2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums Off-Topic Discussions Board Home well systems?
      02-09-2024, 01:49 PM   #23
spazzyfry123
spazzyfry123's Avatar
4379
Drives: Here and There
Originally Posted by UncleWede View Post
Urban Defender from Sweetwater. Primary sediment filtration that I change the filter about every other month and it comes out all red and nasty. The main tank is full of carbon mini balls. Can replace those, but generally I replace the whole system about every decade.
The wife complains when I don't replace the pre-filter often enough. She starts to detect water spots. We have pretty hard water.
It's not a personal well, about 150 of us share the system. At teh well head, we only inject chlorine to CA-mandated standards. The Defender filters that out, and would protect from the MTBE, should that cloud ever reach our aquafer.
Mine is being drilled (I think) next week or the week after. No tests or anything done of course, so not sure what we do/don't need. I've been looking at a few brands and systems. Not sure what we'll need, but getting prepped.
      02-09-2024, 02:14 PM   #24
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Your driller will also test the water once they hit it? I think I would want that done before they installed the pipe and well head. Certainly don't need to pump non-potable water out of the ground.
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
Llarry16833.50
      02-09-2024, 03:40 PM   #25
tranquility
sportscars only
tranquility's Avatar
Drives: 2011 Z4 sDrive 35i
Originally Posted by vreihen16 View Post
It bears mentioning that our SC retirement tree farm on the motorboat lake has municipal water and gigabit Internet fiber sitting at the curb when we decide to build. My DW is tired of working the private water plant in our basement dungeon.....
Oh, it doesn't bode well for noobs like me when you have an expert at home and she's had enough of trying to purify the well.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
vreihen1615626.50
      02-09-2024, 06:25 PM   #26
spazzyfry123
4379
Fair point! I honestly don’t know.
      02-09-2024, 06:35 PM   #27
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
Key word is RETIREMENT house, and I don't blame her for not wanting to do one of her many former careers.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
      02-16-2024, 12:23 PM   #28
spazzyfry123
4379
As a follow up, we drilled today.
265 feet and 20 gallons a minute.
vreihen1615626.50
      02-16-2024, 05:08 PM   #29
vreihen16
vreihen16's Avatar
Out of curiosity, what was the total cost?????
      02-16-2024, 05:20 PM   #30
Weather Man
Weather Man's Avatar
1279
Drives: BMW M4 Competition AWD
160 feet down for my well, going on 23 years. Replaced pump once. Make sure you get a big enough pump to support lawn irrigation. I have a big yard with 22 zones and have run a 1 HP pump since the get go. My water is iron free, but I do have manganese that has to be run through a softener designed for it. I also use a regular salt-based softener. If the well hits water shallow that has bad iron, they can keep drilling and often find better water deeper. Make sure you use a good-sized pressure tank, it helps with the softening. Good luck!
      02-16-2024, 05:53 PM   #31
spazzyfry123
4379
Should be somewhere around $9k all in. Drilling, pump, tank, sediment filter, all connections, electrical, etc.
I'll be addressing full home filtration independently pending water testing.
vreihen1615626.50
      02-20-2024, 11:26 AM   #32
UncleWede
UncleWede's Avatar
Cost me ~$60 to re-cover the abandoned well at my dad's cabin this past weekend. 1/2 sheet of plywood, some deck screws, and a pint of mis-mixed leftover paint at the hardware store. I DID have to shovel a metric-fak-tonne of roof slide snow that fell on the old cover and broke it. I've seen wood that came off a 17th century galleon that was in better shape than that previous cover.
Our shared home well is at ~45 feet right now, with all the rain SoCal has been getting.
Pressure tanks need care, painting/inspection about every 5 years.
vreihen1615626.50
      04-12-2024, 06:19 PM   #33
spazzyfry123
4379
Curious on best approach here. New well has been doing great. Sediment filter has been getting worked out with my third one about to go in. Cool water seems to be where we need it. Hot water is still coming in brown, telling me we’ve got it in the two hot water tanks.
Is there a best practice to flush? Just keep running water? We’re a couple weeks being into the new house.
      04-12-2024, 07:15 PM   #34
vreihen16
vreihen16's Avatar
Is your sediment filter in front of the hot water heater(s)? If so, the hot water should be as clear as the cold water.....
      04-12-2024, 07:48 PM   #35
spazzyfry123
4379
It is. Pressure tank straight to sediment filter. Everything is thereafter.
My assumption is that the hot tanks are holding sediment that made it past the filter whereas just constant use flushed anything out of the cold lines. We've got two 50gal tanks. We've certainly ran enough to get it out, so something is just "stuck" in there. Wondering if there's a flush option. Brand new everything.
      04-12-2024, 07:59 PM   #36
vreihen16
vreihen16's Avatar
I would stop after the quick flush if both tanks are new and the water runs clean out of the drain hose:
https://www.thespruce.com/how-to-dra...heater-2719055
      04-14-2024, 02:29 PM   #37
spazzyfry123
4379
Went through the whole gig. My two heaters are in series.
Drained the second, drained the first. Filled them both back up. Drained the second and flushed the second. Drained the first and flushed the first. Both showed clear water. Filled back up and turned the heaters back on. Back to brown hot water again. Cold is still clear. I’m lost.
Calling well dudes tomorrow.
vreihen1615626.50
      05-10-2024, 05:44 PM   #38
tranquility
sportscars only
I've come to realize that given the replies here, esp from someone whose spouse is a water expert and wanting to take a break, that I'm just gonna leave this water thing to the city.
Septic tank is the furthest I'm going to go, I don't have a prb w stuff exiting my home but coming in is another story haha.
vreihen1615626.50
      05-12-2024, 05:48 PM   #39
vreihen16
vreihen16's Avatar
Septic tank is the further I'm going to go, I don't have a prb w stuff exiting my home but coming in is another story haha.
Ironically, my DW and I just returned from a short trip down to our tree farm. Met with a soil engineer, to draw the septic system and leach field designs for the state permit. Being on the lake, the requirements are a bit stricter to keep both runoff silt and effluent from reaching the shore bank.....
      05-13-2024, 11:44 AM   #40
UncleWede
UncleWede's Avatar
effluent runoff into a lake is under-rated for promotion of algae and mosquito.
vreihen1615626.50
      05-13-2024, 12:34 PM   #41
vreihen16
vreihen16's Avatar
That's *not* a Baby Ruth bar floating in the lake!!!!!
UncleWede18174.00
      05-13-2024, 12:37 PM   #42
spazzyfry123
4379
Coincidentally enough I just had a full home water filtration system installed for our well. Plumbers left about an hour ago
vreihen1615626.50
      05-13-2024, 12:57 PM   #43
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Avoid the pressure tank and spend more for a constant pressure pump, e.g. Grunfos, 15SQE10-250.
It's like having public water.
Make sure to have the well company place the pump wires inside of plastic conduit (the same black piping they use to protect the wire underground from the pump to the house.
When the pump spins up it rubs the wires against the well sleeve and in my case after 9 years wore through wire's sleeve and shorted out.
File Type: pdf Grundfos SQE SmartFlo End User Tri-Fold.pdf (1.94 MB, 39 views)
