| 05-22-2016, 08:35 AM | #23 |
![]() ![]() 1069
Rep 5,555
Here is 1L bottle (need 2)
https://www.turnermotorsport.com/p-1...pQkhoCkuXw_wcB People say this is the same as BMW stuff https://www.ecstuning.com/b-genuine-...r/00004320729/ This is what they use in diff on M cars, maybe same for this LSD https://www.turnermotorsport.com/p-2...xMVRoCV-zw_wcB PS. Read some posts, alot of dealers skipping tranny break-in change even on M cars Last edited by Kolyan2k; 05-22-2016 at 09:00 AM.. |
| 05-22-2016, 09:14 AM | #24 | |
Rep 630
| 05-22-2016, 07:45 PM | #25 | |
![]() ![]() ![]() ![]() 320
Rep 886
I had my rear diff fluid done at a dealer for ~$100. I dropped it 30k miles later to do it again. My usual SA was out that day, so someone else handled it. He called me a few hours later and asked if I resally wanted it done, as it was going to be over $400. Apparently, as there is no drain plug, he wrote it for a full disassembly of the rear diff to drain it, at book rates. I told him it was a 30 minute job (that they had done before) to vac out the fluid and then refill it, at T&M shop rates. He looked up the prior work, agreed that made more sense ( ) and re-wrote it that way.You never want to just drop and wave without knowing what they're going to charge if they haven't done it before.
![]() Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
| 05-22-2016, 11:13 PM | #26 | ||
Rep 630
| Bookmarks |
