06-21-2017, 07:42 PM | #23 | |
Rep 8,942
I wasn't planning to go too crazy since I will only use it rarely on long drives for Escort Live or OBD app for when I am really trying to avoid LEOs. Right now my lead candidate is a pair of belkin cup holders mounted to a speck candy shell case, so I can just wedge the whole thing in there. I don't want to buy another mini just for this so it all has to be easily removable.
06-21-2017, 08:27 PM | #24 | |
Rep 1,183
Right now I have mine wrapped in black suede to match mperformance interior with one of those grippy mats. |
06-29-2017, 09:37 AM | #25 |
Rep 8,942
So I ordered a Goluk T3 since it's small, basic, comes with an iPhone app and importantly for my install uses a standard USB cable for charging. Question for guys who use parking mode. Rather than hardwire it to my battery which is harder since it's in the trunk, anyone use a backup battery for an iPhone or whatever? So plug battery into USB and then plug camera into battery? Seems like it should work and be a much easier install. Plan to mount camera behind my Nav screen could just run wire to glovebox and plug everything into the USB port there.
06-29-2017, 10:01 AM | #26 | |
Rep 1,183
06-29-2017, 10:03 AM | #27 |
Rep 1,183
Does anyone know if there is an empty fuse location under the hood that is "permanently on".
Are there any hardwire alternatives other than directly to the battery that will ensure that camera stays on for sentry mode? |
06-29-2017, 10:26 AM | #28 | |
Rep 8,942
My main concern would be how the power pack actually works. So when car is on and it's getting power, does the batter charge while it's passing power through to camera? Or am I basically filling up the battery while the camera is draining it so I'm not ahead of the game?
06-29-2017, 10:30 AM | #29 | |
Rep 1,183
06-29-2017, 10:33 AM | #30 | |
Rep 8,942
Actually decided to order after some asshole in a white volvo with blue racing stripes tried to run me off the road and passed me and 3 other cars (blowing through a stop sign) doing close to 100mph in a 25 no passing double yellow zone.
07-02-2017, 12:40 PM | #31 |
Rep 23
I have Backvue units fitted front and rear and can't fault them, Dash cams should be fit and forget but I use a lot of the features on this set up all of the time. I have just handed some of the footage over to the Police here in the UK to use for prosecution and they were very happy with what I had captured ..
Remember buy cheep buy twice.
BMW M235i 2016, BMW 624 staggered alloys (Polished), MP front splitter, MP rear carbon boot spoiler, MP side blades, MP rear defuser, MP chrome exhaust tips, BMW sun protection pack, BMW interior carbon/alcantara pack, BMW professional navigation I have some other toys too
07-02-2017, 12:44 PM | #32 |
Rep 8,942
Just finished my Goluk T3 install took all of 5 mins. The tab from the mount fits nicely in the gap between the Nav screen and the dash with a couple of wraps of fabric tape for an extra snug fit. I replaced the included USB cable with a 90 degree one. Then it's just a matter of popping off the speaker grille and pulling the center vent to run the wire for power. Can do either glovebox or in this case I ran it to armrest where I have a USB hub. View probably a little better if mounted top of windshield but that's hard to do and run wires in a convertible and I didn't want to see the camera from the drivers seat. Can post more details if anyone is interested. Under $100 all-in. I'd have done front and rear but again convertible complicates that quite a bit.
07-02-2017, 12:56 PM | #34 |
Rep 5,582
Bem-54 tell me more about your power connection, are you simply plugged into the USB and constantly drawing a small maintenance voltage for the 'impact while parked' mode/
Or is your cam only functional while driving? does the power from the USB turn off completely after the car has been parked for about 20-minutes? |
07-02-2017, 01:02 PM | #35 | |
Rep 8,942
We take GF's sedan when we park anyplace the car could get messed with. That said in this case were I to park my car someplace and want the dash cam on - I always have one or two of those backup iPhone charger battery packs in my bag. I tested the dash cam it works off that (it's USB) so in the very rare event my my car is parked someplace shady I'd just plug it into that. Should last a full day since the camera is on sip mode most of the time. I really didn't want to overcomplicate matters for something that's an issue once a month at the most. Even then plugging it into the battery pack is a 2 second job.
07-02-2017, 01:08 PM | #36 |
Rep 5,582
Bem-54 great info, where did you order the cam from?
Is the camera compatible with Apple and USB-C connections ? I'm not visualizing how you route the wire into the center console cubby, but I'd probably just run mine exposed. |
07-02-2017, 01:12 PM | #37 | |
Rep 8,942
The cable is seriously easy. That said I removed my center speaker so probably easier since I have more room to work in there. Grille pops right off just lift up held in with pressure clips. Center vents pull straight out. From there I found it easiest to feed small end up micro USB up through speaker area. Then large end you just shove down to passenger footwell and pop it out. From there tuck it under the tunnel and pop up into armrest. If you pull the grille and the vent you'll have no problem seeing what to do.
07-02-2017, 01:15 PM | #38 |
Rep 8,942
Check this thread it explains everything about running the wires with pics. But in this case you'd have one more step of running the wire up to the speaker area. If you remove the grille you'll see daylight between the two vent ducts.
http://f20.1addicts.com/forums/showthread.php?t=702457 You could also probably pull the vent and unbolt the screen and fish the wire behind but I'm a big believer in screw with cheap parts (grille) vs expensive parts.
07-02-2017, 01:18 PM | #40 |
Rep 8,942
NP you too! Any questions ping me next week.
07-02-2017, 01:21 PM | #41 |
Rep 1,930
install looks great.
www.nybmwcca.org
07-13-2017, 08:42 AM | #42 | |
Rep 1,183
I am worried about battery drain issue as I love near the city so there is a lot of movement all the time. Also I don't daily drive safe sometimes it sits for a couple days. |
07-18-2017, 04:30 PM | #43 |
Rep 8,942
Just FYI for folks looking to do something similar I moved the camera to top of windshield for a a better viewing angle. The mounting tab fits nicely under the trim. Running the USB under the trim and into the glovebox was a 5 minute install.
In all honestly I'd skip the dash option. You and up seeing a lot of dash as the camera is a touch too low. Was worth a shot.
08-01-2017, 08:58 AM | #44 |
Rep 1,183
Fyi i have my blacksys cam hardwired so that the sentry mode works.
Even with the cameras voltage cuttoff i still get a voltage draining error when i start the car in the morning |
