01-07-2015, 09:41 PM | #23 |
Rep 736
I have the LSD and I as I noted in a previous post and as one of the posters here stated, the e-Diff on the M235 is very very good. My feeling is that if you are not tracking or driving very aggressively on the street you will NOT feel the advantages of the MP Diff.
Yes it is a bit more predictable and smoother versus the e-diff in some situations but it is not really worth the expense unless you are tracking the car. I don't know what the M-team did but that stock e-Diff is impressive. And as stated, you will only really get the most benefit from the MP Diff when DSC is turned OFF (hold for 5 sec). I only got it because of a special situation and my EGO wanted to feel like we were back in our old M3
2011 335 E90 MSport PPK - retired
2008 M3 - retired 2007 335 E92 - Buy back 2007 X3 MSport - retired 1995 M3 - retired |
01-08-2015, 01:53 AM | #24 |
Rep 1,091
OK, how about DTC on - will it not suffice for the mechanical LSD to intervene before eDif? After all, DTC on allows for considerable forward spin, while still preventing stability loss... Because if entire DSC must be off for LSD to act, the latter really is of no use in other than track driving.
previous: 2003 E46 330i SMG
01-08-2015, 04:52 AM | #25 |
Rep 1,091
Here is an excerpt from the official, BMW M-P LSD product leaflet:
"– Whether it's rain, snow or dry conditions – traction is improved for any type of road condition. When the driver deactivates all control systems (display: DSC deactivated/DSC off), careful driving is required in wet and snow conditions and is only recommended for closed areas" Dear God, how can they be so vague! It's worded as if using (read: taking all advantage of) the LSD indeed depended on DSC being off, but it is not stated so (or otherwise) clearly enough...
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 01-08-2015 at 05:21 AM.. |
01-08-2015, 05:01 AM | #26 | |
Rep 1,852
01-08-2015, 05:15 AM | #27 | |
Rep 1,091
Therefore I'd like to ask you as an actual LSD user: if you don't turn DSC off completely (instead, use DTC on for instance, or don't tamper with DSC button at all), and you power- slide through a curve - do you or do you not feel e-diff being faster than LSD and brake your slipping wheel? Or similarly - did you ever find e-diff "fighting" with LSD the "who's faster to stop this spinning wheel" game with DSC on? Your answer could really help me made a more educated decision; I'm definitely not going to track my car, but also definitely am I a fast driver and - like most of us, RWD bimmer enthusiasts - like to play with the tail of my car
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 01-08-2015 at 05:38 AM.. |
01-08-2015, 05:42 AM | #28 | |
Rep 1,091
01-08-2015, 07:14 AM | #29 |
Rep 1,091
To put my question differently:
Assuming DSC is ON (i.e. in public road traffic), when you press on the gas to power-exit a curve or alike - will e-Diff "be faster" and apply brakes to your spinning wheel, rendering LSD useless? Or will LSD take upper hand and prevent e-diff from intervening, thus allowing nice slide with uninterrupted power on the rear wheels? Answering these questions would make it clear whether or not one actually has to turn DSC OFF in order to make any use of LSD...
01-08-2015, 07:58 AM | #30 | |
Rep 863
Drives: '19 M2 '21 X5
01-08-2015, 08:06 AM | #31 |
Rep 242
01-08-2015, 08:19 AM | #32 |
Rep 863
01-08-2015, 08:29 AM | #33 | |
Rep 1,091
Interestingly, I got an answer on another forum that e-diff is only active with DSC OFF (which would of course imply it's inactive with DSC on). This is something I never suspected - thought DSC OFF=no electronic nannies whatsoever; what is the truth?
01-08-2015, 08:30 AM | #34 |
Rep 242
01-08-2015, 08:35 AM | #35 |
Rep 1,091
This is called "intelligence" and "insightfulness"
01-08-2015, 08:42 AM | #36 |
Rep 179
Ok ok, Sport+ = DTC on (optimized traction control - a version of DSC where forward momentum is optimized. Allows better traction on loose ground and limited stability during acceleration and driving around bends). I've been driving BMWs for 15 years and I've never liked their nomenclature around stability and traction control.
01-08-2015, 08:47 AM | #37 | |
Rep 863
One of the challenges is isolating the effected of the ediff (which emulates the lsd) from the stability control. One of the times when an lsd would engage is cornering, particularly when you are oversteering the car. The ediff would theoretically let you oversteer the car. The stability control however will use the same mechanism (brakes) to try to straighten the path of the car. Since we don't have a page in idrive where we can toggle all these different systems on or off it becomes very hard to isolate what is happening. |
01-08-2015, 09:06 AM | #38 | |
Rep 1,091
1. The guy who maintained ediff only works with DSC OFF has proven with his other post he's confusing DSC with DTC, so this part can be dismissed 2. LSD over-riding ediff when cornering/oversteering, and ediff taking upper hand in case of stability loss would actually be a very good scenario, don't you think?
01-08-2015, 09:08 AM | #39 |
***** noob
1402
Rep 10,477
Can we all just get along? :
2006 325xi (Sold)
01-08-2015, 09:15 AM | #40 | |
Rep 863
Even in Sport+ it should prevent you from over steering to the point of actually spinning the car which is exactly its purpose. Ultimately there really is no way to know unless you can see the control system diagram on BMW's DSC system... What the limits are, order of preference etc. (i feel like this post is getting circular, its complicated) With the nannies on there are lots of things the car can do to keep you out of trouble. Back to the original topic the LSD gives you an extra tool in low slip situations that performs better than the emulated system. This tool has worked well for me this winter in my opinion |
01-08-2015, 09:47 AM | #41 | |
Rep 36
My take on this however is we never really know if DSC OFF=no electronic nannies whatsoever since there are multiple layers of "software nannies" that manufacturers can build into their cars which get triggered in certain situations and the only way to prove that the nannies are truly off is when you play with the car at ridiculous (maybe unsafe) levels (hopefully in a track or skidpad). Unless BMW themselves comment on it then we are all in the dark. I would "assume" (so i could be wrong) that the LSD that BMW offers for the M235i triggers before the e-diff does even with all the nannies turned on since it would be of limited use if that was not the case. Maybe a quick chat with the service guys could get you the answers you need since they should be up to date with this car. The service people could also turn off the e-diff feature if they were in a cooperative mood, then the LSD never gets interference from the e-diff and it does not affect any other systems (they would not do this for me when I was looking at a twin turbo 135 sometime in about 2008. I wanted to put an aftermarket LSD so I did not buy the car) but I know it can be done (the only reason I could think of is, it might interfere with the activation of DSC). |
01-08-2015, 10:07 AM | #42 | ||
Rep 1,091
Anyway, you helped me tremendously with your answers; thank a lot!
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 01-08-2015 at 10:23 AM.. |
01-08-2015, 10:15 AM | #43 | |
Rep 1,091
I also agree with you that - even if BMW still claims DSC off is "all nannies go home" - with more and more other brands making it impossible, I think it's probable BMW is just posing to be "one of the last driver's cars" maker, while in fact they leave some last resort electronic protection in case the driver doesn't know completely what he is doing after switching DSC off. But this will not defy the laws of physics, either...
01-08-2015, 10:33 AM | #44 | |
***** noob
1402
Rep 10,477
Sure good luck with the lsd decision
2006 325xi (Sold)
