF9xG80
3859
Rep 7,614
I second kdog26372 pretty much in all !
Racechip recommends 98RON which is 93 Octane but for 91 octane users definitely stick with B for a tank, go to C for a tank and try D for a tank. Modded F would be best, stock car D/E should be the max but of course depends on your octane. For example ethanol-free 91 octane might be the same as a 10% of ethanol mixture 93 octane.
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
05-28-2015, 05:39 PM | #446 |
Cone Killer
87
Rep 210
06-06-2015, 01:52 PM | #450 | |
Rep 447
I've moved back to B setting as car was pulling power sporadically on D when it was mid-80's. So I'll stick with B setting for summer and then go with D for other 3 seasons. Runs smooth in B setting even in hotter temps again.
06-08-2015, 11:17 AM | #451 | |
Rep 853
What about people with 91 pisstane and at altitude(~4500ft) Isn't B the lowest setting?
CURRENT: 2019 Tesla Model 3 Performance
RECENT PAST: 2016 F80 Austin Yellow (6MT) / 2017 F80 Atlantis Metallic (DCT-ZCP) / 2017 Challenger Hellcat 8A / 2017 Focus RS/ 2017 Shelby GT350 / 2018 Audi TTRS / 2018 Raptor Crew Cab / 2020 X3M Comp |
06-08-2015, 11:37 AM | #452 |
Rep 447
B is how the thing came from Racechip yes. I believe RaceChip tunes using 93 octane, they are based in Germany and better gas is assumed available. My car ran best at the D setting on 93 octane, but when it got in the 80's I did notice computer pulling things back after 2 hours of stop and go; don't have those issues on stock setting. Perhaps most tunes without upgraded intercooler would get some additional heat soaking on higher boost. Hell even Dinan tunes assuming 93 octane I think. The computer adjusts based on fuel, heat and I'm guessing 100's of factors. I'd think 91 at higher altitude and crappy gas is just going to be best with a flash tune or stage 2 tune like JB4 as it can control adjust what is best for your exact conditions/fuel/altitude. The stage 1 tunes are best for 75% of the markets with good gas and not living at higher up. My 2 cents.
06-08-2015, 11:49 AM | #453 | |
Rep 853
06-09-2015, 09:56 AM | #454 | |||
IG @bmwF9xG80
3859
Rep 7,614
I also went back to stock (C) for me but have since driven 2 tanks and increased to D.. will leave it at that, going to the drag-strip this friday might or might not increase to E since I have another 2 tanks on D too. Quote:
60-130 6.5s X4M
06-09-2015, 02:06 PM | #455 | |
Rep 853
I emailed Burger, they said they recommend BMS stage 1 and said it will be just fine with 91 and elevation as its only an additional +3psi over stock.
06-09-2015, 02:29 PM | #456 |
Rep 447
There is no way to tell, unless another user in similar elevation and same octane have tested the tune, it's all speculation. Couple options for you; buy a tune with a money back guarantee and try it out yourself, if it runs good keep it, if not, pay restocking fee and move on. Or you could by a used stage 1 tune, again if it works well keep it, if not you can probably resell it for the same used price you just paid. You aren't going to blow up the engine with default setting of these stage 1 tunes, the BMW computer will interfere if things are too far out of spec.
06-09-2015, 02:33 PM | #457 | |
IG @bmwF9xG80
3859
Rep 7,614
Also, if its shipped at a certain setting and you only have 91 octane then I would leave it at that setting. If you have any issues go down a notch. I have tested my N20 from stock setting in the winter to the very high setting (3 numbers before the maximum). C, D, E, F, 0, 1, 2, 3, 4 .. didnt move to 5, 6, or 7 Lowest is 8, 9, A, B,
60-130 6.5s X4M
06-13-2015, 03:22 PM | #458 | |
IG @bmwF9xG80
3859
Rep 7,614
AlexGT The Best Fuel Additive Octane Booster Torco Accelerator
I used 32oz of this yesterday with half tank of Shell V-Power (93 Octane) and my god everything was even smoother and I felt an instance bump. Buying another 32oz Quote:
60-130 6.5s X4M
06-14-2015, 01:41 AM | #459 | ||
Rep 809
Proud BMW owner
E87 130i E90 LCI 320d F22 M235i F15 X5 30d F30 LCI 320i MSport G05 X5 30d MSport |
06-14-2015, 02:45 PM | #460 |
IG @bmwF9xG80
3859
Rep 7,614
I got it off ebay =D
60-130 6.5s X4M
06-20-2015, 05:02 AM | #461 |
Rep 193
Hi guys
Quick one, I've got the BMS s1 installed and it's great, but it's now time to install the RC ultimate in Do I need to first need to remove the BMS s1 harness and connect the plugs back to standard before plugging in the race chip? Ie must I drive it around normally in std a bit before connecting the RC or can I just connect it straight in as I disconnect the bms s1 harness and take her out for a test? Can't wait to try out this baby! Thanks |
06-20-2015, 08:46 AM | #462 |
Rep 41
Just for those wondering, I ran my M235xi on F for a few hundred miles (MPE, no other mods) and it ran surprisingly well. Felt fast as hell too. I ended up taking it back to E for long term reliability, and because it feels smoother. F would sometimes skip a beat, or hiccup. I never felt like the engine was running poorly, just not as smooth as a BMW should feel. E is still plenty fast, and much smoother.
