03-24-2016, 02:03 PM | #23 | |
Rep 178
^^correct. STs are basically the equivalent to KW v1 (w/out dampening) but of course, you lose adaptive suspension. had STs on my previous vehicle and had no issues. of course the ride was stiffer, but considering the price, overall it was good.
-roger
Current: '15 F22 EB 228i | M Sport | 6MT | Dinan | Rotiform | 35% tint | CF side mirrors Gone: '11 B8 A4 | '08 Infiniti G37 Coupe 6MT | '04 E46 M3 6MT |
03-29-2016, 10:53 AM | #24 | |
Rep 1,541
03-29-2016, 10:59 AM | #25 |
Rep 2,384
Yep you absolutely can. If i ever go to a coilover that would be my plan also, however a lot of forum members want to retain the EDC functionality.
04-04-2016, 08:45 AM | #26 |
Rep 127
If OP is only interested in looks/costs the spring route we be easiest and least expensive. IMO, one buys coil overs for their adjustability and potential handling improvements...and one buys springs for looks and slight handling gains within an acceptable ride stiffness increase.
Modest spring rate/drop changes will aid handling (roll) with minimal impact on strut life with virtually no maintenance. Coil overs can provide more drop and are adjustable but you'll need camber plates to offset camber loss and they will have a finite life before rebuilding. Depending on brand and seasonally driving situations coil overs may need additional attention/care. Once you add camber plates the nvh goes up significantly. Cost aside if I wanted a modest increase in performance and appearence while maintaining overall quality and ride I'd go with M4 LCA and swaybars. Most reliable and least intrusive mods but sways+install is $$. If it was used as an aggressive street/AUTOX or occasional tracked car then going the extra distance to coil overs, camber plates, bushings, and chassis stiffening plus LSD would be the best alternative. |
04-10-2016, 06:55 PM | #27 | |
Rep 292
2015 M235i BSM / 2011 X5D AW
04-11-2016, 02:37 PM | #28 |
Rep 1,541
04-11-2016, 03:24 PM | #29 |
Rep 292
They definitely do it right the first time!
