11-28-2016, 07:39 PM | #331 | |
Rep 470
If anyone needs more info than this let me know and I'll snap a picture. |
12-05-2016, 09:58 PM | #334 |
Rep 983
JL C2-400X Installed
It's official, i finally got my JL C2-400X's installed in the rear. Overall the process was pretty straight forward.
Requirements: JL C2-400X Pair of OEM style connector harnesses Plastic Trim removal kit to remove grills T25 for the screws holding them in Sound dampening mat Mat install roller tool Uncarriage bolt/washer for third screw (BMW part 07149126886) |
Beartato887.50 |
12-06-2016, 03:58 AM | #335 | |
Tea wot?
210
Rep 271
More info in this thread. http://babybmw.net/forum/viewtopic.php?f=74&t=92733 For around £550 you can replace the front, rears and underseat subs with plug and play focal units. |
12-06-2016, 08:00 AM | #336 |
Rep 146
Did the sound deadening Material make a big difference on the rear deck?
2015 ///M235iX | Mineral Grey | Dakota Black | Premium | Tech | Cold | Driver Ast | HK Sound | Black Kidney Grilles | M-Performance Exhaust | Front Splitter | Carbon Fiber Mirror Caps, Rear Spoiler and Exhaust Finishers
12-06-2016, 09:39 AM | #337 |
Rep 983
I dunno but it sure looks cool! Added an extra hour onto the deal, but it was pleasing.
I want to take off the whole deck and add a layer undernear, and find a way to prevent the rattle from this thing. It is very loosely attached and flaps around with a real trunk subwoofer, very F*cking annoying |
12-06-2016, 11:40 AM | #338 |
Rep 1,202
I was just about to ask in this thread about the third screw for the rears, but I guess I don't have to now thanks!
Ever since install I've noticed a tapping sound from the rear on bumpy roads, and I can only assume it's the speaker moving. |
12-06-2016, 02:42 PM | #339 |
Rep 5,479
With respect to the BMW OEM Speaker Connector Harness Pigtails, it's not entirely clear in this thread how many sets you should order from the Ebay site. Does ordering one set comprise enough pigtails to complete the install of two speakers OR do you need to order two sets to complete the install? Thanks.
12-06-2016, 03:08 PM | #340 |
Rep 983
One set is a pair of pigtails. It does state pair if you read the auction I know the picture is misleading.
One pair. When you install check the red wire matches the red striped wire in the OEM connector. Because i had to swap the pins on mine to match. I was able to do this on the pigtail connector, with a small flat jewelers screwdrivers, to remove each pin and re-insert into the opposite position. It's very easy, there is a plastic cover over the top of the connector hiding the recess where you can press down on the locking tab on the pins.. Once you remove that little locking tab, you can insert your tiny flathead and while pulling it will slide through, you will have to do it twice as it passes through the connector. When you do it, you will see what i mean. Go slowly and gently, the tab will break if you try to force it out.. When you get it, it pulls through nice and easy. |
12-06-2016, 04:52 PM | #341 | |
Rep 2,942
12-06-2016, 04:55 PM | #342 | |
Rep 2,942
... but just in case, I've used Loctite (the lightest variety; red, I think) on my third speaker screw. No' mo' rattling, knock on wood.
Beartato887.50 fancyfl1ght65.00 |
12-06-2016, 06:06 PM | #343 |
Rep 983
Well if you've already crimped on your connectors on the pigtails for the C2-400X's you'll noticed there is a large one and a small one... Thus i did it my way !
Plus what's the point in doing it if your not going to do it right Regardless it works either work. Takes a few moments to do it right. |
12-07-2016, 05:02 AM | #344 |
Rep 492
This is a great thread and super helpful. Off the back of it I've purchased the JL Audios for rear, Eatons for Front, pigtails, dynamat and ASD harness - so all good to go.
But just wondering, why are we not replacing the rears with the same component Eaton set we are using in the front? Is it a cost thing vs audible improvements (JL's being cheaper than Eatons)? In a perfect world (which it isn't) wouldn't it be better to have same drivers all round and aren't the rears an easy swap out/swap in? Thanks |
12-07-2016, 05:22 AM | #345 | |
Rep 209
Matt
12-07-2016, 08:55 AM | #346 | |
Rep 300
12-07-2016, 08:56 AM | #347 | ||
Rep 300
12-07-2016, 09:01 AM | #348 | |
Rep 492
JL-A grills and then OEM over the top? Or just OEM grills? |
12-07-2016, 09:04 AM | #349 | ||
Rep 492
12-07-2016, 02:13 PM | #350 |
Rep 209
Is that on the map you uploaded in the other thread? I'm going to try that this weekend.
Matt
12-07-2016, 03:13 PM | #351 | |
Rep 470
and use the OEM grille over that. |
12-07-2016, 03:18 PM | #352 | ||
Rep 492
