10-26-2017, 12:47 PM | #23 | |
BimmerPost Supporting Vendor
3595
Rep 6,846
F: 18x9" ET30 - 245/40-18 R: 18x9.5" ET35 - 275/35-18 I have listed tire heights below to give you more context:
A 265/40-18 could be used in the rear though since the height is 26.35". That is almost perfect to the stock 265/35-19. Let us know if you have any other questions -Matt
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
04-09-2018, 02:46 PM | #24 |
3595
Rep 6,846
Check out our customer Arman's 2017 M Performance Edition M2 with 18" SM-10 Wheels in satin black.
18x9.5 ET35 SM-10 wheels Square 275/35/18 RE-71R Tires M Performance Coilovers 12mm spacer front, 5mm rear Ground Control Camber Plates
hexximus4.50 |
04-09-2018, 10:43 PM | #25 |
Rep 9
Will the ARC-8 19x9 et28 clear the front caliper without spacers? Really want to get these together with 19x9.5 et33 for the rear. I'm concerned that no-one has tried this combination yet which leads me to believe that it will not clear.
Thanks. |
04-10-2018, 12:09 AM | #26 | |
1445
Rep 2,673
Edit: At least a 3mm spacer will be needed up front to clear stock brakes with the 19x9" ET28 fitment. -Matt
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 05-07-2018 at 01:04 PM.. |
04-15-2018, 08:54 PM | #27 |
Rep 93
How much negative camber did this have with the M Performance coil overs?
2024 GLS
2016 X5 |
04-16-2018, 12:05 PM | #28 |
3595
Rep 6,846
While we don't know the exact specs that were used for this car, the Ground Control Touring camber plates should allow for at least 2 degrees of negative camber.
04-30-2018, 12:19 AM | #30 |
Rep 7
Does anyone have photos of any 19" Apex wheels on their car?
I saw these EC-7 (1https://www.apexraceparts.com/wheels/ec-7-wheels/19x10-5-et22-apex-ec-7-wheel.html), but wondering how these would look on an M2? |
05-07-2018, 12:17 PM | #31 | |
Rep 9
19" ARC-8
It barely touches but it did remove a layer of masking tape I had placed on the front face of the caliper. Looking to see if I can use a 3 mm spacer to gain some needed clearance. The bevel inside the center bore is shallower on the ARC8 vs the stock wheel so I may have enough hub engagement even with a 3 mm spacer. Otherwise I would have to go up to a 5 mm with a hub extender which will probably require added camber ($$). I really did not want to go with spacers but I really like the look of the ARC8's so may have to compromise. Peter |
05-07-2018, 01:00 PM | #32 | |
1445
Rep 2,673
You have a PM coming your way in order to best take care of you. -Matt
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
chiefsubjugator90.50 |
05-13-2018, 09:16 PM | #33 |
Rep 223
I loved my square set of snows using 18x9 FL-5 this past winter. Now I've got the stock 437M wheels back on for summer, but I'm starting to dream about my M2 with 19" FL-5...
Any chance 19" FL-5 will be available in the future? -OBSIDIANX-
2017 BMW M2 (LBB, 6MT)
2011 BMW 335i xDrive (N55) 2006 BMW X3 3.0 (M54B30) - Sold 5/17 |
05-14-2018, 04:05 AM | #34 | |
3595
Rep 6,846
19" FL-5 and SM-10 are coming, keep your eyes on our website in the coming weeks for more info on that! No firm ETA just yet but the wheels ARE coming! - Max
ObsidianX130.00 |
05-23-2018, 01:10 PM | #35 |
3595
Rep 6,846
Check out Tyspeed's (an authorized APEX Dealer) M2 Club Racer with 18" FL-5 wheels featuring our new M2 specific 10.5" wheels in the rear.
Front: APEX 18×10″ ET25 FL-5 Wheels in Satin Black 275/35R18 Dot-R Radial Tire 10mm Front Spacer Rear: APEX 18×10.5″ ET40 FL-5 Wheels in Satin Black (M2 Specific Fitment) 285/30R18 Dot-R Radial Tire Bimmerworld Premium Race Stud Kit See more details on this build on our blog here.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 05-29-2018 at 05:08 PM.. |
05-25-2018, 07:04 PM | #36 |
Chief Warrant Officer
1025
Rep 1,638
While I don't have an M2 yet (waiting for an M2C), I just recently put some EC-7's in Anthracite on my BSM 135, and they look AMAZING!
I coveted them from afar for years and finally pulled the trigger. Should have done it sooner. I highly recommend APEX wheels if you are considering them (and I'm especially a fan of the EC-7).
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
06-06-2018, 03:46 PM | #37 |
3595
Rep 6,846
We just shot these photos of Silicon Valley Motor Club's M2 track car with APEX FL-5 wheels.
Square setup: 18x9.5" ET35 FL-5 wheels in Satin Black 5mm front spacers 275/35ZR18 95W Nitto NT01 Tires Sparta Evolution BBK and a photo from GotBlueMilk.com on track at Thunderhill at an HOD event
06-09-2018, 08:24 PM | #38 | |
Life is on the Track, the rest is just waiting.
383
Rep 731
06-11-2018, 12:04 PM | #39 | |
3595
Rep 6,846
--Dylan
06-11-2018, 01:27 PM | #40 |
383
Rep 731
Not sure I understand. The quote above states 275/35 with 5mm spacers. Your saying 5mm with 265/35, and maybe larger spacer for 275/35. Is that correct.
06-11-2018, 01:49 PM | #41 | |
3595
Rep 6,846
We have tested many fitments that are known to be a bolt-on-and-go direct fit, but we know that many drivers will want to push the envelope a bit. Essentially, when running these more aggressive (275 and wider) fitments, we recommend being prepared to make minor changes or add spacers if necessary in order to get things dialed in perfectly. --Dylan
chief1richard383.00 |
06-12-2018, 06:03 PM | #43 | |
3595
Rep 6,846
--Dylan
06-13-2018, 05:49 AM | #44 | |
Rep 4,529
If so - what width/offset works and could Apex have an 18" wheel option for M2Comp with m sport or MPerf BBK upgrade ???
Current '22 X3M LCI.. |
