03-01-2016, 01:33 PM | #23 | |
Rep 29
http://www.bimmerfest.com/forums/sho...d.php?t=899063 One of the more knowledgeable contributors there did a comparison between the values showing in my log file and the values on his F80 and recommended making a few FDL coding changes. However after doing this it's still not working. So, will probably require someone a little more knowledgeable yet to compare the new HU with the old one... it is also possible that there is a CAFD file change in ESYS that is needed to get this working fully. |
03-02-2016, 09:16 AM | #24 |
Rep 35
I've seen the thread, and successfully VO coded and the only parameter I can't find and change is
HMI_36_36_8=nicht_aktiv I guess the newer build HU NBT2 need something else changed instead. |
03-02-2016, 09:35 AM | #25 | |
Rep 29
You might want to comment on the thread at Bimmerfest that you also have the issue in order to bump it up and keep people engaged. |
03-03-2016, 09:39 PM | #26 |
Rep 25
Quick update on my findings.
I had coded 6NH --> 6NS, didn't change any of the other FDLs that were mentioned. I then could see the Office menu in connected drive. I then removed and repaired my Nexus 6P (Google Fi), accepted the message on the phone asking to share contacts and message. Office then pulled in a lot of text messages that I had imported from my last phone into the Nexus 6P when I got it. No new messages show up, only old ones. After finally finding the Bluetooth configure settings I turned on Telephone 2, and connected my old Samsung Galaxy S5 (Verizon). I haven't disconnected that phone yet, so it still has service I just don't use it. Anyway, I paired the Galaxy S5 and it shows up and works as Telephone 2. It also displays text messages on the car as I receive them. (sent texts between the two phones). So, to recap in my scenario (New 2016 M235i that I bought a couple weeks ago). Changing 6NH to 6NS successfully enabled Telephone 2 and Office functionality. Google Hangouts apparently doesn't work for notifications in the BMW, the default Samsung messages app does. I didn't test email on the Galaxy S5, but I haven't seen any messages show up from the Nexus 6P for email (I use both Inbox and Gmail)... |
03-03-2016, 10:13 PM | #27 | |
Rep 5,262
not sure how it works on android |
03-06-2016, 08:46 PM | #29 | |
Rep 29
03-07-2016, 09:59 AM | #30 | |
Rep 25
How do I confirm which one I have? When I went in to code stuff, mine showed HU_NBT2 Let me know what else you need me to lookup and I can try (don't have a laptop now though, borrowed one for coding)... |
03-07-2016, 11:30 AM | #31 | |
Rep 29
However I'm not aware of anyone else who followed the steps of; 1. re-coding the car FA with 6NS 2. VO coding the HU_NBT2 module Who has gotten all of the 6NS functions to work such as pairing phone(2) and messages working. Did you happen to FDL code any other values? Certainly mine doesn't work. |
03-07-2016, 12:52 PM | #32 |
Rep 29
I should also mention that I just got the TSB for my 340i done and they did re-code and uplifted the FW on the car, which could be related to this not working, I had never tried it before the FW update was done by the dealer.
03-07-2016, 04:44 PM | #33 | |
Rep 25
03-11-2016, 08:36 AM | #34 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
Go to telephone then press OPTION on the IDRIVE KNOB and scroll to the very bottom where it says configure Bluetooth. Show us what options you have.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
04-14-2016, 02:13 AM | #36 | |
Rep 14
I was able to pair 2 phones simultaneously after checking these boxes. Still no luck getting messages to show up but I think that's an iOS issue. |
04-14-2016, 10:31 AM | #37 | |
Rep 5,262
04-14-2016, 04:06 PM | #38 |
Rep 14
Quick update, I checked again this morning and messages are now working on both my iPhone (iOS 9) and my galaxy S5 (android 5.1.1). I think either the phones need to be reconnected or maybe the NBT needs to be restarted.
Just to confirm what others have said, on android, both text and email will sync with existing messages on the phone. On iPhone, only text will sync with new messages received since the phone was connected and no email option at all. So a few things to watch out for people trying to do this:
This isn't anything that other haven't already said; just thought I would add a data point as someone with HU_NBT2 who got 6NS to eventually work. |
04-14-2016, 06:58 PM | #39 | |
Rep 5,262
04-15-2016, 07:01 PM | #41 |
Rep 5,262
05-19-2016, 05:52 PM | #42 |
Rep 63
I recently vo coded to 6ns. I did very simply, just this,
1. re-coding the car FA with 6NS 2. VO coding the HU_NBT2 module This enabled office, and I was able to go to BT settings and enable phone 2 and office. Enabling office allowed me to see the option to enable "show notifications" on my iPhone (6+). BUT... turning on show notifications and checking the correct options in iDrive, I still don't receive any text messages through iDrive. Nor emails. I will mess around with it tonight and see if I can get it to work... also its a MY16 with tech package. |
