01-08-2016, 05:02 AM | #23 |
Rep 1
I have both the engine, but next 2 will be better
01-08-2016, 06:58 AM | #24 | |
Rep 417
That's somewhat reassuring, although I wonder if there are different chassis requirements between a FW biased and a RW biased AWD system, and if there are similarities between the FW biased AWD system and the FWD car that will make it too tempting to cut costs by sharing components. I'm not automotive engineer or suspension expert, but is seems reasonable (from a business perspective) that BMW would do this instead of making RW bias AWD system.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport |
01-08-2016, 07:26 AM | #25 | |
Rep 886
xDrive works with a central transfer case no matter what. There will be driveshafts to both front and rear axles, and the clutch pack transfer case can load them however it wants. That's different from other systems such as Audi's Haldex-based system (which runs FWD until slip occurs) or their older Torsen system (which had a fixed split all the time). Those systems are truly "biased" from a mechanical perspective, whereas BMW shoves it around at will via the ECU. Weight distribution may not cooperate, however, if you get a nose heavy design as a function of a base FWD car.
01-08-2016, 08:19 AM | #26 | |
Rep 229
http://www.autoevolution.com/news/bm...ned-89358.html The xDrive models weigh just 61 kg more than FWD ones The Active Tourer range is aiming at offering both space and luxury and the BMW badge and all that should come with it. That means drivers will expect the car to handle in a certain way. FWD doesn’t allow the car to be particularly dynamic, but with all-wheel drive things change. The xDrive system for the car weighs just 61 kg (134 lbs) and features technology that allows to save the amount of losses per the drivetrain to a minimum. Power from the front drive to the rear axle is transferred thanks to an angular gear on the front differential and a two-part cardan shaft that are called ‘Power Take-Off’. The heart of the entire system is an electro-hidraulic multiple-disk clutch (Hang-On) fitted inside the rear axle drive. Its job is to vary the torque distribution between the front and rear wheels via a hydraulic pump. Power Take-Off We know BMW likes to use all sorts of weird names for its technologies so we had to know what Power Take-Off actually meant. As far as we can tell, it’s an angular gear mounted behind the engine, on the automatic transmission and crankcase. The input shaft is a hollow shaft construction and directly connected to the front axle differential. This way, part of the drive force is transferred from the differential basket to the cardan shaft via the hollow shaft, the crown wheel and the pinion shaft. Hang-On As far as ‘Hang-On’ goes, this is the multiple disk clutch located in the rear axle drive. It directs a proportion of torque to the rear wheels, depending on the driving situation. It can send up to 100 percent of the power to one axle and is operated by a hydraulic pump which, in turn, is controlled by a pulse-width-modulated signal from the ECU. What makes this system stand out compared to others is that the pressure inside the pump is not measured by a sensor but rather by means of voltage and power alignment. The cars are front-wheel drive when all-wheel drive is not needed In order to be as efficient as possible, the xDrive system deactivates the pump that controls the multiple disk clutch when all-wheel drive is not needed, turning the car into a front-wheel drive vehicle. Thanks to a spring-loaded valve, the oil level in the clutch is lowered, reducing friction losses, making the car run even more efficiently. |
01-08-2016, 09:05 AM | #27 | |
Rep 886
01-08-2016, 09:32 AM | #28 | |
Rep 1,752
01-08-2016, 11:08 AM | #29 | |
Rep 361
Because my preference is for a small, fixed-roof vehicle (and I'm not in a position to install charging hardware), the 2er is the only BMW that I could consider. If the equivalent model is FWD when I'm ready to look for a replacement, I'll likely end up looking elsewhere (assuming there's still somewhere else to look). |
01-08-2016, 04:19 PM | #30 | ||
Resident BMW Fanboy
259
Rep 866
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
01-10-2016, 10:42 PM | #31 | |
Rep 361
I don't track my car, so I want to have fun driving my usual routes. My 228i is a good fit for this (as was my FR-S), but I'm not convinced that an M235i would be better (an M2 definitely wouldn't be). I just don't drive anywhere exciting enough to benefit from it. Not that this has anything to do with the original question. :-) |
01-10-2016, 11:15 PM | #32 | ||
Resident BMW Fanboy
259
Rep 866
01-13-2016, 02:40 PM | #33 | |
Rep 459
