10-12-2023, 01:41 PM | #23 |
Rep 240
+1 on finding a reputable shop that will cover the edges.
After two years with my partial "track" PPF package + ceramic coating, some points I would consider: 1. If you plan on any aero additions soon, do it before you get PPF for maximum savings. My shop charges $250+ for each CF spoiler, lip, sides, all which could have been included had I already had the installed. 2. If you sustain damage on just the PPF, you have to re-do which will be $500+per panel. If the damage goes through the PPF, you have to repair, re-coat paint, AND re-do the ppf. 3. With different tiers for Ceramic Coating, I'd get it done professionally only if you get the highest package- for anything below, I'd just do it myself, if you have polishing experience. I saw significant difference from the mid-tier Ceramic Coating vs when I upgraded to the highest a year later. 4. If you are OCD, the lines across panels for partial PPF is pretty noticeable, not to mention any color differences when you do remove them. Overall, here is what I'd recommend: - Forever car, Investment car- Full PPF, Professional Ceramic Coating - Weekender, 4-5 year keeper- Front bumper/Hood, Rocker panels, Ceramic Coating (Pro or DIY) - Track use- Above+ PPF on mirrors, Front Fenders, Windshield But given your situation, especially if many things are uncertain, I'd honestly just ceramic coat it myself and call it a day. These are ultimately just additional leisures and hobbies.
2021 BMW M2C / AA / Remus / KW
10-12-2023, 01:43 PM | #24 |
The Seeker
14160
Rep 3,416
But it can also be too glossy. I've seen that many times. Until the film gets some age on it you can clearly see the difference between it and the paint.
Forzanerazzurri6922.50 miiipilot522.00 |
10-12-2023, 01:51 PM | #25 |
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
Interesting. Are you saying in applications where you have only parts of the car done? I can definitely see that being an issue because my car is full PPF (not XPEL) and its way glossier and flatter than any factory paint job I've seen on a BMW. But since its full there are no transitions.
10-12-2023, 04:57 PM | #26 | |
Rep 7,340
10-12-2023, 05:34 PM | #28 |
Rep 7,340
I would not be concerned about the aging of the film, honestly. I would be more concerned about the non-PPFed areas oxidizing slightly over time and that causing a mismatch. You can always pull the film and replace, and will need to if it gets enough rock chips etc.
miiipilot522.00 |
10-12-2023, 05:41 PM | #29 |
Rep 37
How well does PPF withstand touchless car washes? If you live in a colder climates where they use salt on roads, taking your car though a touchless carwash is pretty much a must in winter (as they do an underbody spray to wash off the salt).
10-12-2023, 08:17 PM | #30 | |
The Seeker
14160
Rep 3,416
10-12-2023, 09:58 PM | #31 | |
Rep 3,276
I use hand washes (wand washes) exclusively. There are ones with underbody jets too that you park over. Wand washes also allow you to inspect the car for damage as you clean it as well. My car has full PPF with ceramic infused. I generally don't touch my car much physically in winter I just use the wand wash once a week and don't bother with the road film because it just comes back immediately. There are no swirls on my car from last winter at all and I get it professionally detailed in the spring and it looks brand new. The ceramic infusion is also as good as new. |
miiipilot522.00 |
10-12-2023, 10:24 PM | #32 | |
Rep 37
The problem with not washing the car in winter is that you are not doing your underbody any favours by allowing salt and other chemicals they put on the road to accumulate there. |
10-12-2023, 10:37 PM | #33 | |
Rep 3,276
10-12-2023, 10:47 PM | #34 |
OPN DIFF
479
Rep 1,912
Drives: 10' E90 M3 6MT LB
The guy I use, he did paint correction, ceramic coat then PPF the entire front, ceramic coat the PPF afterwards.
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
10-13-2023, 12:48 AM | #35 |
Rep 7,340
Touchless should be fine but will weaken sealants and ceramic coatings over time. They usually use alkaline washes some over pH 11. I doubt it would affect PPF adhesive once it’s had a week or so. I probably wouldn’t use them all the time but occasionally shouldn’t be disastrous.
10-13-2023, 01:44 AM | #36 |
Rep 1,472
Drives: 2023 G81 M3 Touring
10-13-2023, 04:36 AM | #37 |
Rep 4,585
Drives: 2022 Z4 M40i, 2021 228i GC
10-13-2023, 08:26 AM | #38 |
Rep 7,340
Not only that, it could interfere with the adhesive if it’s a slick coating, though not all are.
Westside Guy5958.50 miiipilot522.00 |
10-13-2023, 05:06 PM | #39 |
OPN DIFF
479
Rep 1,912
It has no problems getting the ppf to stick. It’s to save the headache when the PPF needs to be replaced, easier to remove PPF, also less likely to damage paint when PPF gets removed.
miiipilot522.00 |
10-13-2023, 06:34 PM | #40 |
Rep 7,340
Ask XPEL, Suntek, 3M, STEK, etc. directly and I bet none of them will tell you it is a good idea to apply it over a ceramic coating.
10-14-2023, 11:13 AM | #41 |
Rep 4,585
10-18-2023, 03:41 PM | #43 | |
OPN DIFF
479
Rep 1,912
What do I know, everyone on the internet is right.
miiipilot522.00 |
10-18-2023, 04:11 PM | #44 | |
Rep 7,340
Oh, look, SunTek specifically says to remove the coating first. |
miiipilot522.00 ///MPhatic14159.50 |
